1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
#include "sys_config.h"
//#include "LPC17xx.h"
//#include "system_LPC17xx.h"
#include "board.h"
#include "arch\lpc_arch.h"
#ifndef _WINDOWS
#include "BSP.h"
#endif
//#include "GUI.h"
#include "string.h"
//Interruption du QEI
void QEI_IRQHandler()
Board_LED_Set(0,Board_LED_Test(0));
LPC_QEI->CLR=0;
static void prvSetupHardware(void)
/* LED0 is used for the link status, on = PHY cable detected */
Board_Init();
//Définir la broche P1.23 comme point B du QEI
Chip_GPIO_WriteDirBit(LPC_GPIO, 0x1, 0x14, false);
Chip_IOCON_PinMux(LPC_IOCON,0x1,0x14, IOCON_MODE_PULLDOWN ,IOCON_FUNC1);
Chip_GPIO_WriteDirBit(LPC_GPIO, 0x1, 0x17, false);
Chip_IOCON_PinMux(LPC_IOCON,0x1,0x17, IOCON_MODE_PULLDOWN ,IOCON_FUNC1);
Chip_GPIO_WriteDirBit(LPC_GPIO, 0x1, 0x18, false);
Chip_IOCON_PinMux(LPC_IOCON,0x1,0x18, IOCON_MODE_PULLDOWN ,IOCON_FUNC1);
//Activer l'horloge du QEI
Chip_Clock_EnablePeriphClock(SYSCTL_CLOCK_QEI);
Chip_Clock_SetPCLKDiv(SYSCTL_PCLK_QEI, SYSCTL_CLKDIV_4);
//Config du QEI en comptage simple sur la voie B
LPC_QEI->CONF=6;
//Définition du calcul de vitesse
LPC_QEI->LOAD=(uint32_t)3000000;
LPC_QEI->MAXPOS=250000;
//Filtrage du QEI
LPC_QEI->FILTERPHB=10;
//Reset du QEI
LPC_QEI->CON=15;
//Préparation de l'interruption de la vitesse
//Autorisation de l'interruption uniquement sur overflow timer vitesse
LPC_QEI->IES=1;
NVIC_SetPriority((IRQn_Type) QEI_IRQn, 2);
NVIC_EnableIRQ((IRQn_Type) QEI_IRQn);
* Public functions
* @brief main routine for example_lwip_tcpecho_sa_17xx40xx
* @return Function should not exit.
int main(void)
char test[20]={'d','e','b','u','t','\n','\0'};
prvSetupHardware();
//Test de l'UART
Board_UARTPutSTR(test);
//MainTask();
while(1) {
msDelay(1000);
sprintf(test,"INTSTAT : %u\n",LPC_QEI->INTSTAT);
sprintf(test,"VEL : %u\n",LPC_QEI->CAP);
sprintf(test,"IE : %d\n",LPC_QEI->IE);
Board_UARTPutChar('\n');
