Content originally posted in LPCWare by askksa12543 on Mon Nov 17 10:12:20 MST 2014
I am using an NGX Xplorer 4337 board for a school project and am having difficulty with setting the ADC up. When I try to setup the memory pointer for the ADC it tells me LPC_ADC undeclared (first use in this function). I am trying to define it like I did with the PWM.
#define ADCLPC_ADC
#define ADC_CLOCKADC_CLOCK_SETUP
I'm not sure why this wouldn't work the same as
#define SCT_PWM LPC_SCT
when setting up the pulse width motor control. There isn't an ADC example that I can find to determine if I am setting up the wrong pointer. Please help. Thanks,
Kevin Anderson
