Content originally posted in LPCWare by JamesB on Sat Jun 11 12:24:39 MST 2011
if I set cr_startup_lpc13.c to use main() instead of Redlib's __main, my data section becomes only 4 bytes. I'm guessing the linker is eliminating it. What do I have to do to get it back? I don't have enough code space for Redlib's toupper() and the like (as shown by the map file) and don't use them anyway.
Thank you
James
