I want to use the Serial Receive line IDLE condition to call my parsing code after a data packet has been received and buffered. ie: IRQs to move each byte as received to buffer/que then when line becomes IDLE for 1 byte time, start parsing the packet. I do not want to poll Status Register 1 flags as this clears the flags. My source is in assembly.
There's nothing in the Reference Manual to say that won't work. Just make sure you carefully follow the instructions on how to clear the status bits in "Table 12-5. SCIxS1 Field Descriptions".
What difference does that make?
Tom
