I need info about layout constraints between LPC4088 micro and an SDRAM dinamic RAM chip.
I would like to know how to trace address, controls and data lines, lines matching, impedence....
How can I get these info?
Could you suggest some application note or datasheet?
The memory I have to interface is an ISSI IS42S32800G working at about 133MHz.
Thank you very much
Hello Flavio,
Please check the below application notes.
http://www.nxp.com/documents/application_note/AN11508.pdf
http://www.nxp.com/documents/application_note/AN10935.pdf
Sol
