On the i.MX6SoloX, is it possible to output the 32 kHz RTC clock on the CCM_CLK2 pin?
John Kell
Solved! Go to Solution.
Hi John
options for CCM_CLK2 are given in sect.19.6.21 CCM Clock Output Source Register (CCM_CCOSR)
i.MX6SX Reference Manual and unfortunately seems there is no such option.
http://cache.freescale.com/files/32bit/doc/ref_manual/IMX6SXRM.pdf
Hi John
Hi Igor,
Thanks for your quick response and for pointing me to the register setting for CLKO2!
John
