Hello, I am currently involving in a project which build a power evaluation tool for low-end embedded system. I got a LPCXpresso 54102 board. To do some validation of the power model I built, I want to know some detail information about the core in that board:
1. What is the process technology used for Cortex-M0+ and Cortex-M4 in the MCU (LPC54102)?
2. If I supply 3.3V to VDD on the LPC54102, what is the voltage that on-chip regulator will supply to core? Is it also 3.3V?
I don't know whether that information is confidential or not. If it is not, please give me some help.
Thank you in advanced
Solved! Go to Solution.
Hi Rizal,
---Using the 90 nm technology.
---We haven't the privilege to share the kind of confidential information and you should contact with the local sales for these information. Thanks for your understanding.
Ping
Hi Rizal,
Ping
