Content originally posted in LPCWare by zapta on Fri Aug 08 20:20:00 MST 2014
Yes, this does work, thanks!
Is there a way to make it a single click operation? (save modified workspace files, build current project, flash and restart target). This is what I expect the Run button to do.
Also, does the Run button work for you?
