Hi, I use i.MX6 Android KK4.4.2 BSP. I noticed the CPU run at 792MHz because I can see the following message when uboot boots up:
CPU: Freescale i.MX6 family TO1.5 at 792 MHz
Could anyone let me know how to change i.MX6 CPU frequency to 1GHz or 1.2GHz? Thanks!
Hi Frank,
Which i.mx6 processor are you using? Firstly, you need to confirm if it support 1.2Ghz work.
About how to change you can refer to the follow thread:
How can I change CPU frequency on i.MX6Q ?
https://community.nxp.com/message/662973
Hope this can help you. Any questions you can conact me.
Rita
Hi Rita,
Thanks for you reply! I can now change CPU frequency to 1GHz based on your info. I will study if it can be changed to 1.2GHz.
We have some i.MX6Q chips which support 1.2GHz.
