Hi Sir / Madam,
I am reading page location 0xF0 in NTAG 1K (with Pass through enabled and SRAM is mapped to this location), using another NFC device (this NFC device is connected to microcontroller through SPI) . I get an error message, 0x87, It seems a device time out message, which send back from NXP NTAG 1K. I am not able to check the description of this code in NTAG 1K datasheet. Would you please advice what does this mean ? what are solutions to this error message ?
Thanks in advance.
Cheers,
KF Choong#@@
from firmware code file : lib_PCD.h , by author MMY Application Team, it is interpret in send receive field status error, as #define PCD_ERRORCODE_NOTAGFOUND 0x87 . But I already have a NTAG 1K present, which can be read using handphone apps. Please advice. Thank you.
Cheers,
KF Choong
Hello KF Choong,
Do you still have this issue?
Please make sure that the Pass-through mode is enabled when trying to read from page 0xF0. Otherwise as shown in the datasheet the tag will respond with a NAK for that address range:
Also, I don't know what NFC reader or software framework you are using but give a check to the READ command format and the response times:
Regards!
Jorge Gonzalez
