I am confused about uSDHC init and polling mode setting.
It will stuck at CMD13
But when I use [step into] or [step over] to run, I can go through CMD13 successfully.
Why?
CMD25_Polling_MWBlock(psdinfo, blk_size,(uint32_t*)Sdram2SdcAddr);
It will have an CRC error. And after run CMD25, it didn't come back to tran state.
Why?
The code is now ALIGN_32_BYTE, and the SD card is now 8 byte align when did format settings.
Thanks a lot.
HONG Yang
2016.11.14
Original Attachment has been moved to: code.7z.zip
