Hello
Whole content of the directory %USERPROFILE%\Local Settings\Application Data\Metrowerks
is recreated next time you start CodeWarrior.
So solution for you might be to
- Close CodeWarrior
- Remove whole directory %USERPROFILE%\Local Settings\Application Data\Metrowerks
- Restart CodeWarrior.
Deleting the Metrowerks directory you will loose following information:
- List of recent files, projects and workspaces opened
- All settings in IDE Preference dialog
- All Settings in "Customize IDE" dialog.
CrasyCat
