in the AFV141KH data sheet there is only the S-Parameters for the balanced configuration gate to gate and drain to drain.
The data sheet says that is possible to use this device in single ended and quadrature configuration.
Where is the single ended s-parameters referenced to ground?
Please create a Service request for this question.
