user@host:~$ sudo apt-get install util-linux ia32*
[sudo] password for user:
Reading package lists... Done
Building dependency tree
Reading state information... Done
util-linux is already the newest version.
Note, selecting ia32-crossover-xandros for regex 'ia32*'
Note, selecting ia32-crossover-pro for regex 'ia32*'
Note, selecting ia32-crossover-pro-demo for regex 'ia32*'
Note, selecting ia32-crossover-pro-xandros for regex 'ia32*'
Note, selecting ia32-libs for regex 'ia32*'
Note, selecting ia32-apt-get for regex 'ia32*'
Note, selecting ia32-crossover-standard-demo for regex 'ia32*'
Note, selecting ia32-crossover-standard for regex 'ia32*'
Note, selecting nvidia-glx-ia32 for regex 'ia32*'
Note, selecting ia32-sun-java6-plugin for regex 'ia32*'
Note, selecting ia32-libs-dev for regex 'ia32*'
Note, selecting ia32-crossover-demo-xandros for regex 'ia32*'
Note, selecting ia32-libs-gtk for regex 'ia32*'
Note, selecting ia32-libs instead of ia32-libs-gtk
Note, selecting grub-efi-ia32 for regex 'ia32*'
Note, selecting ia32-libs-sdl for regex 'ia32*'
Note, selecting ia32-libs instead of ia32-libs-sdl
Note, selecting ia32-sun-java6-bin for regex 'ia32*'
Note, selecting ia32-libs-openoffice.org for regex 'ia32*'
The following extra packages will be installed:
grub-efi-ia32 ia32-sun-java6-bin
Suggested packages:
efibootmgr
The following packages will be REMOVED:
grub-pc
The following NEW packages will be installed:
0 upgraded, 2 newly installed, 1 to remove and 0 not upgraded.
Need to get 29.9MB of archives.
After this operation, 87.9MB of additional disk space will be used.
Do you want to continue [Y/n]? n
Abort. |
