on my lpc11u24/301 microcontroller but after connecting the usb cable and visualizing correctly the virtual com i can't open the port with a serial data logger or any other software.
i imported the entire folder containing the cdc usb rom example and the build happens to be correct so it is the debugging.
what's wrong with my virtual com? i use windows xp and the driver provided by nxp support for letting the virtual com appears.
