Content originally posted in LPCWare by MOHAMMAD BIYABANI on Tue Apr 02 22:14:41 MST 2013
Now i am working on Linux ubuntu system with 11.10 ubuntu and kernel version Linux-3.0.10 version. I was downloaded Net-snmp-5.4.3 package from NET_SNMP Website and then I have compiled Net-snmp-5.4.3 using below procedure. But i am not able to identify next step for to check my client (i am using LPC3250 board) that means how to execute compiled SNMP files on my board. I have got the .o,.c,.lo,.dsp files but not .exe or .bin files after compilation. Please help me...
The procedure that i was followed to compile the NET-SNMP with output
1. Go to the contained file of NET-SNMP like below
root@mohan:/home/mohan/net-snmp-5.4.4#
2. Run ./configure
root@mohan:/home/mohan/net-snmp-5.4.4# ./configure
3. Perform Make operation
root@mohan:/home/mohan/net-snmp-5.4.4# make ARCH=arm CROSS_COMPILE=arm-linux-
making man page alias register_app_premib_handler.3 -> read_config APIs
making man page alias register_config_handler.3 -> read_config APIs
making man page alias register_mib_handlers.3 -> read_config APIs
making man page alias register_premib_handler.3 -> read_config APIs
making man page alias unregister_app_config_handler.3 -> read_config APIs
making man page alias unregister_config_handler.3 -> read_config APIs
making man page alias snmp_alarm_register.3 -> snmp_alarm APIs
making man page alias snmp_alarm_register_hr.3 -> snmp_alarm APIs
making man page alias snmp_alarm_unregister.3 -> snmp_alarm APIs
making man page alias fprint_description.3 -> snmp_set_save_descriptions APIs
making man page alias fprint_objid.3 -> snmp_set_save_descriptions APIs
making man page alias fprint_value.3 -> snmp_set_save_descriptions APIs
making man page alias fprint_variable.3 -> snmp_set_save_descriptions APIs
making man page alias snprint_objid.3 -> snmp_set_save_descriptions APIs
making man page alias snprint_value.3 -> snmp_set_save_descriptions APIs
making man page alias snprint_variable.3 -> snmp_set_save_descriptions APIs
making man page alias sprint_realloc_objid.3 -> snmp_set_save_descriptions APIs
making man page alias sprint_realloc_value.3 -> snmp_set_save_descriptions APIs
making man page alias sprint_realloc_variable.3 -> snmp_set_save_descriptions APIs
making man page alias send_easy_trap.3 -> snmp_trap APIs
making man page alias send_trap_vars.3 -> snmp_trap APIs
making man page alias send_v2trap.3 -> snmp_trap APIs
make[1]: Leaving directory `/home/mohan/net-snmp-5.4.4/man'
making all in /home/mohan/net-snmp-5.4.4/local
make[1]: Entering directory `/home/mohan/net-snmp-5.4.4/local'
/bin/sed -f ../sedscript ./snmpcheck.def > snmpcheck
if test "x/usr/bin/perl" != "x" ; then \
/usr/bin/perl -p -e 's%^#!.*/perl.*%#!/usr/bin/perl%' snmpcheck > snmpcheck.made ; \
else \
touch snmpcheck.made ; \
fi
/usr/bin/perl -p -e 's%^#!.*/perl.*%#!/usr/bin/perl%' ./tkmib > tkmib.made; \
else \
touch tkmib.made; \
fi
/usr/bin/perl -p -e 's%^#!.*/perl.*%#!/usr/bin/perl%;s#/usr/local/share/snmp#/usr/local/share/snmp#;' ./mib2c > mib2c.made; \
else \
touch mib2c.made; \
fi
/usr/bin/perl -p -e 's%^#!.*/perl.*%#!/usr/bin/perl%' ./fixproc > fixproc.made; \
else \
touch fixproc.made; \
fi
/usr/bin/perl -p -e 's%^#!.*/perl.*%#!/usr/bin/perl%' ./ipf-mod.pl > ipf-mod.pl.made; \
else \
touch ipf-mod.pl.made; \
fi
/usr/bin/perl -p -e 's%^#!.*/perl.*%#!/usr/bin/perl%; s#/usr/local/share#/usr/local/share#g; s#/usr/local/etc/snmp#/usr/local/etc/snmp#g; s#/var/net-snmp#/var/net-snmp#g' ./snmpconf > snmpconf.made; \
else \
touch snmpconf.made; \
fi
/usr/bin/perl -p -e 's%^#!.*/perl.*%#!/usr/bin/perl%; s#/usr/local/share#/usr/local/share#g; s#/usr/local/etc/snmp##g' ./traptoemail > traptoemail.made; \
else \
touch traptoemail.made; \
fi
make[1]: Leaving directory `/home/mohan/net-snmp-5.4.4/local'
making all in /home/mohan/net-snmp-5.4.4/mibs
make[1]: Entering directory `/home/mohan/net-snmp-5.4.4/mibs'
make[1]: Leaving directory `/home/mohan/net-snmp-5.4.4/mibs'
chmod a+x net-snmp-config
touch net-snmp-config-x
Checking if your kit is complete...
Looks good
Warning: -L../../snmplib/.libs changed to -L/home/mohan/net-snmp-5.4.4/perl/default_store/../../snmplib/.libs
Warning: -L../../snmplib/ changed to -L/home/mohan/net-snmp-5.4.4/perl/default_store/../../snmplib/
Writing Makefile for NetSNMP::default_store
Looks good
Warning: -L../../snmplib/.libs changed to -L/home/mohan/net-snmp-5.4.4/perl/ASN/../../snmplib/.libs
Warning: -L../../snmplib/ changed to -L/home/mohan/net-snmp-5.4.4/perl/ASN/../../snmplib/
Writing Makefile for NetSNMP::ASN
Looks good
Warning: -L../../snmplib/.libs changed to -L/home/mohan/net-snmp-5.4.4/perl/OID/../../snmplib/.libs
Warning: -L../../snmplib/ changed to -L/home/mohan/net-snmp-5.4.4/perl/OID/../../snmplib/
Writing Makefile for NetSNMP::OID
Looks good
Warning: -L../../snmplib/.libs changed to -L/home/mohan/net-snmp-5.4.4/perl/agent/../../snmplib/.libs
Warning: -L../../snmplib/ changed to -L/home/mohan/net-snmp-5.4.4/perl/agent/../../snmplib/
Warning: -L../../agent/.libs changed to -L/home/mohan/net-snmp-5.4.4/perl/agent/../../agent/.libs
Warning: -L../../agent/ changed to -L/home/mohan/net-snmp-5.4.4/perl/agent/../../agent/
Warning: -L../../agent/helpers/.libs changed to -L/home/mohan/net-snmp-5.4.4/perl/agent/../../agent/helpers/.libs
Warning: -L../../agent/helpers/ changed to -L/home/mohan/net-snmp-5.4.4/perl/agent/../../agent/helpers/
Writing Makefile for NetSNMP::agent::Support
Warning: -L../../../snmplib/.libs changed to -L/home/mohan/net-snmp-5.4.4/perl/agent/default_store/../../../snmplib/.libs
Warning: -L../../../snmplib/ changed to -L/home/mohan/net-snmp-5.4.4/perl/agent/default_store/../../../snmplib/
Writing Makefile for NetSNMP::agent::default_store
Looks good
Warning: -L../../snmplib/.libs changed to -L/home/mohan/net-snmp-5.4.4/perl/SNMP/../../snmplib/.libs
Warning: -L../../snmplib/ changed to -L/home/mohan/net-snmp-5.4.4/perl/SNMP/../../snmplib/
Writing Makefile for SNMP
Looks good
Warning: prerequisite NetSNMP::OID 5.02 not found.
Warning: -L../../apps/.libs changed to -L/home/mohan/net-snmp-5.4.4/perl/TrapReceiver/../../apps/.libs
Warning: -L../../apps changed to -L/home/mohan/net-snmp-5.4.4/perl/TrapReceiver/../../apps
Warning: -L../../agent/.libs changed to -L/home/mohan/net-snmp-5.4.4/perl/TrapReceiver/../../agent/.libs
Warning: -L../../agent changed to -L/home/mohan/net-snmp-5.4.4/perl/TrapReceiver/../../agent
Warning: -L../../agent/helpers/.libs changed to -L/home/mohan/net-snmp-5.4.4/perl/TrapReceiver/../../agent/helpers/.libs
Warning: -L../../agent/helpers changed to -L/home/mohan/net-snmp-5.4.4/perl/TrapReceiver/../../agent/helpers
Warning: -L../../snmplib/.libs changed to -L/home/mohan/net-snmp-5.4.4/perl/TrapReceiver/../../snmplib/.libs
Warning: -L../../snmplib changed to -L/home/mohan/net-snmp-5.4.4/perl/TrapReceiver/../../snmplib
Writing Makefile for NetSNMP::TrapReceiver
Writing Makefile for Bundle::NetSNMP
make[1]: Entering directory `/home/mohan/net-snmp-5.4.4/perl'
cp Makefile.subs.pl blib/lib/Bundle/Makefile.subs.pl
make[2]: Entering directory `/home/mohan/net-snmp-5.4.4/perl/default_store'
cp default_store.pm ../blib/lib/NetSNMP/default_store.pm
AutoSplitting ../blib/lib/NetSNMP/default_store.pm (../blib/lib/auto/NetSNMP/default_store)
/usr/bin/perl /usr/share/perl/5.12.4/ExtUtils/xsubpp -prototypes -typemap /usr/share/perl/5.12/ExtUtils/typemap -typemap typemap default_store.xs > default_store.xsc && mv default_store.xsc default_store.c
cc -c -I../../include -fno-strict-aliasing -g -O2 -Ulinux -Dlinux=linux -D_REENTRANT -D_GNU_SOURCE -DDEBIAN -fno-strict-aliasing -pipe -fstack-protector -I/usr/local/include -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64 -I/usr/lib/perl/5.12/CORE -I. -I/usr/local/include -D_REENTRANT -D_GNU_SOURCE -DDEBIAN -fno-strict-aliasing -pipe -fstack-protector -I/usr/local/include -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64 -O2 -g -DVERSION=\"5.0404\" -DXS_VERSION=\"5.0404\" -fPIC "-I/usr/lib/perl/5.12/CORE" default_store.c
Running Mkbootstrap for NetSNMP::default_store ()
chmod 644 default_store.bs
rm -f ../blib/arch/auto/NetSNMP/default_store/default_store.so
LD_RUN_PATH="/usr/local/lib:/usr/lib/perl/5.12/CORE" cc -shared -O2 -g -L/usr/local/lib -fstack-protector default_store.o -o ../blib/arch/auto/NetSNMP/default_store/default_store.so \
-L/home/mohan/net-snmp-5.4.4/perl/default_store/../../snmplib/.libs -L/home/mohan/net-snmp-5.4.4/perl/default_store/../../snmplib -L/usr/local/lib -lnetsnmp -lcrypto \
chmod 755 ../blib/arch/auto/NetSNMP/default_store/default_store.so
cp default_store.bs ../blib/arch/auto/NetSNMP/default_store/default_store.bs
chmod 644 ../blib/arch/auto/NetSNMP/default_store/default_store.bs
Manifying ../blib/man3/NetSNMP::default_store.3pm
make[2]: Leaving directory `/home/mohan/net-snmp-5.4.4/perl/default_store'
make[2]: Entering directory `/home/mohan/net-snmp-5.4.4/perl/ASN'
cp ASN.pm ../blib/lib/NetSNMP/ASN.pm
AutoSplitting ../blib/lib/NetSNMP/ASN.pm (../blib/lib/auto/NetSNMP/ASN)
/usr/bin/perl /usr/share/perl/5.12.4/ExtUtils/xsubpp -prototypes -typemap /usr/share/perl/5.12/ExtUtils/typemap ASN.xs > ASN.xsc && mv ASN.xsc ASN.c
cc -c -I../../include -fno-strict-aliasing -g -O2 -Ulinux -Dlinux=linux -D_REENTRANT -D_GNU_SOURCE -DDEBIAN -fno-strict-aliasing -pipe -fstack-protector -I/usr/local/include -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64 -I/usr/lib/perl/5.12/CORE -I. -I/usr/local/include -D_REENTRANT -D_GNU_SOURCE -DDEBIAN -fno-strict-aliasing -pipe -fstack-protector -I/usr/local/include -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64 -O2 -g -DVERSION=\"5.0404\" -DXS_VERSION=\"5.0404\" -fPIC "-I/usr/lib/perl/5.12/CORE" ASN.c
Running Mkbootstrap for NetSNMP::ASN ()
chmod 644 ASN.bs
rm -f ../blib/arch/auto/NetSNMP/ASN/ASN.so
LD_RUN_PATH="/usr/local/lib:/usr/lib/perl/5.12/CORE" cc -shared -O2 -g -L/usr/local/lib -fstack-protector ASN.o -o ../blib/arch/auto/NetSNMP/ASN/ASN.so \
-L/home/mohan/net-snmp-5.4.4/perl/ASN/../../snmplib/.libs -L/home/mohan/net-snmp-5.4.4/perl/ASN/../../snmplib -L/usr/local/lib -lnetsnmp -lcrypto \
chmod 755 ../blib/arch/auto/NetSNMP/ASN/ASN.so
cp ASN.bs ../blib/arch/auto/NetSNMP/ASN/ASN.bs
chmod 644 ../blib/arch/auto/NetSNMP/ASN/ASN.bs
Manifying ../blib/man3/NetSNMP::ASN.3pm
make[2]: Leaving directory `/home/mohan/net-snmp-5.4.4/perl/ASN'
make[2]: Entering directory `/home/mohan/net-snmp-5.4.4/perl/OID'
cp OID.pm ../blib/lib/NetSNMP/OID.pm
AutoSplitting ../blib/lib/NetSNMP/OID.pm (../blib/lib/auto/NetSNMP/OID)
/usr/bin/perl /usr/share/perl/5.12.4/ExtUtils/xsubpp -prototypes -typemap /usr/share/perl/5.12/ExtUtils/typemap -typemap typemap OID.xs > OID.xsc && mv OID.xsc OID.c
cc -c -I../../include -fno-strict-aliasing -g -O2 -Ulinux -Dlinux=linux -D_REENTRANT -D_GNU_SOURCE -DDEBIAN -fno-strict-aliasing -pipe -fstack-protector -I/usr/local/include -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64 -I/usr/lib/perl/5.12/CORE -I. -I/usr/local/include -D_REENTRANT -D_GNU_SOURCE -DDEBIAN -fno-strict-aliasing -pipe -fstack-protector -I/usr/local/include -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64 -O2 -g -DVERSION=\"5.0404\" -DXS_VERSION=\"5.0404\" -fPIC "-I/usr/lib/perl/5.12/CORE" OID.c
Running Mkbootstrap for NetSNMP::OID ()
chmod 644 OID.bs
rm -f ../blib/arch/auto/NetSNMP/OID/OID.so
LD_RUN_PATH="/usr/local/lib:/usr/lib/perl/5.12/CORE" cc -shared -O2 -g -L/usr/local/lib -fstack-protector OID.o -o ../blib/arch/auto/NetSNMP/OID/OID.so \
-L/home/mohan/net-snmp-5.4.4/perl/OID/../../snmplib/.libs -L/home/mohan/net-snmp-5.4.4/perl/OID/../../snmplib -L/usr/local/lib -lnetsnmp -lcrypto \
chmod 755 ../blib/arch/auto/NetSNMP/OID/OID.so
cp OID.bs ../blib/arch/auto/NetSNMP/OID/OID.bs
chmod 644 ../blib/arch/auto/NetSNMP/OID/OID.bs
Manifying ../blib/man3/NetSNMP::OID.3pm
make[2]: Leaving directory `/home/mohan/net-snmp-5.4.4/perl/OID'
make[2]: Entering directory `/home/mohan/net-snmp-5.4.4/perl/agent'
cp agent.pm ../blib/lib/NetSNMP/agent.pm
AutoSplitting ../blib/lib/NetSNMP/agent.pm (../blib/lib/auto/NetSNMP/agent)
cp netsnmp_request_infoPtr.pm ../blib/lib/NetSNMP/agent/netsnmp_request_infoPtr.pm
make[3]: Entering directory `/home/mohan/net-snmp-5.4.4/perl/agent/Support'
cp Support.pm ../../blib/lib/NetSNMP/agent/Support.pm
make[3]: Leaving directory `/home/mohan/net-snmp-5.4.4/perl/agent/Support'
make[3]: Entering directory `/home/mohan/net-snmp-5.4.4/perl/agent/default_store'
cp default_store.pm ../../blib/lib/NetSNMP/agent/default_store.pm
AutoSplitting ../../blib/lib/NetSNMP/agent/default_store.pm (../../blib/lib/auto/NetSNMP/agent/default_store)
/usr/bin/perl /usr/share/perl/5.12.4/ExtUtils/xsubpp -prototypes -typemap /usr/share/perl/5.12/ExtUtils/typemap default_store.xs > default_store.xsc && mv default_store.xsc default_store.c
cc -c -I../../../include -fno-strict-aliasing -g -O2 -Ulinux -Dlinux=linux -D_REENTRANT -D_GNU_SOURCE -DDEBIAN -fno-strict-aliasing -pipe -fstack-protector -I/usr/local/include -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64 -I/usr/lib/perl/5.12/CORE -I. -I/usr/local/include -D_REENTRANT -D_GNU_SOURCE -DDEBIAN -fno-strict-aliasing -pipe -fstack-protector -I/usr/local/include -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64 -O2 -g -DVERSION=\"5.0404\" -DXS_VERSION=\"5.0404\" -fPIC "-I/usr/lib/perl/5.12/CORE" default_store.c
Running Mkbootstrap for NetSNMP::agent::default_store ()
rm -f ../../blib/arch/auto/NetSNMP/agent/default_store/default_store.so
LD_RUN_PATH="/usr/local/lib:/usr/lib/perl/5.12/CORE" cc -shared -O2 -g -L/usr/local/lib -fstack-protector default_store.o -o ../../blib/arch/auto/NetSNMP/agent/default_store/default_store.so \
-L/home/mohan/net-snmp-5.4.4/perl/agent/default_store/../../../snmplib/.libs -L/home/mohan/net-snmp-5.4.4/perl/agent/default_store/../../../snmplib -L/usr/local/lib -lnetsnmp -lcrypto \
chmod 755 ../../blib/arch/auto/NetSNMP/agent/default_store/default_store.so
cp default_store.bs ../../blib/arch/auto/NetSNMP/agent/default_store/default_store.bs
chmod 644 ../../blib/arch/auto/NetSNMP/agent/default_store/default_store.bs
Manifying ../../blib/man3/NetSNMP::agent::default_store.3pm
make[3]: Leaving directory `/home/mohan/net-snmp-5.4.4/perl/agent/default_store'
/usr/bin/perl /usr/share/perl/5.12.4/ExtUtils/xsubpp -prototypes -typemap /usr/share/perl/5.12/ExtUtils/typemap -typemap typemap agent.xs > agent.xsc && mv agent.xsc agent.c
cc -c -I../../include -fno-strict-aliasing -g -O2 -Ulinux -Dlinux=linux -D_REENTRANT -D_GNU_SOURCE -DDEBIAN -fno-strict-aliasing -pipe -fstack-protector -I/usr/local/include -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64 -I/usr/lib/perl/5.12/CORE -I. -I/usr/local/include -D_REENTRANT -D_GNU_SOURCE -DDEBIAN -fno-strict-aliasing -pipe -fstack-protector -I/usr/local/include -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64 -O2 -g -DVERSION=\"5.0404\" -DXS_VERSION=\"5.0404\" -fPIC "-I/usr/lib/perl/5.12/CORE" agent.c
agent.xs: In function ‘handler_wrapper’:
agent.xs:399:9: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
agent.xs:403:9: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
agent.xs:407:9: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
agent.xs:411:9: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
agent.xs: In function ‘XS_NetSNMP__agent_errlog’:
agent.xs:492:9: warning: format not a string literal and no format arguments [-Wformat-security]
agent.xs: In function ‘XS_NetSNMP__agent__netsnmp_handler_registration_register’:
agent.xs:542:27: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
agent.xs: In function ‘XS_NetSNMP__agent__netsnmp_handler_registrationPtr_getRootOID’:
agent.xs:567:19: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
agent.xs:577:9: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
agent.xs: In function ‘XS_NetSNMP__agent__netsnmp_request_infoPtr_getOID’:
agent.xs:606:19: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
agent.xs:616:9: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
agent.xs: In function ‘XS_NetSNMP__agent__netsnmp_request_infoPtr_getOIDptr’:
agent.xs:637:19: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
agent.xs: In function ‘XS_NetSNMP__agent__netsnmp_request_infoPtr_getType’:
agent.xs:652:19: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
agent.xs: In function ‘XS_NetSNMP__agent__netsnmp_request_infoPtr_setType’:
agent.xs:665:19: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
agent.xs: In function ‘XS_NetSNMP__agent__netsnmp_request_infoPtr_getValue’:
agent.xs:677:19: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
agent.xs: In function ‘XS_NetSNMP__agent__netsnmp_request_infoPtr_getDelegated’:
agent.xs:690:19: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
agent.xs: In function ‘XS_NetSNMP__agent__netsnmp_request_infoPtr_setDelegated’:
agent.xs:702:19: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
agent.xs: In function ‘XS_NetSNMP__agent__netsnmp_request_infoPtr_getProcessed’:
agent.xs:711:19: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
agent.xs: In function ‘XS_NetSNMP__agent__netsnmp_request_infoPtr_setProcessed’:
agent.xs:723:19: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
agent.xs: In function ‘XS_NetSNMP__agent__netsnmp_request_infoPtr_getStatus’:
agent.xs:732:19: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
agent.xs: In function ‘XS_NetSNMP__agent__netsnmp_request_infoPtr_setStatus’:
agent.xs:744:19: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
agent.xs: In function ‘XS_NetSNMP__agent__netsnmp_request_infoPtr_getRepeat’:
agent.xs:753:19: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
agent.xs: In function ‘XS_NetSNMP__agent__netsnmp_request_infoPtr_setRepeat’:
agent.xs:765:19: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
agent.xs: In function ‘XS_NetSNMP__agent__netsnmp_request_infoPtr_setValue’:
agent.xs:786:19: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
agent.xs:983:29: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
agent.xs: In function ‘XS_NetSNMP__agent__netsnmp_request_infoPtr_setOID’:
agent.xs:1017:23: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
agent.xs: In function ‘XS_NetSNMP__agent__netsnmp_request_infoPtr_setError’:
agent.xs:1032:19: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
agent.xs:1033:19: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
agent.xs: In function ‘XS_NetSNMP__agent__netsnmp_request_infoPtr_next’:
agent.xs:1044:23: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
agent.xs:1049:17: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
agent.xs: In function ‘XS_NetSNMP__agent__netsnmp_agent_request_info_getMode’:
agent.xs:1066:19: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
agent.xs: In function ‘XS_NetSNMP__agent__netsnmp_agent_request_info_setMode’:
agent.xs:1078:19: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
Running Mkbootstrap for NetSNMP::agent ()
chmod 644 agent.bs
rm -f ../blib/arch/auto/NetSNMP/agent/agent.so
LD_RUN_PATH="/usr/local/lib:/usr/lib/perl/5.12/CORE" cc -shared -O2 -g -L/usr/local/lib -fstack-protector agent.o -o ../blib/arch/auto/NetSNMP/agent/agent.so \
-L/usr/local/lib -L/home/mohan/net-snmp-5.4.4/perl/agent/../../snmplib/.libs -L/home/mohan/net-snmp-5.4.4/perl/agent/../../snmplib -L/home/mohan/net-snmp-5.4.4/perl/agent/../../agent/.libs -L/home/mohan/net-snmp-5.4.4/perl/agent/../../agent -L/home/mohan/net-snmp-5.4.4/perl/agent/../../agent/helpers/.libs -L/home/mohan/net-snmp-5.4.4/perl/agent/../../agent/helpers -lnetsnmpmibs -lnetsnmpagent -lnetsnmphelpers -lnetsnmp \
chmod 755 ../blib/arch/auto/NetSNMP/agent/agent.so
cp agent.bs ../blib/arch/auto/NetSNMP/agent/agent.bs
chmod 644 ../blib/arch/auto/NetSNMP/agent/agent.bs
Manifying ../blib/man3/NetSNMP::netsnmp_request_infoPtr.3pm
Manifying ../blib/man3/NetSNMP::agent.3pm
make[2]: Leaving directory `/home/mohan/net-snmp-5.4.4/perl/agent'
make[2]: Entering directory `/home/mohan/net-snmp-5.4.4/perl/SNMP'
cp SNMP.pm ../blib/lib/SNMP.pm
AutoSplitting ../blib/lib/SNMP.pm (../blib/lib/auto/SNMP)
/usr/bin/perl /usr/share/perl/5.12.4/ExtUtils/xsubpp -noprototypes -typemap /usr/share/perl/5.12/ExtUtils/typemap -typemap typemap SNMP.xs > SNMP.xsc && mv SNMP.xsc SNMP.c
cc -c -I../../include -fno-strict-aliasing -g -O2 -Ulinux -Dlinux=linux -D_REENTRANT -D_GNU_SOURCE -DDEBIAN -fno-strict-aliasing -pipe -fstack-protector -I/usr/local/include -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64 -I/usr/lib/perl/5.12/CORE -I. -I/usr/local/include -D_REENTRANT -D_GNU_SOURCE -DDEBIAN -fno-strict-aliasing -pipe -fstack-protector -I/usr/local/include -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64 -O2 -g -DVERSION=\"5.0404\" -DXS_VERSION=\"5.0404\" -fPIC "-I/usr/lib/perl/5.12/CORE" SNMP.c
SNMP.xs: In function ‘_bulkwalk_send_pdu’:
SNMP.xs:1808:26: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
SNMP.xs: In function ‘XS_SNMP__update_session’:
SNMP.xs:2859:17: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
SNMP.xs: In function ‘XS_SNMP__read_mib’:
SNMP.xs:2959:18: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
SNMP.xs: In function ‘XS_SNMP__read_module’:
SNMP.xs:2982:18: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
SNMP.xs: In function ‘XS_SNMP__set’:
SNMP.xs:3026:13: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
SNMP.xs: In function ‘XS_SNMP__catch’:
SNMP.xs:3154:13: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
SNMP.xs: In function ‘XS_SNMP__get’:
SNMP.xs:3233:13: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
SNMP.xs: In function ‘XS_SNMP__getnext’:
SNMP.xs:3459:13: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
SNMP.xs: In function ‘XS_SNMP__getbulk’:
SNMP.xs:3704:13: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
SNMP.xs: In function ‘XS_SNMP__bulkwalk’:
SNMP.xs:3929:10: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
SNMP.xs:4124:8: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
SNMP.xs: In function ‘XS_SNMP__trapV1’:
SNMP.xs:4234:13: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
SNMP.xs: In function ‘XS_SNMP__trapV2’:
SNMP.xs:4373:13: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
SNMP.xs: In function ‘XS_SNMP__inform’:
SNMP.xs:4512:13: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
SNMP.xs: In function ‘XS_SNMP__translate_obj’:
SNMP.xs:4786:9: warning: format ‘%s’ expects argument of type ‘char *’, but argument 2 has type ‘int’ [-Wformat]
SNMP.xs: In function ‘XS_SNMP__MIB__NODE_TIEHASH’:
SNMP.xs:5014:26: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
SNMP.xs: In function ‘XS_SNMP__MIB__NODE_FETCH’:
SNMP.xs:5046:36: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
SNMP.xs:5098:24: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
SNMP.xs:5179:18: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
SNMP.xs:5216:18: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
Running Mkbootstrap for SNMP ()
chmod 644 SNMP.bs
rm -f ../blib/arch/auto/SNMP/SNMP.so
LD_RUN_PATH="/usr/local/lib:/usr/lib/perl/5.12/CORE" cc -shared -O2 -g -L/usr/local/lib -fstack-protector SNMP.o -o ../blib/arch/auto/SNMP/SNMP.so \
-L/home/mohan/net-snmp-5.4.4/perl/SNMP/../../snmplib/.libs -L/home/mohan/net-snmp-5.4.4/perl/SNMP/../../snmplib -L/usr/local/lib -lnetsnmp -lcrypto \
chmod 755 ../blib/arch/auto/SNMP/SNMP.so
cp SNMP.bs ../blib/arch/auto/SNMP/SNMP.bs
chmod 644 ../blib/arch/auto/SNMP/SNMP.bs
Manifying ../blib/man3/SNMP.3
make[2]: Leaving directory `/home/mohan/net-snmp-5.4.4/perl/SNMP'
make[2]: Entering directory `/home/mohan/net-snmp-5.4.4/perl/TrapReceiver'
cp TrapReceiver.pm ../blib/lib/NetSNMP/TrapReceiver.pm
AutoSplitting ../blib/lib/NetSNMP/TrapReceiver.pm (../blib/lib/auto/NetSNMP/TrapReceiver)
/usr/bin/perl /usr/share/perl/5.12.4/ExtUtils/xsubpp -prototypes -typemap /usr/share/perl/5.12/ExtUtils/typemap -typemap typemap TrapReceiver.xs > TrapReceiver.xsc && mv TrapReceiver.xsc TrapReceiver.c
cc -c -I. -I../../include -fno-strict-aliasing -g -O2 -Ulinux -Dlinux=linux -D_REENTRANT -D_GNU_SOURCE -DDEBIAN -fno-strict-aliasing -pipe -fstack-protector -I/usr/local/include -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64 -I/usr/lib/perl/5.12/CORE -I. -I/usr/local/include -D_REENTRANT -D_GNU_SOURCE -DDEBIAN -fno-strict-aliasing -pipe -fstack-protector -I/usr/local/include -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64 -O2 -g -DVERSION=\"5.0404\" -DXS_VERSION=\"5.0404\" -fPIC "-I/usr/lib/perl/5.12/CORE" TrapReceiver.c
In file included from TrapReceiver.xs:6:0:
ppport.h:227:0: warning: "PERL_UNUSED_DECL" redefined [enabled by default]
/usr/lib/perl/5.12/CORE/perl.h:308:0: note: this is the location of the previous definition
TrapReceiver.xs: In function ‘perl_trapd_handler’:
TrapReceiver.xs:145:25: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
TrapReceiver.xs:197:9: warning: format ‘%lu’ expects argument of type ‘long unsigned int’, but argument 5 has type ‘unsigned int’ [-Wformat]
Running Mkbootstrap for NetSNMP::TrapReceiver ()
chmod 644 TrapReceiver.bs
rm -f ../blib/arch/auto/NetSNMP/TrapReceiver/TrapReceiver.so
LD_RUN_PATH="/usr/local/lib:/usr/lib/perl/5.12/CORE" cc -shared -O2 -g -L/usr/local/lib -fstack-protector TrapReceiver.o -o ../blib/arch/auto/NetSNMP/TrapReceiver/TrapReceiver.so \
-L/home/mohan/net-snmp-5.4.4/perl/TrapReceiver/../../apps/.libs -L/home/mohan/net-snmp-5.4.4/perl/TrapReceiver/../../apps -L/home/mohan/net-snmp-5.4.4/perl/TrapReceiver/../../agent/.libs -L/home/mohan/net-snmp-5.4.4/perl/TrapReceiver/../../agent -L/home/mohan/net-snmp-5.4.4/perl/TrapReceiver/../../agent/helpers/.libs -L/home/mohan/net-snmp-5.4.4/perl/TrapReceiver/../../agent/helpers -L/home/mohan/net-snmp-5.4.4/perl/TrapReceiver/../../snmplib/.libs -L/home/mohan/net-snmp-5.4.4/perl/TrapReceiver/../../snmplib -lnetsnmptrapd -lnetsnmpagent -lnetsnmp \
chmod 755 ../blib/arch/auto/NetSNMP/TrapReceiver/TrapReceiver.so
cp TrapReceiver.bs ../blib/arch/auto/NetSNMP/TrapReceiver/TrapReceiver.bs
chmod 644 ../blib/arch/auto/NetSNMP/TrapReceiver/TrapReceiver.bs
Manifying ../blib/man3/NetSNMP::TrapReceiver.3pm
make[2]: Leaving directory `/home/mohan/net-snmp-5.4.4/perl/TrapReceiver'
make[1]: Leaving directory `/home/mohan/net-snmp-5.4.4/perl'
Thanks & Regards,
MOHAMMAD BIYABANI.
linuxubuntu biyabani is online now Report This Post
