Content originally posted in LPCWare by qqqyounng on Wed Jun 03 22:31:23 MST 2015Hi,I am using Mr.Diego Mariano López customers' Software USB1.1 stack.http://www.ucontrol.com.ar/forosmf/programacion-en-asm/inalambrico-usb-12f675/It was transplanted into LPC810.I will attach a HID-Serial firmware and Loopback host.This is not a CDC.[img]http://hp.vector.co.jp/authors/VA058115/common/USB810.jpg[/img][img]http://hp.vector.co.jp/authors/VA058115/common/LoopBackHost.jpg[/img]1.To change the baud rate from the host.2.Manipulating the communication conditions from the host. (data length, parity, stop bits)3.2 Output ports (DTR,RTS)Clock:12MHz intRegister:R0-R12Code:$0000 to $0D00RAM:64bytesBest regards,DANOriginal Attachment has been moved to: USB810_src_HIDserial_int12MHz_r3.zip
