Content originally posted in LPCWare by rob.mitrunen@avnet.com on Tue May 05 15:15:15 MST 2015
My customer asks:
We successfully programmed the LPC54102 to blink the LED but when we try to build a new code, it is gives us the error that " cannot find -llpc_board_lpcxpresso_54102" and "cannot find -llpc_chip_5410x" .
In the device manager, the LPC54102 Sensor Processing/Motion Solution (P/N OM13078) is listed under COM ports i.e. it is getting recognized and I have also updated the drivers.
I restarted my laptop and built it again , still getting the errors below:
Building target: pressuresensor.axf
Invoking: MCU Linker
arm-none-eabi-gcc -nostdlib -L"C:\Users\aban02\Documents\LPCXpresso_7.7.2_379\workspace\lpc_chip_5410x\libs" -L"C:\Users\aban02\Documents\LPCXpresso_7.7.2_379\workspace\CMSIS_DSPLIB_CM4\lib" -Xlinker -Map="pressuresensor.map" -Xlinker --gc-sections -mcpu=cortex-m0 -mfpu=fpv4-sp-d16 -mfloat-abi=softfp -mthumb -T "pressuresensor_Release.ld" -o "pressuresensor.axf" ./src/bmp280_support.o ./src/boot_multicore_slave.o ./src/cr_startup_lpc5410x.o ./src/crp.o ./src/pressuresensor.o ./src/sysinit.o -llpc_board_lpcxpresso_54102 -llpc_chip_5410x -lpower -lCMSIS_DSPLIB_CM4
c:/nxp/lpcxpresso_7.7.2_379/lpcxpresso/tools/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/bin/ld.exe: cannot find -llpc_board_lpcxpresso_54102
c:/nxp/lpcxpresso_7.7.2_379/lpcxpresso/tools/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/bin/ld.exe: cannot find -llpc_chip_5410x
collect2.exe: error: ld returned 1 exit status
make: *** [pressuresensor.axf] Error 1
Suggestions?
