Content originally posted in LPCWare by Izzy Weird on Wed Aug 24 18:08:30 MST 2011
Quote: CodeRedSupport
There is no need to do any of the other things suggested by other posters. The quick way to stop the linker from trying to insert CRP is to :
- right-click on the project
- select Properties
- open the page C/C++Build, Settings
- Under MCU Linker, select Target
- uncheck "Enable Code Read Protect"
Thats it.
Thanks, that looks like solid advice, and that is where I would expect to find it. But what if there is no [U]"MCU Linker[/U]" under C/C++ Build - Settings. I see MCU C Compiler, MCU Assembler, and MCU Archiver, but no MCU Linker.
What Gives?:confused:
