i-jet/JTAGjet debugger errorswith TWR-K65F180M
grantcazinha
I'm having a problem using the IAR i-jet/JTAG debugger with my TWR-K65F180M.  Any help would be greatly appreciated.
Fri Oct 21, 2016 09:34:50: IAR Embedded Workbench 7.70.1 (armproc.dll)
Fri Oct 21, 2016 09:34:50: Loaded macro file: C:\Program Files (x86)\IAR Systems\Embedded Workbench 7.5\arm\config\debugger\NXP\K6x.dmac
Fri Oct 21, 2016 09:34:50: Loading the I-jet/JTAGjet driver
Fri Oct 21, 2016 09:34:52: Probe: Probe SW module ver 1.56
Fri Oct 21, 2016 09:34:52: Probe: Option: trace(Auto,size_limit=100%)
Fri Oct 21, 2016 09:34:52: Probe: I-jet-Trace SW module ver 1.61
Fri Oct 21, 2016 09:34:52: Probe: Found I-jet, SN=75317
Fri Oct 21, 2016 09:34:52: Probe: Opened connection to I-jet:75317
Fri Oct 21, 2016 09:34:52: Probe: USB connection verified (7512 packets/sec)
Fri Oct 21, 2016 09:34:52: Probe: I-jet, FW ver 4.2, HW Ver:A
Fri Oct 21, 2016 09:34:52: Probe: MIPI20 adapter detected
Fri Oct 21, 2016 09:34:52: Probe: Versions: JTAG=1.75 SWO=1.36 A2D=1.70 Stream=1.47 SigCom=2.41
Fri Oct 21, 2016 09:34:52: EARM v.4.4
Fri Oct 21, 2016 09:34:52: Emulation layer version 4.4
Fri Oct 21, 2016 09:34:52: Warning: JTAG clock cannot be automatically determined. Set the clock manually.
Fri Oct 21, 2016 09:34:52: A default 9.6MHz is used.
Fri Oct 21, 2016 09:34:52: Notification to core-connect hookup.
Fri Oct 21, 2016 09:34:52: CMD_INTERPRETER: failed
Fri Oct 21, 2016 09:34:52: C:\Program Files (x86)\IAR Systems\Embedded Workbench 7.5\arm\config\debugger\NXP\K6x.dmac(280,18): Error: Operation error.
Fri Oct 21, 2016 09:34:52: Error while calling macro execUserCoreConnect
Fri Oct 21, 2016 09:34:52: CPU status FAILED
Fri Oct 21, 2016 09:34:53: CMD_INTERPRETER: failed
Fri Oct 21, 2016 09:34:53: C:\Program Files (x86)\IAR Systems\Embedded Workbench 7.5\arm\config\debugger\NXP\K6x.dmac(280,18): Error: Operation error.
Fri Oct 21, 2016 09:34:53: Error while calling macro execUserCoreConnect
Fri Oct 21, 2016 09:34:54: CMD_INTERPRETER: failed
Fri Oct 21, 2016 09:34:54: C:\Program Files (x86)\IAR Systems\Embedded Workbench 7.5\arm\config\debugger\NXP\K6x.dmac(280,18): Error: Operation error.
Fri Oct 21, 2016 09:34:54: Error while calling macro execUserCoreConnect
Fri Oct 21, 2016 09:34:55: CMD_INTERPRETER: failed
Fri Oct 21, 2016 09:34:55: C:\Program Files (x86)\IAR Systems\Embedded Workbench 7.5\arm\config\debugger\NXP\K6x.dmac(280,18): Error: Operation error.
Fri Oct 21, 2016 09:34:55: Error while calling macro execUserCoreConnect
Fri Oct 21, 2016 09:34:55: LowLevelReset(system, delay 200)
Fri Oct 21, 2016 09:34:56: CMD_INTERPRETER: failed
Fri Oct 21, 2016 09:34:56: C:\Program Files (x86)\IAR Systems\Embedded Workbench 7.5\arm\config\debugger\NXP\K6x.dmac(280,18): Error: Operation error.
Fri Oct 21, 2016 09:34:56: Error while calling macro execUserCoreConnect
Fri Oct 21, 2016 09:34:58: Fatal error: Failed to connect to CPU Session aborted!
Fri Oct 21, 2016 09:34:58: IAR Embedded Workbench 7.70.1 (armproc.dll)
Fri Oct 21, 2016 09:34:59: Loading the I-jet/JTAGjet driver
Labels (2)
grantcazinha
A solution has been found.
You must update the bootloader with the JLink_OpenSDA_V2_2015-10-13.bin bootloader.  The default bootloader doesn't disable the MBED debugger when the JTAG is active unless you update.
