Content originally posted in LPCWare by Shoaib on Tue Aug 05 12:58:59 MST 2014Hi everyone,I was trying to implement a basic code for rpm measurement but came across a couple of problems.1) I am connecting a DC motor to the power supply and measuring the rpm values in my code. The rpm values are reducing for higher supply voltages. If the power supply is 10 V the rpm value is around 180 and for 15V it reduces to 90.2) Moreover the measured rpm is alternating between two values. For example for 10V supply i receive 180 and 220 as the rpm values.Thanks!Original Attachment has been moved to: New%20Text%20Document_0.txt.zip
