Content originally posted in LPCWare by shriharsh.datu on Fri Mar 01 05:51:01 MST 2013
Using nxpUSBlib can i use both host & device simultaneously?
On host port i need to connect modem with CDC class.
And this device need to connect to PC as mass storage device.
So can i use the latest stack v0.98 with LPC1830 to implement both funcationality?
If not can you recommend any other solution for same?
Shriharsh Datar
