Content originally posted in LPCWare by richas on Tue Feb 16 18:21:31 MST 2010If, I disconnect the LPC-Link while the LPCxpresso IDE is open I cannot ever connect to the debugger again. I have to restart the computer! (winxp)I have:reinstalled LPCxpressouninstalled/reinstalled the device under device managerIf I close the IDE and THEN disconnect/reconnect the debugger then, after restarting the IDE I can still connect. I am doing this to reset the board so I can run code without starting the debugger.Has anyone else experienced this?RichOriginal Attachment has been moved to: 1100124_extra%20info.txt.zip
