I trying to get some information on how to create a Post-linker. I have understand that it is some kind of .bat file but I cant find any information about commands and syntax to be used. The help in CW just tells me to "see the appropriate Targeting manual" and I don't understand where to find it.
I'm using CodeWarrior Development Studio for S12(X) Version 5.1 , build 10221
/Bengt Andersson
Maybe this one helps:
Hi!
Already seen it and it is a great help if you have a .bat file and just want to run automatically when you build the project. What I look for are instructions on how to build a bat file from scratch, utilizing all available commands. Is it just common Windows command line commands or are there special commands only used in CW?
//Bengt
Hi Bengt,
it is just common Windows command line commands.
Erich
