Content originally posted in LPCWare by klakow on Fri Nov 30 15:43:40 MST 2012
Wow can i use same of the JTAG Pins for application. Me interested is to use same or all pin if this possible for application, except with the option to use the pins also for debugging, is this possible?
Best regards, U.Klakow
