could you please write me, which CodeWarrior and which version you use? Which debug probe you use?
Have you ever loaded any code into microcontroller flash?
Martin
I am using codewarrior 10.6 version and the probe I used was USB A-B cable. We could flash program previously in that kit.
when you click OK in password required window, are you able to connect to the board?
Have you ever loaded any code, which modifies Shadow flash?
Martin
