I am working on LPC3250 board with linux(3.0.10) ubuntu(11.10) version.Basically only one UART1 has been enabled for BOOTING <span class="skimwords-unlinked">Process.But,In</span> this board i want to send the data using remaining UARTS( i,e from board UARTS to another system or board). How can i transmit the data and test whether data is transmitted or not?<span class="skimwords-unlinked"></span>
Thanks & Regards,
MOHAMMAD BIYABANI.
