Content originally posted in LPCWare by manishd on Fri Oct 07 09:53:10 MST 2011
I would like to configure the can_onchip example for a CAN bitrate of 500kbps instead of the 125kbps default. Can this be accomplished simply by changing the values in the ClkInitTable?
// 500kbps
uint32_t ClkInitTable[2] = {
0x00000005UL, // CANCLKDIV 5
0x00002301UL // CAN_BTR 0x2301
//instead of 125kbps
0x00000000UL, // CANCLKDIV 5
0x00001C57UL // CAN_BTR 0x2301
Calculating the bit time quanta seems a little :(
