I am seeing a similar error message "No source available for "0x1fff0040" as soon as I download my code. I get this error even after replacing all code in main() with while(1).
This happens with using both LPC-Link1 and 2 debuggers, along with LPCXpresso v8.2.2.
The same code works on another board that I have, so it should not be a problem. Also, on this board, I am able to run some other test code, so the controller is not inaccessible or hanged.
Please let me know what may be the problem.
Thanks and Regards.
