Content originally posted in LPCWare by jeshwanth on Tue May 06 23:01:40 MST 2014
I am using lpc1768 with LPCXpresso IDE. After adding USB Mass storage driver I am getting below Error.
c:/code_red/redsuitenxp_5.2.6_2137/redsuite/tools/bin/../lib/gcc/arm-none-eabi/4.6.2/../../../../arm-none-eabi/bin/ld.exe: abc.axf section `.bss' will not fit in region `RamLoc32'
c:/code_red/redsuitenxp_5.2.6_2137/redsuite/tools/bin/../lib/gcc/arm-none-eabi/4.6.2/../../../../arm-none-eabi/bin/ld.exe: region `RamLoc32' overflowed by 4988 bytes
collect2: ld returned 1 exit status
My question is, the USB Massstorage needs to put in RamAHB32 (If I understood correctly), but why on RamLoc32 ?
If my understanding is right, How to load USB related stuffs to RamAHB32 instead RamLoc32 ?
