How to use CAN LPB(loop-back) mode in MPC5643L
caizhikai292
I want to test my CAN software in MPC5643L, so I want to use LPB mode to test the transmission and reception function. I wonder if there is an example of CAN LPB mode in MPC5643L. Thank you.
PetrS
If you want to test the internal loopback mode, just set the LPB bit in the Control Register in Freeze mode.
BR, Petr
