Content originally posted in LPCWare by Microembedded on Fri May 09 03:06:09 MST 2014
I had purchased a LPCXpresso board and CLEV663B board from NXP.I am able to read the value in MiFARE card in the console through USB.Now the question is how to read the same value in my hyperterminal. What changes should i make in the firmware/hardware to make it possible?The sample code i am using is RC663-LPC1227-Classic.Kindly advice. Thank you.
