FXOS8700CQ - undesired portrait/landscape interrupt on getting to ACTIVE mode
oferfreilich
I'm using FXOS8700CQ.
For most registers, the sensor must be changed to STANDBY mode for register writing.
I'm using the portrait/landscape interrupt.
Whenever I try to write to register by entering STANDBY mode I'm getting portrait/landscape interrupt on returning to ACTIVE mode.
Who can I prevent those interrupt ?
diegoadrian
Hello Ofer Freilich,
Thank you for writing.
This interrupt is important for the sensor, this is because the sensor needs it as an initial reference. For that reason it is impossible to prevent this interrupt.
I hope this information will be useful for you.
Diego.
