I'm embarrassed to ask but I can't find how to access the internal temperature sensor of the K64.
The documentation says the PN diode is attached to one of the ADC pins but that's it.
Where can I find which ADC channel has access to the temperature sensor?
Thanks.
Joe
Solved! Go to Solution.
Details about particulars for any specific chip are in section 3 of the reference manuals. You should find a 'channel assignment' table in the analog section with this detail -- I expect you will find temp-sense on AD26.
I hope you have read my post about how to use this input.
Found it.
Sorry for the question.
