CodeWarrior 6.3 and Windows 7 64 bit
2,513 次查看
piergiovannigor
I wish to continue to use COdeWarrior 6.3, but it cannot be installed in a 64 bit machine.
Does exist a way to solve the problem ?
标签 (1)
标记 (1)
2 回复数
1,472 次查看
RodneyMcGee
I personally would not us XP mode.
Here is how I use CW 6.3 natively on 7 and 10 64-bit.
Install CodeWarrior Classic 6.3 Windows 10 & 7 64-bit HCS08 RS08 CFV1
Make sure to read the pinned comments and the video description.
1,472 次查看
Carlos_Mendoza
Hi Giovanni,
You could take a look to the following document that explains how to install and run Classic CodeWarrior products on 64-bit Windows 7 pc:
http://www.nxp.com/files/soft_dev_tools/doc/app_note/AN3936.pdf
But please notice that we highly recommend you to use the eclipse based CodeWarrior version:
CodeWarrior for Microcontrollers-Eclipse IDE|NXP
Hope it helps!
Carlos Mendoza
Technical Support Engineer
