uint32_t sdram_test( void ) { volatile uint32_t *wr_ptr; volatile uint16_t *short_wr_ptr; uint32_t data; uint32_t i, j; uint32_t uiGood = 0; uint32_t uiBad = 0; wr_ptr = (uint32_t *)SDRAM_BASE; short_wr_ptr = (uint16_t *)wr_ptr; /* 16 bit write */ for (i = 0; i < SDRAM_SIZE/0x40000; i++) { for (j = 0; j < 0x100; j++) { *short_wr_ptr++ = (i + j) & 0xFFFF; *short_wr_ptr++ = ((i + j) + 1) & 0xFFFF; } } /* Verifying */ wr_ptr = (uint32_t *)SDRAM_BASE; for (i = 0; i < SDRAM_SIZE/0x40000; i++) { for (j = 0; j < 0x100; j++) { data = *wr_ptr; if (data != (((((i + j) + 1) & 0xFFFF) << 16) | ((i + j) & 0xFFFF))) { uiBad++; //return 0x0; } else uiGood++; wr_ptr++; } } return 0x1; } |
uint32_t sdram_test2(void) { uint32_t *ramdata; uint32_t uiGood = 0; uint32_t uiBad = 0; uint32_t i = 0; ramdata = (uint32_t *)SDRAM_BASE; for(i=0;i < SDRAM_SIZE/4; i++){ *ramdata = i; ramdata++; } ramdata = (uint32_t *)SDRAM_BASE; for(i=0;i < SDRAM_SIZE/4; i++){ if(*ramdata != i) { uiBad++; } else uiGood++; ramdata++; } return 1; } |
uint32_t sdram_init (void) { uint32_t temp; uint32_t emcclk; /* Select EMC clock-out */ LPC_SCU->SFSCLK_0 = (MD_PLN | MD_EZI | MD_ZI | MD_EHS); LPC_SCU->SFSCLK_1 = (MD_PLN | MD_EZI | MD_ZI | MD_EHS); LPC_SCU->SFSCLK_2 = (MD_PLN | MD_EZI | MD_ZI | MD_EHS); LPC_SCU->SFSCLK_3 = (MD_PLN | MD_EZI | MD_ZI | MD_EHS); /* Setup EMC delays */ LPC_SCU->EMCDELAYCLK = ((CLK0_DELAY) | (CLK0_DELAY << 4) | (CLK0_DELAY << 8) | (CLK0_DELAY << 12)); /* EMC clock is half of CGU_BASE_M4 if CGU_BASE_M4 is >104 MHz */ long SystemCoreClock = 204000000; if (SystemCoreClock > 104000000) { LPC_CCU1->CLK_M4_EMCDIV_CFG = ( (1<<0) | (1<<1) | (1<<2) | (1<<5) ); LPC_CREG->CREG6 |= (1<<16); emcclk = SystemCoreClock / 2; } else { LPC_CCU1->CLK_M4_EMCDIV_CFG = ( (1<<0) | (1<<1) | (1<<2) | (0<<5) ); LPC_CREG->CREG6 &= ~(1<<16); emcclk = SystemCoreClock; } LPC_EMC->CONTROL = 0x00000001; LPC_EMC->CONFIG = 0x00000000; LPC_EMC->DYNAMICCONFIG0 = 0<<14 | 1<<12 | 1<<9 | 1<<7; /* 64Mb, 1Mx16, 4 banks, row=12, column=8 */ LPC_EMC->DYNAMICRASCAS0 = 0x00000303; /* 3 RAS, 3 CAS latency */ LPC_EMC->DYNAMICREADCONFIG = 0x00000001; /* Command delayed strategy, using EMCCLKDELAY */ LPC_EMC->DYNAMICRP = NS2CLK(emcclk, 20); //tRP LPC_EMC->DYNAMICRAS = NS2CLK(emcclk, 45); //tRAS LPC_EMC->DYNAMICSREX = NS2CLK(emcclk, 80); //tXSR LPC_EMC->DYNAMICAPR = 0x00000005; LPC_EMC->DYNAMICDAL = NS2CLK(emcclk, 40); //tDAL LPC_EMC->DYNAMICWR = NS2CLK(emcclk, 15); //tDPL LPC_EMC->DYNAMICRC = NS2CLK(emcclk, 68); //tRC LPC_EMC->DYNAMICRFC = NS2CLK(emcclk, 80); //tRFC LPC_EMC->DYNAMICXSR = NS2CLK(emcclk, 80); //tXSR LPC_EMC->DYNAMICRRD = NS2CLK(emcclk, 15); //tRRD LPC_EMC->DYNAMICMRD = 0x00000002; chThdSleepMicroseconds(100); /* wait 100us */ LPC_EMC->DYNAMICCONTROL = 0x00000183; /* Issue NOP command */ chThdSleepMicroseconds(200); /* wait 200us */ LPC_EMC->DYNAMICCONTROL = 0x00000103; /* Issue PALL command */ LPC_EMC->DYNAMICREFRESH = 2; /* ( n * 16 ) -> 32 clock cycles */ chThdSleepMicroseconds(200); /* wait 200us */ /* (64ms / 4096 row) */ LPC_EMC->DYNAMICREFRESH = NS2CLK(emcclk, 64000000 / 4096)/16; /* ( n * 16 ) */ LPC_EMC->DYNAMICCONTROL = 0x00000083; /* Issue MODE command */ temp = *((volatile uint32_t *)(SDRAM_BASE | (3<<4| 2)<<(9+2+2))); /* 4 burst, 3 CAS latency */ temp = temp; LPC_EMC->DYNAMICCONTROL = 0x00000000; /* Issue NORMAL command */ //[re]enable buffers LPC_EMC->DYNAMICCONFIG0 |= 1<<19; return 1; } |
temp = *((volatile uint32_t *)(SDRAM_BASE | (3<<4| 2)<<(9+2+2))); /* 4 burst, 3 CAS latency */ temp = temp; |
*((volatile uint32_t *)(SDRAM_BASE | ((3 | (3 << 4)) << (8 + 1)))); |
