maxe@schorschmobile:/opt/lpcxpresso_4.0.5_113/lpcxpresso/bin$ ./crt_emu_lpc11_13_nxp -g -2 -info-emu -wire=winusb Pc: ( 0) Reading remote configuration Ni: LPCXpresso Debug Driver v4.0 (Jun 27 2011 18:30:24) 1 Emulators available: 0. LPCLINK_1_1 LPC-Link Driver LINUX32 v1.1 (Code Red - LPCXpresso) maxe@schorschmobile:/opt/lpcxpresso_4.0.5_113/lpcxpresso/bin$ ./crt_emu_lpc11_13_nxp -info-target -pLPC1114/301 -wire=winusb -4 Ni: LPCXpresso Debug Driver v4.0 (Jun 27 2011 18:30:24) Nc: Looked for chip XML file in /opt/lpcxpresso_4.0.5_113/lpcxpresso/bin/LPC1114/301.xml Nc: Looked for vendor directory XML file in /opt/lpcxpresso_4.0.5_113/lpcxpresso/bin/nxp_directory.xml Nc: Found generic directory XML file in /opt/lpcxpresso_4.0.5_113/lpcxpresso/bin/crt_directory.xml |
glibc-*.i686 glib2-*.i686 xorg-lib-libXft-*.i686 gdk-pixbuf2-*.i686 gtk+2-*.x86_64 xorg-lib-libXtst-*.i686 |
# LPC-Link ACTION=="add|change", ATTR{idVendor}=="0471", ATTR{idProduct}=="df55", MODE="0660", GROUP="usb" ACTION=="add|change", ATTR{idVendor}=="1fc9", ATTR{idProduct}=="0009", MODE="0660", GROUP="usb" |
#!/bin/sh LPCLink_New_ID="0471:df55" LPCLink_Ready_ID="1fc9:0009" USB_LIST=$(lsusb) target_udev_info () { udevadm info -a -p $(udevadm info -q path -n /dev/bus/usb/${1}/${2}) | egrep "ATTR{(bMaxPower|manufacturer|product|serial)}" } LPCLink_New=$(echo "${USB_LIST}" | grep ${LPCLink_New_ID}) if [ -n "${LPCLink_New}" ]; then echo "LPCLink Bootless Found:\"${LPCLink_New}\"" LPCLink_New_BusNo=$(echo "${LPCLink_New}" | sed -n "s/^Bus[[:space:]]\([[:digit:]]\{3\}\).*/\1/p") LPCLink_New_DevNo=$(echo "${LPCLink_New}" | sed -n 's/^.*Device[[:space:]]\([[:digit:]]\{3\}\).*/\1/p') echo -e "\t Bus/Dev No:${LPCLink_New_BusNo}/${LPCLink_New_DevNo}" target_udev_info "${LPCLink_New_BusNo}" "${LPCLink_New_DevNo}" fi LPCLink_Ready=$(echo "${USB_LIST}" | grep ${LPCLink_Ready_ID}) if [ -n "${LPCLink_Ready}" ]; then echo "LPCLink Ready to Link Found:\"${LPCLink_Ready}\"" LPCLink_Ready_BusNo=$(echo "${LPCLink_Ready}" | sed -n "s/^Bus[[:space:]]\([[:digit:]]\{3\}\).*/\1/p") LPCLink_Ready_DevNo=$(echo "${LPCLink_Ready}" | sed -n "s/^.*Device[[:space:]]\([[:digit:]]\{3\}\).*/\1/p") echo -e "\t Bus/Dev No:${LPCLink_Ready_BusNo}/${LPCLink_Ready_DevNo}" target_udev_info "${LPCLink_Ready_BusNo}" "${LPCLink_Ready_DevNo}" fi |
#!/bin/sh # See http://support.code-red-tech.com/CodeRedWiki/CommandLineFlashProgramming dfu-util -d 0x471:0xdf55 -c 0 -t 2048 -R -D /usr/local/lpcxpresso_4.0.5_113/lpcxpresso/bin/LPCXpressoWIN.enc |
#!/bin/sh # See http://support.code-red-tech.com/CodeRedWiki/CommandLineFlashProgramming /usr/local/lpcxpresso_4.0.5_113/lpcxpresso/bin/crt_emu_lpc11_13_nxp -wire=winusb -pLPC1343 -flash-load-exec=${1} |
$ Boot_LPCLINK dfu-util - (C) 2005-2008 by Weston Schmidt, Harald Welte and OpenMoko Inc. This program is Free Software and has ABSOLUTELY NO WARRANTY dfu-util does currently only support DFU version 1.0 Filter on vendor = 0x0471 product = 0xdf55 Opening DFU USB device... ID 0471:df55 Claiming USB DFU Runtime Interface... Determining device status: state = dfuIDLE, status = 0 WARNING: Runtime device already in DFU state ?!? Found Runtime: [0x0471:0xdf55] devnum=0, cfg=1, intf=0, alt=0, name="UNDEFINED" Claiming USB DFU Interface... Setting Alternate Setting #0 ... Determining device status: state = dfuIDLE, status = 0 dfuIDLE, continuing No valid DFU suffix signature Warning: File has no DFU suffix bytes_per_hash=604 Copying data from PC to DFU device Starting download: [##################################################] finished! state(8) = dfuMANIFEST-WAIT-RESET, status(0) = No error condition is present Done! can't detach Resetting USB to switch back to runtime mode $ Load_LPC1343 blinky.axf Current dir:"/home/users/light-i/Devel/ARM/LPCXpresso/blinky/Release" Ni: LPCXpresso Debug Driver v4.0 (Jun 27 2011 18:30:24) Nc: Looked for chip XML file in /usr/local/lpcxpresso_4.0.5_113/lpcxpresso/bin/LPC1343.xml Nc: Looked for vendor directory XML file in /usr/local/lpcxpresso_4.0.5_113/lpcxpresso/bin/nxp_directory.xml Nc: Found generic directory XML file in /usr/local/lpcxpresso_4.0.5_113/lpcxpresso/bin/crt_directory.xml Xs: Xc: Nc: Emu(0): Conn&Reset. DpID: 2BA01477. Info: LPCLINK_1_1 Nc: SWD Frequency: 3000 KHz. RTCK: False. Vector catch: False. Nc: Packet delay: 0 Poll delay: 0. Nc: NXP: LPC1343 Part ID: 0x3D00002B Cr:v Registered license, download limit of 128K Nt: Loading ELF file 'blinky.axf' at location 00000000 Xs: Nc: nSRST assert (if available) Nc: Executing in user flash. |
root@schorschmobile:/home/maxe# lsusb | grep LPC Bus 003 Device 012: ID 0471:df55 Philips (or NXP) LPCXpresso LPC-Link |
root@schorschmobile:/home/maxe# dmesg | grep usb | tail -n 20 [ 133.503573] usb 3-3.3.1: USB disconnect, device number 9 [ 133.732587] usb 3-3.3.1: new low speed USB device number 10 using ohci_hcd [ 133.841583] usb 3-3.3.1: New USB device found, idVendor=046d, idProduct=c051 [ 133.841591] usb 3-3.3.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 133.841597] usb 3-3.3.1: Product: USB-PS/2 Optical Mouse [ 133.841604] usb 3-3.3.1: Manufacturer: Logitech [ 133.850297] input: Logitech USB-PS/2 Optical Mouse as /devices/pci0000:00/0000:00:12.0/usb3/3-3/3-3.3/3-3.3.1/3-3.3.1:1.0/input/input10 [ 133.850671] generic-usb 0003:046D:C051.0006: input,hidraw0: USB HID v1.10 Mouse [Logitech USB-PS/2 Optical Mouse] on usb-0000:00:12.0-3.3.1/input0 [ 263.716086] usb 3-3.3.1: USB disconnect, device number 10 [ 263.953082] usb 3-3.3.1: new low speed USB device number 11 using ohci_hcd [ 264.065082] usb 3-3.3.1: New USB device found, idVendor=046d, idProduct=c051 [ 264.065090] usb 3-3.3.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 264.065096] usb 3-3.3.1: Product: USB-PS/2 Optical Mouse [ 264.065102] usb 3-3.3.1: Manufacturer: Logitech [ 264.073793] input: Logitech USB-PS/2 Optical Mouse as /devices/pci0000:00/0000:00:12.0/usb3/3-3/3-3.3/3-3.3.1/3-3.3.1:1.0/input/input11 [ 264.074158] generic-usb 0003:046D:C051.0007: input,hidraw0: USB HID v1.10 Mouse [Logitech USB-PS/2 Optical Mouse] on usb-0000:00:12.0-3.3.1/input0 [11887.388619] usb 3-3.3.3: new full speed USB device number 12 using ohci_hcd [11887.487012] usb 3-3.3.3: not running at top speed; connect to a high speed hub [11887.493560] usb 3-3.3.3: New USB device found, idVendor=0471, idProduct=df55 [11887.493570] usb 3-3.3.3: New USB device strings: Mfr=0, Product=0, SerialNumber=0 |
root@schorschmobile:/home/maxe# lsusb Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 002 Device 002: ID 1b1c:1928 Bus 003 Device 002: ID 058f:6254 Alcor Micro Corp. USB Hub Bus 003 Device 003: ID 058f:9254 Alcor Micro Corp. Hub Bus 003 Device 011: ID 046d:c051 Logitech, Inc. G3 (MX518) Optical Mouse Bus 003 Device 006: ID 046d:c30a Logitech, Inc. iTouch Composite Bus 003 Device 007: ID 041e:3020 Creative Technology, Ltd SoundBlaster Audigy 2 NX Bus 003 Device 013: ID 1fc9:0009 NXP Semiconductors |
root@schorschmobile:/home/maxe# dmesg | grep usb | tail -n 20 [ 133.850671] generic-usb 0003:046D:C051.0006: input,hidraw0: USB HID v1.10 Mouse [Logitech USB-PS/2 Optical Mouse] on usb-0000:00:12.0-3.3.1/input0 [ 263.716086] usb 3-3.3.1: USB disconnect, device number 10 [ 263.953082] usb 3-3.3.1: new low speed USB device number 11 using ohci_hcd [ 264.065082] usb 3-3.3.1: New USB device found, idVendor=046d, idProduct=c051 [ 264.065090] usb 3-3.3.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 264.065096] usb 3-3.3.1: Product: USB-PS/2 Optical Mouse [ 264.065102] usb 3-3.3.1: Manufacturer: Logitech [ 264.073793] input: Logitech USB-PS/2 Optical Mouse as /devices/pci0000:00/0000:00:12.0/usb3/3-3/3-3.3/3-3.3.1/3-3.3.1:1.0/input/input11 [ 264.074158] generic-usb 0003:046D:C051.0007: input,hidraw0: USB HID v1.10 Mouse [Logitech USB-PS/2 Optical Mouse] on usb-0000:00:12.0-3.3.1/input0 [11887.388619] usb 3-3.3.3: new full speed USB device number 12 using ohci_hcd [11887.487012] usb 3-3.3.3: not running at top speed; connect to a high speed hub [11887.493560] usb 3-3.3.3: New USB device found, idVendor=0471, idProduct=df55 [11887.493570] usb 3-3.3.3: New USB device strings: Mfr=0, Product=0, SerialNumber=0 [12319.094518] usb 3-3.3.3: USB disconnect, device number 12 [12319.596525] usb 3-3.3.3: new full speed USB device number 13 using ohci_hcd [12319.710598] usb 3-3.3.3: New USB device found, idVendor=1fc9, idProduct=0009 [12319.710603] usb 3-3.3.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [12319.710606] usb 3-3.3.3: Product: LPC-Link Probe v1.1 [12319.710608] usb 3-3.3.3: Manufacturer: Code Red Technologies [12319.710610] usb 3-3.3.3: SerialNumber: T1S6RGRIA |
$ lsusb | grep LPC Bus 002 Device 003: ID 0471:df55 Philips (or NXP) LPCXpresso LPC-Link |
