Content originally posted in LPCWare by charchar on Wed Mar 25 16:39:02 MST 2015
I'm playing with heap overflow checking mechanism by defining the function __check_heap_overflow. This function gets called every time the heap grows past a 4K boundary. I'm guessing because the heap advances 4K at a time.... Is there a way to tweak this value? It results in up to 4K of memory being unallocatable (worst case) when the heap reaches its limit.
thanks
