spi realtime
spi realtime
wonhyukkwon
Hi.
I'm using MWCT1003A chip which connected by slave spi in my board system.
I have something problem so i want see MWCT1003A's SPI data in realtime.
Is it possible? If possible how do that?
TICS_Fiona
Hello wonhyuk
CodeWarrior does not support for viewing the register or variables in real time on DSC platform.  A workaround is to read the SPI data from register and save it to global variable every time the SPI data register is updated.  Then show the global variable in FreeMaster.  FreeMaster can be downloaded from:
FreeMASTER Run-Time Debugging Tool|NXP
Best Regards
Fiona Kuang
TIC - Technical Information Center
Note: If this post answers your question, please click the Mark Correct button. Thank you!
TICS_Fiona
Hello wonhyuk
Best Regards
Fiona Kuang
