General speaking, what is the default pin state of MPC5745R during reset before the software initialization code runs? In some security applications, it is especially required to have a well-defined default pin state of an output pin. So how is the pin state controlled?
take a look at excel file "IO Signal Description and Input Multiplexing Tables.xlsx" which is attached to the reference manual. Open the tab "IO Signal Table" and here you can find column "Pad State During Reset".
Lukas
