Content originally posted in LPCWare by sjalloq on Thu Nov 10 14:16:34 MST 2011
Hi there,
just getting up to speed with the nxpUSBlib and noticed that not all of the demos have been ported across with LPCxpresso example projects. I'm wanting to try out the AudioOutput one and tried creating my own project but on compile found that it still contained references to the original AVR targets. The first example project I compared it against seems to have ARCH_LPC ifdef's.
What is the plan regarding the remaining example projects? Do you have a timeline for porting them?
Otherwise, I'm guessing it's not much work to make the adjustments myself. Any gotchas I should be aware of?
Thanks.
