Hello all and sorry for the necroposting.
I'm currently building LTIB in a Ubuntu 10.4 platform. The process seems to go fairly well until I get an error similar to the one comented in this post. Indeed the error is this (I also attach the log):
[code]
+ [ -n ]
+ [ -f /home/guillermo/ltib/ltib-mcfv4m-20090730/config/.config ]
+ perl -ne print if m,^CONFIG_(?!PCF),
+ cat /home/guillermo/ltib/ltib-mcfv4m-20090730/config/.config
+ [ ! -f config/platform/mcfv4m/.config -a -f config/platform/mcfv4m/defconfig ]
+ [ -n ]
+ cd config/platform/mcfv4m
+ mconf main.lkc .config
sh: mconf: not found
Died at ./ltib line 2869.
traceback:
main::run_plat_config:2869
main::ltib_config:2844
main:re_build_checks:1445
main:557
Started: Wed Oct 6 17:00:20 2010
Ended: Wed Oct 6 17:00:21 2010
Elapsed: 1 seconds
Build Failed
Exiting on error or interrupt
[/code]
The LTIB version is: ltib-mcfv4m-20090730 that comes inside the Linux BSD image avaliable for download in Freescale's page. I still haven't defined a board but in my case it will be M54455EVB.
By the way I have been using this guides:
http://www.imxdev.org/wiki/index.php?title=All_Boards_LTIB
http://www.imxdev.org/wiki/index.php?title=ALL_Boards_ltib_config_ubuntu
May I'll be lucky enough to get someones advice?
Thanks.
