Content originally posted in LPCWare by Mokler on Mon May 05 07:58:51 MST 2014
I have a board lpcexpresso. With LPC11U14
After connecting some LED to pins I can not flash it anymore with the given error
Flash driver "UnInit" return code: 0x1
15: Target error from Commit Flash write
Flash verify operation failed.
Is there anyway I can do a hard reset? Or erase the flash?
Thank you.
