Hi all,
Iam not able to turn on bluetooth in lollipop 5.1.1. When i am seeing cat /proc/devices my devices is creating as usb charecter deivce as rsi But when iam seeing in logcat, it saying unable to open device rsi.Can anybody help me in getting out of this.Here i am attaching my logcat.
As per the logcat deatils i am not able to open my charecter device port.Please find my logcat details
--------- beginning of main
I/lowmemorykiller( 122): Using in-kernel low memory killer interface
W/auditd ( 120): type=2000 audit(0.0:1): initialized
I/auditd ( 120): type=1403 audit(0.0:2): policy loaded auid=4294967295 ses=4294967295
W/auditd ( 120): type=1404 audit(0.0:3): enforcing=1 old_enforcing=0 auid=4294967295 ses=4294967295
--------- beginning of system
I/Vold ( 124): Vold 2.1 (the revenge) firing up
E/DirectVolume( 124): Vold managed volumes must have auto mount point; ignoring /mnt/media_rw/extsd
D/Vold ( 124): Volume extsd state changing -1 (Initializing) -> 0 (No-Media)
E/DirectVolume( 124): Vold managed volumes must have auto mount point; ignoring /mnt/media_rw/udisk
D/Vold ( 124): Volume udisk state changing -1 (Initializing) -> 0 (No-Media)
I/SurfaceFlinger( 125): SurfaceFlinger is starting
I/SurfaceFlinger( 125): SurfaceFlinger's main thread ready to run. Initializing graphics H/W...
D/libEGL ( 125): loaded /system/lib/egl/libGLES_android.so
I/ ( 141): debuggerd: Feb 25 2016 14:56:22
I/Netd ( 139): Netd 1.0 starting
I/installd( 144): installd firing up
E/cutils ( 144): Failed to read /data/.layout_version: No such file or directory
D/installd( 144): Upgrading /data/media for multi-user
I/SELinux ( 144): SELinux: Loaded file_contexts from /file_contexts
D/installd( 144): Upgrading to shared /data/media/obb
E/cutils ( 150): Failed to read /data/.layout_version: No such file or directory
E/sdcard ( 150): installd fs upgrade not yet complete. Waiting...
D/installd( 144): Upgrading to /data/misc/user directories
I/imx6.gralloc( 125): open gpu gralloc module!
I/imx6.gralloc( 125): fb_device_open dispid:0, fb:0
I/imx6.gralloc( 125): 16bpp setting of Framebuffer with RGB565 format!
W/imx6.gralloc( 125): using (fd=11)
W/imx6.gralloc( 125): id = mxs-lcdif
W/imx6.gralloc( 125): xres = 800 px
W/imx6.gralloc( 125): yres = 480 px
W/imx6.gralloc( 125): xres_virtual = 800 px
W/imx6.gralloc( 125): yres_virtual = 1440 px
W/imx6.gralloc( 125): bpp = 16
W/imx6.gralloc( 125): r = 11:5
W/imx6.gralloc( 125): g = 5:6
W/imx6.gralloc( 125): b = 0:5
W/imx6.gralloc( 125): width = 127 mm (160.000000 dpi)
W/imx6.gralloc( 125): height = 76 mm (160.421051 dpi)
W/imx6.gralloc( 125): refresh rate = 60.26 Hz
I/FslHwcomposer( 125): using fsl hwc!!!
I/FslHwcomposer( 125): hwc_device_open,562
I/FslHwcomposer( 125): open /sys/class/graphics/fb0/fsl_disp_dev_property failed
W/FslHwcomposer( 125): open /sys/class/graphics/fb1 failed
W/FslHwcomposer( 125): open /sys/class/graphics/fb2 failed
W/FslHwcomposer( 125): open /sys/class/graphics/fb3 failed
W/FslHwcomposer( 125): open /sys/class/graphics/fb4 failed
W/FslHwcomposer( 125): open /sys/class/graphics/fb5 failed
I/FslHwcomposer( 125): hwcomposer: open framebuffer fb0
I/imx6.gralloc( 125): display already initialized...
I/FslHwcomposer( 125): hwc_device_open,426
I/SurfaceFlinger( 125): Using composer version 1.3
W/SurfaceFlinger( 125): no suitable EGLConfig found, trying a simpler query
W/SurfaceFlinger( 125): EGL_SLOW_CONFIG selected!
I/SurfaceFlinger( 125): EGL information:
I/SurfaceFlinger( 125): vendor : Android
I/SurfaceFlinger( 125): version : 1.4 Android META-EGL
I/SurfaceFlinger( 125): extensions: EGL_KHR_get_all_proc_addresses EGL_ANDROID_presentation_time EGL_KHR_image_base EGL_KHR_fence_sync EGL_ANDROID_image_native_buffer
I/SurfaceFlinger( 125): Client API: OpenGL_ES
I/SurfaceFlinger( 125): EGLSurface: 5-6-5-0, config=0x0
I/SurfaceFlinger( 125): OpenGL ES informations:
I/SurfaceFlinger( 125): renderer : Android PixelFlinger 1.4
I/SurfaceFlinger( 125): version : OpenGL ES-CM 1.0
I/SurfaceFlinger( 125): extensions: GL_EXT_debug_marker GL_OES_byte_coordinates GL_OES_fixed_point GL_OES_single_precision GL_OES_read_format GL_OES_compressed_paletted_texture GL_OES_draw_texture GL_OES_matrix_get GL_OES_query_matrix GL_OES_EGL_image GL_OES_EGL_sync GL_OES_compressed_ETC1_RGB8_texture GL_ARB_texture_compression GL_ARB_texture_non_power_of_two GL_ANDROID_user_clip_plane GL_ANDROID_vertex_buffer_object GL_ANDROID_generate_mipmap
I/SurfaceFlinger( 125): GL_MAX_TEXTURE_SIZE = 4096
I/SurfaceFlinger( 125): GL_MAX_VIEWPORT_DIMS = 4096
E/cutils-trace( 125): Error opening trace file: Permission denied (13)
D/SurfaceFlinger( 125): Set power mode=2, type=0 flinger=0xb6082000
I/FslHwcomposer( 125): prepare: targetHandle is null
E/sdcard ( 150): missing packages.list; retrying
D/libEGL ( 170): loaded /system/lib/egl/libGLES_android.so
E/cutils-trace( 170): Error opening trace file: Permission denied (13)
I/imx6.gralloc( 170): open gpu gralloc module!
I/ARMAssembler( 170): generated scanline__00000077:03010102_00000A01_00000000 [ 9 ipp] (30 ins) at [0xad1891f0:0xad189268] in 139917 ns
I/ARMAssembler( 170): generated scanline__00000077:03545402_00000A01_00000000 [ 31 ipp] (52 ins) at [0xad189270:0xad189340] in 100917 ns
I/mediaserver( 143): ServiceManager: 0xb58700c0
I/AudioFlinger( 143): Using default 3000 mSec as standby time.
I/ServiceManager( 143): Waiting for service batterystats...
D/AndroidRuntime( 148): >>>>>> START com.android.internal.os.ZygoteInit uid 0 <<<<<<
D/AndroidRuntime( 148): CheckJNI is OFF
I/art ( 148): option[0]=-Xzygote
I/art ( 148): option[1]=-Xstacktracefile:/data/anr/traces.txt
I/art ( 148): option[2]=exit
I/art ( 148): option[3]=vfprintf
I/art ( 148): option[4]=sensitiveThread
I/art ( 148): option[5]=-verbose:gc
I/art ( 148): option[6]=-Xms8m
I/art ( 148): option[7]=-Xmx384m
I/art ( 148): option[8]=-XX:mainThreadStackSize=24K
I/art ( 148): option[9]=-XX:HeapGrowthLimit=80m
I/art ( 148): option[10]=-XX:HeapMinFree=512k
I/art ( 148): option[11]=-XX:HeapMaxFree=8m
I/art ( 148): option[12]=-XX:HeapTargetUtilization=0.75
I/art ( 148): option[13]=-Xgenregmap
I/art ( 148): option[14]=-Xgc:precise
I/art ( 148): option[15]=-agentlib:jdwp=transport=dt_android_adb,suspend=n,server=y
I/art ( 148): option[16]=-Xlockprofthreshold:500
I/art ( 148): option[17]=-Ximage-compiler-option
I/art ( 148): option[18]=--runtime-arg
I/art ( 148): option[19]=-Ximage-compiler-option
I/art ( 148): option[20]=-Xms64m
I/art ( 148): option[21]=-Ximage-compiler-option
I/art ( 148): option[22]=--runtime-arg
I/art ( 148): option[23]=-Ximage-compiler-option
I/art ( 148): option[24]=-Xmx64m
I/art ( 148): option[25]=-Ximage-compiler-option
I/art ( 148): option[26]=--image-classes=/system/etc/preloaded-classes
I/art ( 148): option[27]=-Xcompiler-option
I/art ( 148): option[28]=--runtime-arg
I/art ( 148): option[29]=-Xcompiler-option
I/art ( 148): option[30]=-Xms64m
I/art ( 148): option[31]=-Xcompiler-option
I/art ( 148): option[32]=--runtime-arg
I/art ( 148): option[33]=-Xcompiler-option
I/art ( 148): option[34]=-Xmx512m
I/art ( 148): option[35]=-Duser.language=en
I/art ( 148): option[36]=-Duser.region=US
I/art ( 148): Pruning dalvik-cache since we are generating an image and will need to recompile
I/art ( 148): Using an offset of 0x90c000 from default art base address of 0x50000000
I/art ( 148): GenerateImage: /system/bin/dex2oat --image=/data/dalvik-cache/arm/system@framework@boot.art --dex-file=/system/framework/core-libart.jar --dex-file=/system/framework/conscrypt.jar --dex-file=/system/framework/okhttp.jar --dex-file=/system/framework/core-junit.jar --dex-file=/system/framework/bouncycastle.jar --dex-file=/system/framework/ext.jar --dex-file=/system/framework/framework.jar --dex-file=/system/framework/telephony-common.jar --dex-file=/system/framework/voip-common.jar --dex-file=/system/framework/ims-common.jar --dex-file=/system/framework/mms-common.jar --dex-file=/system/framework/android.policy.jar --dex-file=/system/framework/apache-xml.jar --oat-file=/data/dalvik-cache/arm/system@framework@boot.oat --instruction-set=arm --instruction-set-features=default --base=0x5090c000 --runtime-arg -Xms64m --runtime-arg -Xmx64m --image-classes=/system/etc/preloaded-classes
V/NatController( 139): runCmd(/system/bin/iptables -F natctrl_FORWARD) res=0
V/NatController( 139): runCmd(/system/bin/iptables -A natctrl_FORWARD -j DROP) res=0
V/NatController( 139): runCmd(/system/bin/iptables -t nat -F natctrl_nat_POSTROUTING) res=0
V/NatController( 139): runCmd(/system/bin/iptables -F natctrl_tether_counters) res=1
V/NatController( 139): runCmd(/system/bin/iptables -X natctrl_tether_counters) res=1
V/NatController( 139): runCmd(/system/bin/iptables -N natctrl_tether_counters) res=0
V/NatController( 139): runCmd(/system/bin/iptables -t mangle -A natctrl_mangle_FORWARD -p tcp --tcp-flags SYN SYN -j TCPMSS --clamp-mss-to-pmtu) res=0
E/cutils-trace( 284): Error opening trace file: No such file or directory (2)
I/dex2oat ( 284): /system/bin/dex2oat --image=/data/dalvik-cache/arm/system@framework@boot.art --dex-file=/system/framework/core-libart.jar --dex-file=/system/framework/conscrypt.jar --dex-file=/system/framework/okhttp.jar --dex-file=/system/framework/core-junit.jar --dex-file=/system/framework/bouncycastle.jar --dex-file=/system/framework/ext.jar --dex-file=/system/framework/framework.jar --dex-file=/system/framework/telephony-common.jar --dex-file=/system/framework/voip-common.jar --dex-file=/system/framework/ims-common.jar --dex-file=/system/framework/mms-common.jar --dex-file=/system/framework/android.policy.jar --dex-file=/system/framework/apache-xml.jar --oat-file=/data/dalvik-cache/arm/system@framework@boot.oat --instruction-set=arm --instruction-set-features=default --base=0x5090c000 --runtime-arg -Xms64m --runtime-arg -Xmx64m --image-classes=/system/etc/preloaded-classes
D/MDnsDS ( 139): MDnsSdListener::Hander starting up
D/MDnsDS ( 139): MDnsSdListener starting to monitor
D/MDnsDS ( 139): Going to poll with pollCount 1
I/CameraService( 143): CameraService started (pid=143)
I/CameraService( 143): Loaded "Freescale CameraHal Module" camera module
I/FslCameraHAL( 143): Face Back Camera is csi, orient is 0
I/FslCameraHAL( 143): Face Front Camera is uvc, orient is 0
I/FslCameraHAL( 143): v4l2_cap.drive is mx6s-csi
I/FslCameraHAL( 143): Get sensor csi's dev path /dev/video0
I/FslCameraHAL( 143): Camera ID 0: name csi, Facing 0, orientation 0, dev path /dev/video0
I/FslCameraHAL( 143): Camera ID 1: name uvc, Facing 1, orientation 0, dev path
I/AudioPolicyService( 143): AudioPolicyService CSTOR in new mode
I/AudioPolicyManager( 143): loadAudioPolicyConfig() loaded /system/etc/audio_policy.conf
W/audio_hw_primary( 143): card 0, id wm8962audio ,driver wm8962-audio, name wm8962-audio
W/audio_hw_primary( 143): out rate 44100
W/audio_hw_primary( 143): in rate 44100, channels 1 format 0
W/audio_hw_primary( 143): card 1, id imxspdif ,driver imx-spdif, name imx-spdif
W/audio_hw_primary( 143): in rate 0, channels 0 format 0
I/AudioFlinger( 143): loadHwModule() Loaded primary audio interface from Freescale i.MX Audio HW HAL (audio) handle 1
W/audio_hw_primary( 143): open output stream devices 2, format 1, channels 3, sample_rate 44100, flag 2
W/audio_hw_primary( 143): opened out stream...-1249269568, type 1
I/AudioFlinger( 143): HAL output buffer size 192 frames, normal sink buffer size 768 frames
I/AudioMixer( 143): found effect "Multichannel Downmix To Stereo" from The Android Open Source Project
E/MonoPipe( 143): Failed to fetch local time frequency when constructing a MonoPipe (res = -32). getNextWriteTimestamp calls will be non-functional
I/dex2oat ( 284): Explicit concurrent mark sweep GC freed 34948(5MB) AllocSpace objects, 0(0B) LOS objects, 16% free, 20MB/24MB, paused 859us total 280.166ms
I/dex2oat ( 284): Method exceeds compiler instruction limit: 21296 in void org.ccil.cowan.tagsoup.HTMLSchema.<init>()
W/dex2oat ( 284): Compilation of boolean android.app.ActivityManagerNative.onTransact(int, android.os.Parcel, android.os.Parcel, int) took 125.453ms
W/dex2oat ( 284): Compilation of void com.android.internal.telephony.uicc.SIMRecords.handleMessage(android.os.Message) took 109.095ms
I/dex2oat ( 284): Explicit concurrent mark sweep GC freed 223916(15MB) AllocSpace objects, 0(0B) LOS objects, 27% free, 10MB/14MB, paused 1.909ms total 146.674ms
I/dex2oat ( 284): dex2oat took 163.013s (threads: 1) arena alloc=2MB java alloc=10MB native alloc=65MB free=14MB
E/memtrack( 148): Couldn't load memtrack module (No such file or directory)
E/android.os.Debug( 148): failed to load memtrack module: -2
I/SamplingProfilerIntegration( 148): Profiling disabled.
D/Zygote ( 148): begin preload
I/Zygote ( 148): Preloading classes...
E/cutils-trace( 148): Error opening trace file: Permission denied (13)
I/art ( 148): Explicit concurrent mark sweep GC freed 796(35KB) AllocSpace objects, 0(0B) LOS objects, 95% free, 44KB/1068KB, paused 259us total 8.225ms
I/art ( 148): Counter: 1
I/art ( 148): Explicit concurrent mark sweep GC freed 539(33KB) AllocSpace objects, 0(0B) LOS objects, 94% free, 64KB/1088KB, paused 242us total 6.236ms
I/art ( 148): Explicit concurrent mark sweep GC freed 650(41KB) AllocSpace objects, 0(0B) LOS objects, 93% free, 71KB/1095KB, paused 398us total 8.017ms
I/art ( 148): Explicit concurrent mark sweep GC freed 381(22KB) AllocSpace objects, 0(0B) LOS objects, 90% free, 102KB/1126KB, paused 249us total 5.520ms
E/Minikin ( 148): addFont failed to create font /system/fonts/NotoSansGujarati-Regular.ttf
E/Minikin ( 148): addFont failed to create font /system/fonts/NotoSansGujarati-Bold.ttf
E/Minikin ( 148): addFont failed to create font /system/fonts/NotoSansGujaratiUI-Regular.ttf
E/Minikin ( 148): addFont failed to create font /system/fonts/NotoSansGujaratiUI-Bold.ttf
E/Minikin ( 148): addFont failed to create font /system/fonts/NotoSansGurmukhi-Regular.ttf
E/Minikin ( 148): addFont failed to create font /system/fonts/NotoSansGurmukhi-Bold.ttf
E/Minikin ( 148): addFont failed to create font /system/fonts/NotoSansGurmukhiUI-Regular.ttf
E/Minikin ( 148): addFont failed to create font /system/fonts/NotoSansGurmukhiUI-Bold.ttf
E/Minikin ( 148): addFont failed to create font /system/fonts/NotoSansSinhala-Regular.ttf
E/Minikin ( 148): addFont failed to create font /system/fonts/NotoSansSinhala-Bold.ttf
E/Minikin ( 148): addFont failed to create font /system/fonts/NotoSansThaana-Regular.ttf
E/Minikin ( 148): addFont failed to create font /system/fonts/NotoSansThaana-Bold.ttf
E/Minikin ( 148): addFont failed to create font /system/fonts/NotoSansCham-Regular.ttf
E/Minikin ( 148): addFont failed to create font /system/fonts/NotoSansCham-Bold.ttf
E/Minikin ( 148): addFont failed to create font /system/fonts/NotoSansBalinese-Regular.ttf
E/Minikin ( 148): addFont failed to create font /system/fonts/NotoSansBatak-Regular.ttf
E/Minikin ( 148): addFont failed to create font /system/fonts/NotoSansBuginese-Regular.ttf
E/Minikin ( 148): addFont failed to create font /system/fonts/NotoSansBuhid-Regular.ttf
E/Minikin ( 148): addFont failed to create font /system/fonts/NotoSansCanadianAboriginal-Regular.ttf
E/Minikin ( 148): addFont failed to create font /system/fonts/NotoSansCherokee-Regular.ttf
E/Minikin ( 148): addFont failed to create font /system/fonts/NotoSansCoptic-Regular.ttf
E/Minikin ( 148): addFont failed to create font /system/fonts/NotoSansGlagolitic-Regular.ttf
E/Minikin ( 148): addFont failed to create font /system/fonts/NotoSansHanunoo-Regular.ttf
E/Minikin ( 148): addFont failed to create font /system/fonts/NotoSansJavanese-Regular.ttf
E/Minikin ( 148): addFont failed to create font /system/fonts/NotoSansKayahLi-Regular.ttf
E/Minikin ( 148): addFont failed to create font /system/fonts/NotoSansLepcha-Regular.ttf
E/Minikin ( 148): addFont failed to create font /system/fonts/NotoSansLimbu-Regular.ttf
E/Minikin ( 148): addFont failed to create font /system/fonts/NotoSansMeeteiMayek-Regular.ttf
E/Minikin ( 148): addFont failed to create font /system/fonts/NotoSansOlChiki-Regular.ttf
E/Minikin ( 148): addFont failed to create font /system/fonts/NotoSansRejang-Regular.ttf
E/Minikin ( 148): addFont failed to create font /system/fonts/NotoSansSaurashtra-Regular.ttf
E/Minikin ( 148): addFont failed to create font /system/fonts/NotoSansSundanese-Regular.ttf
E/Minikin ( 148): addFont failed to create font /system/fonts/NotoSansSylotiNagri-Regular.ttf
E/Minikin ( 148): addFont failed to create font /system/fonts/NotoSansTagbanwa-Regular.ttf
E/Minikin ( 148): addFont failed to create font /system/fonts/NotoSansTaiTham-Regular.ttf
E/Minikin ( 148): addFont failed to create font /system/fonts/NotoSansTaiViet-Regular.ttf
E/Minikin ( 148): addFont failed to create font /system/fonts/NotoSansTifinagh-Regular.ttf
E/Minikin ( 148): addFont failed to create font /system/fonts/NotoSansYi-Regular.ttf
E/Minikin ( 148): addFont failed to create font /system/fonts/Lohit-Odia.ttf
E/Minikin ( 148): addFont failed to create font /system/fonts/NotoSansHans-Regular.otf
E/Minikin ( 148): addFont failed to create font /system/fonts/NotoSansHant-Regular.otf
E/Minikin ( 148): addFont failed to create font /system/fonts/NotoSansJP-Regular.otf
E/Minikin ( 148): addFont failed to create font /system/fonts/NotoSansKR-Regular.otf
E/Minikin ( 148): addFont failed to create font /system/fonts/NotoSansTaiLe-Regular.ttf
I/art ( 148): Explicit concurrent mark sweep GC freed 1800(129KB) AllocSpace objects, 0(0B) LOS objects, 90% free, 113KB/1137KB, paused 251us total 6.425ms
I/art ( 148): Explicit concurrent mark sweep GC freed 1933(92KB) AllocSpace objects, 0(0B) LOS objects, 86% free, 153KB/1177KB, paused 244us total 10.221ms
I/art ( 148): Explicit concurrent mark sweep GC freed 1986(88KB) AllocSpace objects, 0(0B) LOS objects, 84% free, 189KB/1213KB, paused 250us total 8.744ms
I/art ( 148): Explicit concurrent mark sweep GC freed 371(19KB) AllocSpace objects, 0(0B) LOS objects, 82% free, 222KB/1246KB, paused 256us total 8.608ms
I/art ( 148): Thread[1,tid=148,WaitingForJniOnLoad,Thread*=0xb4827800,peer=0x12c31100,"main"] recursive attempt to load library "/system/lib/libmedia_jni.so"
D/MtpDeviceJNI( 148): register_android_mtp_MtpDevice
I/art ( 148): Explicit concurrent mark sweep GC freed 644(37KB) AllocSpace objects, 0(0B) LOS objects, 81% free, 234KB/1258KB, paused 256us total 10.354ms
I/art ( 148): Explicit concurrent mark sweep GC freed 508(24KB) AllocSpace objects, 0(0B) LOS objects, 79% free, 260KB/1284KB, paused 253us total 9.722ms
I/art ( 148): Explicit concurrent mark sweep GC freed 615(33KB) AllocSpace objects, 0(0B) LOS objects, 78% free, 288KB/1312KB, paused 267us total 9.662ms
I/art ( 148): Explicit concurrent mark sweep GC freed 1894(110KB) AllocSpace objects, 0(0B) LOS objects, 69% free, 453KB/1477KB, paused 276us total 9.542ms
E/EmojiFactory_jni( 148): Failed to load libemoji.so: dlopen failed: library "libemoji.so" not found
I/art ( 148): Explicit concurrent mark sweep GC freed 364(45KB) AllocSpace objects, 0(0B) LOS objects, 57% free, 750KB/1774KB, paused 274us total 17.639ms
I/art ( 148): Explicit concurrent mark sweep GC freed 438(30KB) AllocSpace objects, 0(0B) LOS objects, 57% free, 769KB/1793KB, paused 270us total 9.888ms
I/art ( 148): Explicit concurrent mark sweep GC freed 782(49KB) AllocSpace objects, 0(0B) LOS objects, 57% free, 769KB/1793KB, paused 263us total 8.526ms
I/art ( 148): Explicit concurrent mark sweep GC freed 959(105KB) AllocSpace objects, 0(0B) LOS objects, 55% free, 812KB/1836KB, paused 315us total 11.935ms
I/art ( 148): Explicit concurrent mark sweep GC freed 597(42KB) AllocSpace objects, 0(0B) LOS objects, 55% free, 819KB/1843KB, paused 280us total 11.569ms
I/art ( 148): Explicit concurrent mark sweep GC freed 265(20KB) AllocSpace objects, 0(0B) LOS objects, 54% free, 847KB/1871KB, paused 283us total 8.491ms
I/art ( 148): Explicit concurrent mark sweep GC freed 31(1232B) AllocSpace objects, 0(0B) LOS objects, 45% free, 1226KB/2MB, paused 301us total 10.448ms
I/art ( 148): Explicit concurrent mark sweep GC freed 572(33KB) AllocSpace objects, 0(0B) LOS objects, 45% free, 1242KB/2MB, paused 304us total 12.946ms
I/art ( 148): Explicit concurrent mark sweep GC freed 741(45KB) AllocSpace objects, 0(0B) LOS objects, 45% free, 1246KB/2MB, paused 304us total 10.824ms
I/System ( 148): Loaded time zone names for "" in 116ms (112ms in ICU)
I/System ( 148): Loaded time zone names for "en_US" in 68ms (57ms in ICU)
I/art ( 148): Explicit concurrent mark sweep GC freed 2203(171KB) AllocSpace objects, 0(0B) LOS objects, 42% free, 1401KB/2MB, paused 302us total 12.283ms
I/art ( 148): Explicit concurrent mark sweep GC freed 136(12KB) AllocSpace objects, 0(0B) LOS objects, 41% free, 1466KB/2MB, paused 298us total 13.131ms
I/art ( 148): Explicit concurrent mark sweep GC freed 288(24KB) AllocSpace objects, 0(0B) LOS objects, 40% free, 1512KB/2MB, paused 300us total 12.709ms
I/art ( 148): Explicit concurrent mark sweep GC freed 679(47KB) AllocSpace objects, 0(0B) LOS objects, 40% free, 1513KB/2MB, paused 298us total 11.825ms
I/Zygote ( 148): ...preloaded 3005 classes in 2485ms.
I/art ( 148): VMRuntime.preloadDexCaches starting
I/art ( 148): VMRuntime.preloadDexCaches strings total=211441 before=39118 after=39118
I/art ( 148): VMRuntime.preloadDexCaches types total=18385 before=6348 after=6386
I/art ( 148): VMRuntime.preloadDexCaches fields total=85422 before=32200 after=32534
I/art ( 148): VMRuntime.preloadDexCaches methods total=151668 before=66497 after=67398
I/art ( 148): VMRuntime.preloadDexCaches finished
I/art ( 148): Counter: 0
I/art ( 148): Explicit concurrent mark sweep GC freed 61(15KB) AllocSpace objects, 0(0B) LOS objects, 40% free, 1499KB/2MB, paused 338us total 17.064ms
D/idmap ( 400): error: no read access to /vendor/overlay: No such file or directory
I/Zygote ( 148): Preloading resources...
W/Resources( 148): Preloaded drawable resource #0x1080096 (android:drawable/toast_frame) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x108010d (android:drawable/btn_check_on_pressed_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x108010c (android:drawable/btn_check_on_pressed_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x108010a (android:drawable/btn_check_on_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080109 (android:drawable/btn_check_on_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080107 (android:drawable/btn_check_on_focused_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080106 (android:drawable/btn_check_on_focused_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080105 (android:drawable/btn_check_on_disabled_holo_light) that varies with configuration!!
I/art ( 148): Explicit concurrent mark sweep GC freed 204(12KB) AllocSpace objects, 0(0B) LOS objects, 39% free, 1539KB/2MB, paused 321us total 14.275ms
W/Resources( 148): Preloaded drawable resource #0x1080104 (android:drawable/btn_check_on_disabled_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080103 (android:drawable/btn_check_on_disabled_focused_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080102 (android:drawable/btn_check_on_disabled_focused_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10800fa (android:drawable/btn_check_off_pressed_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10800f9 (android:drawable/btn_check_off_pressed_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10800f5 (android:drawable/btn_check_off_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10800f4 (android:drawable/btn_check_off_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10800f2 (android:drawable/btn_check_off_focused_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10800f1 (android:drawable/btn_check_off_focused_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10800f0 (android:drawable/btn_check_off_disabled_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10800ef (android:drawable/btn_check_off_disabled_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10800ee (android:drawable/btn_check_off_disabled_focused_holo_light) that varies with configuration!!
I/art ( 148): Explicit concurrent mark sweep GC freed 308(40KB) AllocSpace objects, 0(0B) LOS objects, 39% free, 1549KB/2MB, paused 302us total 19.523ms
W/Resources( 148): Preloaded drawable resource #0x10800ed (android:drawable/btn_check_off_disabled_focused_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10800e3 (android:drawable/btn_check_holo_light) that varies with configuration!!
I/art ( 148): Explicit concurrent mark sweep GC freed 451(54KB) AllocSpace objects, 0(0B) LOS objects, 40% free, 1558KB/2MB, paused 311us total 11.931ms
W/Resources( 148): Preloaded drawable resource #0x10800e2 (android:drawable/btn_check_holo_dark) that varies with configuration!!
I/art ( 148): Explicit concurrent mark sweep GC freed 456(61KB) AllocSpace objects, 0(0B) LOS objects, 39% free, 1556KB/2MB, paused 467us total 11.962ms
W/Resources( 148): Preloaded drawable resource #0x10801bd (android:drawable/btn_radio_on_pressed_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10801bc (android:drawable/btn_radio_on_pressed_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10801b9 (android:drawable/btn_radio_on_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10801b8 (android:drawable/btn_radio_on_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10801b6 (android:drawable/btn_radio_on_focused_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10801b5 (android:drawable/btn_radio_on_focused_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10801b4 (android:drawable/btn_radio_on_disabled_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10801b3 (android:drawable/btn_radio_on_disabled_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10801b2 (android:drawable/btn_radio_on_disabled_focused_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10801b1 (android:drawable/btn_radio_on_disabled_focused_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10801ae (android:drawable/btn_radio_off_pressed_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10801ad (android:drawable/btn_radio_off_pressed_holo_dark) that varies with configuration!!
I/art ( 148): Explicit concurrent mark sweep GC freed 349(53KB) AllocSpace objects, 0(0B) LOS objects, 40% free, 1553KB/2MB, paused 304us total 11.663ms
W/Resources( 148): Preloaded drawable resource #0x10801ab (android:drawable/btn_radio_off_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10801aa (android:drawable/btn_radio_off_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10801a8 (android:drawable/btn_radio_off_focused_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10801a7 (android:drawable/btn_radio_off_focused_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10801a6 (android:drawable/btn_radio_off_disabled_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10801a5 (android:drawable/btn_radio_off_disabled_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10801a4 (android:drawable/btn_radio_off_disabled_focused_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10801a3 (android:drawable/btn_radio_off_disabled_focused_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x108014e (android:drawable/btn_default_pressed_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x108014d (android:drawable/btn_default_pressed_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x108014a (android:drawable/btn_default_normal_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080149 (android:drawable/btn_default_normal_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080140 (android:drawable/btn_default_focused_holo_light) that varies with configuration!!
I/art ( 148): Explicit concurrent mark sweep GC freed 349(48KB) AllocSpace objects, 0(0B) LOS objects, 39% free, 1556KB/2MB, paused 311us total 11.704ms
W/Resources( 148): Preloaded drawable resource #0x108013f (android:drawable/btn_default_focused_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x108013d (android:drawable/btn_default_disabled_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x108013c (android:drawable/btn_default_disabled_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x108013a (android:drawable/btn_default_disabled_focused_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080139 (android:drawable/btn_default_disabled_focused_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080141 (android:drawable/btn_default_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080142 (android:drawable/btn_default_holo_light) that varies with configuration!!
I/art ( 148): Explicit concurrent mark sweep GC freed 579(62KB) AllocSpace objects, 0(0B) LOS objects, 39% free, 1571KB/2MB, paused 306us total 12.104ms
W/Resources( 148): Preloaded drawable resource #0x108021e (android:drawable/btn_star_off_normal_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080228 (android:drawable/btn_star_on_normal_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080224 (android:drawable/btn_star_on_disabled_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x108021a (android:drawable/btn_star_off_disabled_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x108022a (android:drawable/btn_star_on_pressed_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080220 (android:drawable/btn_star_off_pressed_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080226 (android:drawable/btn_star_on_focused_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x108021c (android:drawable/btn_star_off_focused_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080222 (android:drawable/btn_star_on_disabled_focused_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080218 (android:drawable/btn_star_off_disabled_focused_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080213 (android:drawable/btn_star_holo_light) that varies with configuration!!
I/art ( 148): Explicit concurrent mark sweep GC freed 785(82KB) AllocSpace objects, 0(0B) LOS objects, 40% free, 1590KB/2MB, paused 315us total 13.327ms
W/Resources( 148): Preloaded drawable resource #0x108021d (android:drawable/btn_star_off_normal_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080227 (android:drawable/btn_star_on_normal_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080223 (android:drawable/btn_star_on_disabled_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080219 (android:drawable/btn_star_off_disabled_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080229 (android:drawable/btn_star_on_pressed_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x108021f (android:drawable/btn_star_off_pressed_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080225 (android:drawable/btn_star_on_focused_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x108021b (android:drawable/btn_star_off_focused_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080221 (android:drawable/btn_star_on_disabled_focused_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080217 (android:drawable/btn_star_off_disabled_focused_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080212 (android:drawable/btn_star_holo_dark) that varies with configuration!!
I/art ( 148): Explicit concurrent mark sweep GC freed 728(98KB) AllocSpace objects, 0(0B) LOS objects, 39% free, 1592KB/2MB, paused 317us total 11.666ms
W/Resources( 148): Preloaded drawable resource #0x108025e (android:drawable/btn_toggle_on_pressed_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x108025d (android:drawable/btn_toggle_on_pressed_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x108025c (android:drawable/btn_toggle_on_normal_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x108025b (android:drawable/btn_toggle_on_normal_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x108025a (android:drawable/btn_toggle_on_focused_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080259 (android:drawable/btn_toggle_on_focused_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080258 (android:drawable/btn_toggle_on_disabled_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080257 (android:drawable/btn_toggle_on_disabled_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080256 (android:drawable/btn_toggle_on_disabled_focused_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080255 (android:drawable/btn_toggle_on_disabled_focused_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080253 (android:drawable/btn_toggle_off_pressed_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080252 (android:drawable/btn_toggle_off_pressed_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080251 (android:drawable/btn_toggle_off_normal_holo_light) that varies with configuration!!
I/art ( 148): Explicit concurrent mark sweep GC freed 446(80KB) AllocSpace objects, 0(0B) LOS objects, 39% free, 1564KB/2MB, paused 316us total 11.500ms
W/Resources( 148): Preloaded drawable resource #0x1080250 (android:drawable/btn_toggle_off_normal_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x108024f (android:drawable/btn_toggle_off_focused_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x108024e (android:drawable/btn_toggle_off_focused_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x108024d (android:drawable/btn_toggle_off_disabled_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x108024c (android:drawable/btn_toggle_off_disabled_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x108024b (android:drawable/btn_toggle_off_disabled_focused_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x108024a (android:drawable/btn_toggle_off_disabled_focused_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080246 (android:drawable/btn_toggle_holo_light) that varies with configuration!!
I/art ( 148): Explicit concurrent mark sweep GC freed 643(63KB) AllocSpace objects, 0(0B) LOS objects, 39% free, 1585KB/2MB, paused 315us total 12.484ms
W/Resources( 148): Preloaded drawable resource #0x1080245 (android:drawable/btn_toggle_holo_dark) that varies with configuration!!
I/art ( 148): Explicit concurrent mark sweep GC freed 612(74KB) AllocSpace objects, 0(0B) LOS objects, 39% free, 1568KB/2MB, paused 317us total 17.955ms
W/Resources( 148): Preloaded drawable resource #0x108071d (android:drawable/textfield_multiline_default_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080721 (android:drawable/textfield_multiline_disabled_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x108071b (android:drawable/textfield_multiline_activated_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080723 (android:drawable/textfield_multiline_focused_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x108071f (android:drawable/textfield_multiline_disabled_focused_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x108070f (android:drawable/textfield_default_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080715 (android:drawable/textfield_disabled_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080706 (android:drawable/textfield_activated_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080718 (android:drawable/textfield_focused_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080713 (android:drawable/textfield_disabled_focused_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10802c6 (android:drawable/edit_text_holo_light) that varies with configuration!!
I/art ( 148): Explicit concurrent mark sweep GC freed 527(57KB) AllocSpace objects, 0(0B) LOS objects, 39% free, 1569KB/2MB, paused 315us total 14.526ms
W/Resources( 148): Preloaded drawable resource #0x108071c (android:drawable/textfield_multiline_default_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080720 (android:drawable/textfield_multiline_disabled_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x108071a (android:drawable/textfield_multiline_activated_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080722 (android:drawable/textfield_multiline_focused_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x108071e (android:drawable/textfield_multiline_disabled_focused_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x108070e (android:drawable/textfield_default_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080714 (android:drawable/textfield_disabled_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080705 (android:drawable/textfield_activated_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080717 (android:drawable/textfield_focused_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080712 (android:drawable/textfield_disabled_focused_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10802c5 (android:drawable/edit_text_holo_dark) that varies with configuration!!
I/art ( 148): Explicit concurrent mark sweep GC freed 527(56KB) AllocSpace objects, 0(0B) LOS objects, 40% free, 1571KB/2MB, paused 318us total 13.841ms
W/Resources( 148): Preloaded drawable resource #0x10806fc (android:drawable/text_select_handle_left) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080702 (android:drawable/text_select_handle_right) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10806f9 (android:drawable/text_edit_paste_window) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10802dd (android:drawable/expander_close_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10802de (android:drawable/expander_close_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10802e6 (android:drawable/expander_open_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10802e1 (android:drawable/expander_group_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10802e7 (android:drawable/expander_open_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10802e2 (android:drawable/expander_group_holo_light) that varies with configuration!!
I/art ( 148): Explicit concurrent mark sweep GC freed 421(50KB) AllocSpace objects, 0(0B) LOS objects, 40% free, 1573KB/2MB, paused 311us total 19.208ms
W/Resources( 148): Preloaded drawable resource #0x10804bd (android:drawable/list_selector_disabled_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x108049c (android:drawable/list_pressed_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x108049a (android:drawable/list_longpressed_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10804ba (android:drawable/list_selector_background_transition_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080495 (android:drawable/list_focused_holo) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10804c1 (android:drawable/list_selector_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10804be (android:drawable/list_selector_disabled_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x108049d (android:drawable/list_pressed_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x108049b (android:drawable/list_longpressed_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10804bb (android:drawable/list_selector_background_transition_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10804c2 (android:drawable/list_selector_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x108049f (android:drawable/list_section_divider_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x108049e (android:drawable/list_section_divider_holo_dark) that varies with configuration!!
I/art ( 148): Explicit concurrent mark sweep GC freed 615(64KB) AllocSpace objects, 0(0B) LOS objects, 39% free, 1560KB/2MB, paused 316us total 12.338ms
W/Resources( 148): Preloaded drawable resource #0x10804d2 (android:drawable/menu_hardkey_panel_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10804d3 (android:drawable/menu_hardkey_panel_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10804da (android:drawable/menu_submenu_background) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10804d1 (android:drawable/menu_dropdown_panel_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10804d0 (android:drawable/menu_dropdown_panel_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10804d7 (android:drawable/menu_popup_panel_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10804d6 (android:drawable/menu_popup_panel_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10804d5 (android:drawable/menu_panel_holo_light) that varies with configuration!!
I/art ( 148): Explicit concurrent mark sweep GC freed 452(31KB) AllocSpace objects, 0(0B) LOS objects, 39% free, 1588KB/2MB, paused 315us total 11.918ms
W/Resources( 148): Preloaded drawable resource #0x10804d4 (android:drawable/menu_panel_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080607 (android:drawable/spinner_16_outer_holo) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080606 (android:drawable/spinner_16_inner_holo) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080609 (android:drawable/spinner_48_outer_holo) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080608 (android:drawable/spinner_48_inner_holo) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x108060b (android:drawable/spinner_76_outer_holo) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x108060a (android:drawable/spinner_76_inner_holo) that varies with configuration!!
I/art ( 148): Explicit concurrent mark sweep GC freed 310(56KB) AllocSpace objects, 0(0B) LOS objects, 40% free, 1594KB/2MB, paused 341us total 11.855ms
W/Resources( 148): Preloaded drawable resource #0x1080560 (android:drawable/progress_bg_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080561 (android:drawable/progress_bg_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080572 (android:drawable/progress_secondary_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080570 (android:drawable/progress_primary_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080562 (android:drawable/progress_horizontal_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080573 (android:drawable/progress_secondary_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080571 (android:drawable/progress_primary_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080563 (android:drawable/progress_horizontal_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x108057c (android:drawable/progressbar_indeterminate_holo1) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x108057d (android:drawable/progressbar_indeterminate_holo2) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x108057e (android:drawable/progressbar_indeterminate_holo3) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x108057f (android:drawable/progressbar_indeterminate_holo4) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080580 (android:drawable/progressbar_indeterminate_holo5) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080581 (android:drawable/progressbar_indeterminate_holo6) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080582 (android:drawable/progressbar_indeterminate_holo7) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080583 (android:drawable/progressbar_indeterminate_holo8) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080565 (android:drawable/progress_indeterminate_horizontal_holo) that varies with configuration!!
I/art ( 148): Explicit concurrent mark sweep GC freed 508(76KB) AllocSpace objects, 0(0B) LOS objects, 39% free, 1729KB/2MB, paused 318us total 11.998ms
W/Resources( 148): Preloaded drawable resource #0x1080568 (android:drawable/progress_large_holo) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x108056c (android:drawable/progress_medium_holo) that varies with configuration!!
I/art ( 148): Explicit concurrent mark sweep GC freed 349(191KB) AllocSpace objects, 0(0B) LOS objects, 40% free, 1587KB/2MB, paused 361us total 13.651ms
W/Resources( 148): Preloaded drawable resource #0x1080575 (android:drawable/progress_small_holo) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10805ee (android:drawable/scrubber_track_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10805ed (android:drawable/scrubber_secondary_holo) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10805e8 (android:drawable/scrubber_primary_holo) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10805ea (android:drawable/scrubber_progress_horizontal_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10805ef (android:drawable/scrubber_track_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10805eb (android:drawable/scrubber_progress_horizontal_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10805cc (android:drawable/scrollbar_handle_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10805cd (android:drawable/scrollbar_handle_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x108062e (android:drawable/spinner_disabled_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x108063c (android:drawable/spinner_pressed_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080634 (android:drawable/spinner_focused_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080629 (android:drawable/spinner_default_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080622 (android:drawable/spinner_background_holo_dark) that varies with configuration!!
I/art ( 148): Explicit concurrent mark sweep GC freed 555(69KB) AllocSpace objects, 0(0B) LOS objects, 39% free, 1580KB/2MB, paused 333us total 12.281ms
W/Resources( 148): Preloaded drawable resource #0x1080630 (android:drawable/spinner_disabled_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x108063e (android:drawable/spinner_pressed_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080636 (android:drawable/spinner_focused_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x108062b (android:drawable/spinner_default_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080623 (android:drawable/spinner_background_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x108060e (android:drawable/spinner_ab_default_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080610 (android:drawable/spinner_ab_default_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080612 (android:drawable/spinner_ab_disabled_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080614 (android:drawable/spinner_ab_disabled_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080616 (android:drawable/spinner_ab_focused_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080618 (android:drawable/spinner_ab_focused_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x108061c (android:drawable/spinner_ab_pressed_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x108061e (android:drawable/spinner_ab_pressed_holo_light) that varies with configuration!!
I/art ( 148): Explicit concurrent mark sweep GC freed 649(44KB) AllocSpace objects, 0(0B) LOS objects, 39% free, 1588KB/2MB, paused 324us total 13.900ms
W/Resources( 148): Preloaded drawable resource #0x108061a (android:drawable/spinner_ab_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x108061b (android:drawable/spinner_ab_holo_light) that varies with configuration!!
I/art ( 148): Explicit concurrent mark sweep GC freed 582(50KB) AllocSpace objects, 0(0B) LOS objects, 40% free, 1588KB/2MB, paused 315us total 12.004ms
W/Resources( 148): Preloaded drawable resource #0x108026f (android:drawable/cab_background_bottom_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080274 (android:drawable/cab_background_top_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080270 (android:drawable/cab_background_bottom_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x108032f (android:drawable/ic_cab_done_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080273 (android:drawable/cab_background_top_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080330 (android:drawable/ic_cab_done_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10800d5 (android:drawable/btn_cab_done_default_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10800d8 (android:drawable/btn_cab_done_focused_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10800d6 (android:drawable/btn_cab_done_default_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10800dd (android:drawable/btn_cab_done_pressed_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10800d7 (android:drawable/btn_cab_done_focused_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10800de (android:drawable/btn_cab_done_pressed_holo_light) that varies with configuration!!
I/art ( 148): Explicit concurrent mark sweep GC freed 590(52KB) AllocSpace objects, 0(0B) LOS objects, 39% free, 1586KB/2MB, paused 324us total 13.683ms
W/Resources( 148): Preloaded drawable resource #0x10800da (android:drawable/btn_cab_done_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10800d9 (android:drawable/btn_cab_done_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080038 (android:drawable/ic_menu_close_clear_cancel) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10803d1 (android:drawable/ic_menu_copy_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10803d2 (android:drawable/ic_menu_copy_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10803d5 (android:drawable/ic_menu_cut_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10803d6 (android:drawable/ic_menu_cut_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080045 (android:drawable/ic_menu_more) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10803ed (android:drawable/ic_menu_moreoverflow_normal_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10803ea (android:drawable/ic_menu_moreoverflow_holo_dark) that varies with configuration!!
I/art ( 148): Explicit concurrent mark sweep GC freed 546(48KB) AllocSpace objects, 0(0B) LOS objects, 39% free, 1590KB/2MB, paused 342us total 12.098ms
W/Resources( 148): Preloaded drawable resource #0x10803ee (android:drawable/ic_menu_moreoverflow_normal_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10803eb (android:drawable/ic_menu_moreoverflow_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10803f1 (android:drawable/ic_menu_paste_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10803f2 (android:drawable/ic_menu_paste_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10803fb (android:drawable/ic_menu_selectall_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10803fa (android:drawable/ic_menu_selectall_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080334 (android:drawable/ic_clear_disabled) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080339 (android:drawable/ic_clear_normal) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080333 (android:drawable/ic_clear) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x108042e (android:drawable/ic_search_api_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x108042f (android:drawable/ic_search_api_holo_light) that varies with configuration!!
I/art ( 148): Explicit concurrent mark sweep GC freed 422(48KB) AllocSpace objects, 0(0B) LOS objects, 39% free, 1592KB/2MB, paused 318us total 12.221ms
W/Resources( 148): Preloaded drawable resource #0x1080361 (android:drawable/ic_go) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x108043c (android:drawable/ic_voice_search_api_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x108043d (android:drawable/ic_voice_search_api_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x108028f (android:drawable/dialog_bottom_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080290 (android:drawable/dialog_bottom_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080294 (android:drawable/dialog_full_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080295 (android:drawable/dialog_full_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x108029d (android:drawable/dialog_middle_holo_dark) that varies with configuration!!
I/art ( 148): Explicit concurrent mark sweep GC freed 266(37KB) AllocSpace objects, 0(0B) LOS objects, 40% free, 1604KB/2MB, paused 306us total 11.730ms
W/Resources( 148): Preloaded drawable resource #0x108029e (android:drawable/dialog_middle_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x108029f (android:drawable/dialog_top_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10802a0 (android:drawable/dialog_top_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080350 (android:drawable/ic_dialog_alert_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080351 (android:drawable/ic_dialog_alert_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080490 (android:drawable/list_divider_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080491 (android:drawable/list_divider_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10800c1 (android:drawable/ab_transparent_dark_holo) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10800bf (android:drawable/ab_stacked_transparent_dark_holo) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10800a1 (android:drawable/ab_bottom_transparent_dark_holo) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10800b7 (android:drawable/ab_solid_dark_holo) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10800bc (android:drawable/ab_stacked_solid_dark_holo) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x108009e (android:drawable/ab_bottom_solid_dark_holo) that varies with configuration!!
I/art ( 148): Explicit concurrent mark sweep GC freed 357(56KB) AllocSpace objects, 0(0B) LOS objects, 40% free, 1600KB/2MB, paused 314us total 13.550ms
W/Resources( 148): Preloaded drawable resource #0x10800c2 (android:drawable/ab_transparent_light_holo) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10800c0 (android:drawable/ab_stacked_transparent_light_holo) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10800a2 (android:drawable/ab_bottom_transparent_light_holo) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10800b8 (android:drawable/ab_solid_light_holo) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10800be (android:drawable/ab_stacked_solid_light_holo) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10800a0 (android:drawable/ab_bottom_solid_light_holo) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10800b9 (android:drawable/ab_solid_shadow_holo) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x108044e (android:drawable/item_background_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x108044f (android:drawable/item_background_holo_light) that varies with configuration!!
I/art ( 148): Explicit concurrent mark sweep GC freed 736(69KB) AllocSpace objects, 0(0B) LOS objects, 39% free, 1596KB/2MB, paused 315us total 12.123ms
W/Resources( 148): Preloaded drawable resource #0x10802f2 (android:drawable/fastscroll_thumb_pressed_holo) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10802ef (android:drawable/fastscroll_thumb_default_holo) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10802f0 (android:drawable/fastscroll_thumb_holo) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10802f8 (android:drawable/fastscroll_track_pressed_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10802f3 (android:drawable/fastscroll_track_default_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10802f5 (android:drawable/fastscroll_track_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10802e9 (android:drawable/fastscroll_label_left_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10802ec (android:drawable/fastscroll_label_right_holo_dark) that varies with configuration!!
I/art ( 148): Explicit concurrent mark sweep GC freed 551(43KB) AllocSpace objects, 0(0B) LOS objects, 40% free, 1614KB/2MB, paused 320us total 19.393ms
W/Resources( 148): Preloaded drawable resource #0x10802f9 (android:drawable/fastscroll_track_pressed_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10802f4 (android:drawable/fastscroll_track_default_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10802f6 (android:drawable/fastscroll_track_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10802ea (android:drawable/fastscroll_label_left_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10802ed (android:drawable/fastscroll_label_right_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10802ca (android:drawable/editbox_dropdown_background_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080736 (android:drawable/textfield_search_selected_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080728 (android:drawable/textfield_search_default_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080738 (android:drawable/textfield_searchview_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080733 (android:drawable/textfield_search_right_selected_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080731 (android:drawable/textfield_search_right_default_holo_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x108073a (android:drawable/textfield_searchview_right_holo_dark) that varies with configuration!!
I/art ( 148): Explicit concurrent mark sweep GC freed 412(64KB) AllocSpace objects, 0(0B) LOS objects, 40% free, 1606KB/2MB, paused 388us total 17.889ms
W/Resources( 148): Preloaded drawable resource #0x1080737 (android:drawable/textfield_search_selected_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080729 (android:drawable/textfield_search_default_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080739 (android:drawable/textfield_searchview_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080734 (android:drawable/textfield_search_right_selected_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080732 (android:drawable/textfield_search_right_default_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x108073b (android:drawable/textfield_searchview_right_holo_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10806f2 (android:drawable/tab_unselected_holo) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10806ed (android:drawable/tab_selected_holo) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10806f1 (android:drawable/tab_unselected_focused_holo) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10806ec (android:drawable/tab_selected_focused_holo) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10806f3 (android:drawable/tab_unselected_pressed_holo) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10806ee (android:drawable/tab_selected_pressed_holo) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10806df (android:drawable/tab_indicator_holo) that varies with configuration!!
I/art ( 148): Explicit concurrent mark sweep GC freed 665(67KB) AllocSpace objects, 0(0B) LOS objects, 40% free, 1589KB/2MB, paused 323us total 12.765ms
W/Resources( 148): Preloaded drawable resource #0x1080596 (android:drawable/quickcontact_badge_overlay_pressed_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x108058d (android:drawable/quickcontact_badge_overlay_focused_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080592 (android:drawable/quickcontact_badge_overlay_normal_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x108058c (android:drawable/quickcontact_badge_overlay_dark) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080598 (android:drawable/quickcontact_badge_overlay_pressed_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x108058f (android:drawable/quickcontact_badge_overlay_focused_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080594 (android:drawable/quickcontact_badge_overlay_normal_light) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080591 (android:drawable/quickcontact_badge_overlay_light) that varies with configuration!!
I/art ( 148): Explicit concurrent mark sweep GC freed 645(38KB) AllocSpace objects, 0(0B) LOS objects, 39% free, 1601KB/2MB, paused 319us total 25.300ms
W/Resources( 148): Preloaded drawable resource #0x10800b5 (android:drawable/ab_share_pack_material) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10800ba (android:drawable/ab_solid_shadow_material) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10800db (android:drawable/btn_cab_done_material) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10800e5 (android:drawable/btn_check_material_anim) that varies with configuration!!
I/art ( 148): Explicit concurrent mark sweep GC freed 830(54KB) AllocSpace objects, 0(0B) LOS objects, 39% free, 1685KB/2MB, paused 328us total 20.447ms
W/Resources( 148): Preloaded drawable resource #0x10801a1 (android:drawable/btn_radio_material_anim) that varies with configuration!!
I/art ( 148): Explicit concurrent mark sweep GC freed 837(123KB) AllocSpace objects, 0(0B) LOS objects, 39% free, 1685KB/2MB, paused 333us total 14.162ms
W/Resources( 148): Preloaded drawable resource #0x1080215 (android:drawable/btn_star_material) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080248 (android:drawable/btn_toggle_material) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080271 (android:drawable/cab_background_bottom_material) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080275 (android:drawable/cab_background_top_material) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x108028e (android:drawable/dialog_background_shadow_material) that varies with configuration!!
I/art ( 148): Explicit concurrent mark sweep GC freed 527(107KB) AllocSpace objects, 0(0B) LOS objects, 39% free, 1641KB/2MB, paused 320us total 15.748ms
W/Resources( 148): Preloaded drawable resource #0x10802c7 (android:drawable/edit_text_material) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10802e3 (android:drawable/expander_group_material) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080343 (android:drawable/ic_commit_search_api_material) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x108035b (android:drawable/ic_find_next_material) that varies with configuration!!
I/art ( 148): Explicit concurrent mark sweep GC freed 699(68KB) AllocSpace objects, 0(0B) LOS objects, 39% free, 1624KB/2MB, paused 331us total 14.877ms
W/Resources( 148): Preloaded drawable resource #0x108035f (android:drawable/ic_find_previous_material) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10803ab (android:drawable/ic_media_route_connecting_material) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10803b1 (android:drawable/ic_media_route_material) that varies with configuration!!
I/art ( 148): Explicit concurrent mark sweep GC freed 565(36KB) AllocSpace objects, 0(0B) LOS objects, 40% free, 1639KB/2MB, paused 323us total 22.740ms
W/Resources( 148): Preloaded drawable resource #0x10803dd (android:drawable/ic_menu_find_material) that varies with configuration!!
I/art ( 148): Explicit concurrent mark sweep GC freed 1224(71KB) AllocSpace objects, 0(0B) LOS objects, 39% free, 1618KB/2MB, paused 474us total 17.861ms
W/Resources( 148): Preloaded drawable resource #0x10803f8 (android:drawable/ic_menu_search_material) that varies with configuration!!
I/art ( 148): Explicit concurrent mark sweep GC freed 1518(54KB) AllocSpace objects, 0(0B) LOS objects, 39% free, 1630KB/2MB, paused 349us total 12.167ms
I/art ( 148): Explicit concurrent mark sweep GC freed 1386(50KB) AllocSpace objects, 0(0B) LOS objects, 39% free, 1635KB/2MB, paused 429us total 12.175ms
W/Resources( 148): Preloaded drawable resource #0x1080493 (android:drawable/list_divider_material) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10804a0 (android:drawable/list_section_divider_material) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080564 (android:drawable/progress_horizontal_material) that varies with configuration!!
I/art ( 148): Explicit concurrent mark sweep GC freed 1523(61KB) AllocSpace objects, 0(0B) LOS objects, 39% free, 1674KB/2MB, paused 324us total 15.410ms
W/Resources( 148): Preloaded drawable resource #0x10805ba (android:drawable/ratingbar_full_empty_material) that varies with configuration!!
I/art ( 148): Explicit concurrent mark sweep GC freed 684(32KB) AllocSpace objects, 0(0B) LOS objects, 40% free, 1703KB/2MB, paused 323us total 12.892ms
W/Resources( 148): Preloaded drawable resource #0x10805be (android:drawable/ratingbar_full_filled_material) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10805c1 (android:drawable/ratingbar_full_material) that varies with configuration!!
I/art ( 148): Explicit concurrent mark sweep GC freed 411(32KB) AllocSpace objects, 0(0B) LOS objects, 39% free, 1727KB/2MB, paused 331us total 20.479ms
W/Resources( 148): Preloaded drawable resource #0x10805d9 (android:drawable/scrubber_control_material_anim) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10805e1 (android:drawable/scrubber_control_selector_material) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10805ec (android:drawable/scrubber_progress_horizontal_material) that varies with configuration!!
I/art ( 148): Explicit concurrent mark sweep GC freed 464(69KB) AllocSpace objects, 0(0B) LOS objects, 40% free, 1713KB/2MB, paused 333us total 12.942ms
W/Resources( 148): Preloaded drawable resource #0x1080624 (android:drawable/spinner_background_material) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080641 (android:drawable/spinner_textfield_background_material) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10806b1 (android:drawable/switch_thumb_material_anim) that varies with configuration!!
I/art ( 148): Explicit concurrent mark sweep GC freed 834(51KB) AllocSpace objects, 0(0B) LOS objects, 40% free, 1766KB/2MB, paused 333us total 12.908ms
W/Resources( 148): Preloaded drawable resource #0x10806b6 (android:drawable/switch_track_material) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10806e0 (android:drawable/tab_indicator_material) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10806f7 (android:drawable/text_cursor_material) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x108072f (android:drawable/textfield_search_material) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x10806fd (android:drawable/text_select_handle_left_material) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080700 (android:drawable/text_select_handle_middle_material) that varies with configuration!!
W/Resources( 148): Preloaded drawable resource #0x1080703 (android:drawable/text_select_handle_right_material) that varies with configuration!!
I/Zygote ( 148): ...preloaded 343 resources in 2193ms.
I/art ( 148): Explicit concurrent mark sweep GC freed 1156(114KB) AllocSpace objects, 0(0B) LOS objects, 39% free, 1706KB/2MB, paused 340us total 20.846ms
I/Zygote ( 148): ...preloaded 41 resources in 40ms.
D/libEGL ( 148): loaded /system/lib/egl/libGLES_android.so
E/sdcard ( 150): missing packages.list; retrying
I/Zygote ( 148): Preloading shared libraries...
D/Zygote ( 148): end preload
I/art ( 148): Explicit concurrent mark sweep GC freed 581(33KB) AllocSpace objects, 0(0B) LOS objects, 40% free, 1711KB/2MB, paused 512us total 16.366ms
I/art ( 148): Explicit concurrent mark sweep GC freed 389(16KB) AllocSpace objects, 0(0B) LOS objects, 40% free, 1695KB/2MB, paused 340us total 14.323ms
I/art ( 148): Explicit concurrent mark sweep GC freed 5(160B) AllocSpace objects, 0(0B) LOS objects, 40% free, 1695KB/2MB, paused 318us total 20.041ms
I/Zygote ( 148): System server process 401 has been created
I/Zygote ( 148): Accepting command socket connections
I/InstallerConnection( 401): connecting...
I/installd( 144): new connection
E/cutils-trace( 414): Error opening trace file: Permission denied (13)
I/dex2oat ( 414): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/framework/services.jar --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@framework@services.jar@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 414): Decided to run without swap.
W/dex2oat ( 414): Compilation of android.content.pm.PackageParser$Package com.android.server.pm.PackageManagerService.scanPackageDirtyLI(android.content.pm.PackageParser$Package, int, int, long, android.os.UserHandle) took 166.673ms
I/dex2oat ( 414): dex2oat took 24.282s (threads: 1) arena alloc=3MB java alloc=4MB native alloc=15MB free=4MB
E/cutils-trace( 416): Error opening trace file: Permission denied (13)
I/dex2oat ( 416): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/framework/ethernet-service.jar --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@framework@ethernet-service.jar@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 416): Decided to run without swap.
I/dex2oat ( 416): dex2oat took 169.728ms (threads: 1) arena alloc=35KB java alloc=67KB native alloc=557KB free=3MB
E/cutils-trace( 418): Error opening trace file: Permission denied (13)
I/dex2oat ( 418): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/framework/wifi-service.jar --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@framework@wifi-service.jar@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 418): Decided to run without swap.
I/dex2oat ( 418): dex2oat took 3.292s (threads: 1) arena alloc=1557KB java alloc=888KB native alloc=3MB free=4MB
I/InstallerConnection( 401): disconnecting...
E/installd( 144): eof
E/installd( 144): failed to read size
I/installd( 144): closing connection
W/SystemServer( 401): System clock is before 1970; setting to 1970.
I/SystemServer( 401): Entered the Android system server!
V/Fingerprint-JNI( 401): FingerprintManager JNI ready.
D/SensorService( 401): nuSensorService starting...
E/SensorService( 401): couldn't load sensors module (No such file or directory)
I/SystemServiceManager( 401): Starting com.android.server.pm.Installer
I/Installer( 401): Waiting for installd to be ready.
I/SystemServiceManager( 401): Starting com.android.server.am.ActivityManagerService$Lifecycle
I/ActivityManager( 401): Memory class: 80
I/ServiceThread( 401): Enabled StrictMode logging for ActivityManager looper.
W/BatteryStatsImpl( 401): Couldn't get kernel wake lock stats
I/AppOps ( 401): No existing app ops /data/system/appops.xml; starting empty
I/IntentFirewall( 401): Read new rules (A:0 B:0 S:0)
I/ServiceThread( 401): Enabled StrictMode logging for android.ui looper.
I/ServiceThread( 401): Enabled StrictMode logging for android.display looper.
D/AppOps ( 401): AppOpsService published
I/SystemServiceManager( 401): Starting com.android.server.power.PowerManagerService
I/ServiceThread( 401): Enabled StrictMode logging for PowerManagerService looper.
E/SWITCHPROFILE( 401): setprop: sys.interactive = active
W/libsuspend( 401): Error writing 'on' to /sys/power/state: Invalid argument
I/libsuspend( 401): Selected wakeup count
I/SWITCHPROFILE( 401): Switchprofile thread received GOV_INTERACTIVE from Power HAL
I/SystemServiceManager( 401): Starting com.android.server.display.DisplayManagerService
I/DisplayManagerService( 401): Display device added: DisplayDeviceInfo{"Built-in Screen": uniqueId="local:0", 800 x 480, 60.000004 fps, supportedRefreshRates [60.000004], density 120, 160.0 x 160.421 dpi, appVsyncOff 0, presDeadline 17666666, touch INTERNAL, rotation 0, type BUILT_IN, state UNKNOWN, FLAG_DEFAULT_DISPLAY, FLAG_ROTATES_WITH_CONTENT, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
I/SystemServiceManager( 401): Starting phase 100
I/SystemServer( 401): Package Manager
W/SELinuxMMAC( 401): Error opening /data/system/seapp_hash. Assuming first boot.
W/FileUtils( 401): Failed to chmod(/data/system/packages.list): android.system.ErrnoException: chmod failed: ENOENT (No such file or directory)
W/SystemConfig( 401): No directory /system/etc/sysconfig, skipping
D/SELinuxMMAC( 401): Using policy file /system/etc/security/mac_permissions.xml
I/PackageManager( 401): No settings file; creating initial state
E/cutils-trace( 435): Error opening trace file: Permission denied (13)
I/dex2oat ( 435): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/framework/com.android.location.provider.jar --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@framework@com.android.location.provider.jar@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 435): Decided to run without swap.
I/dex2oat ( 435): dex2oat took 168.373ms (threads: 1) arena alloc=25KB java alloc=73KB native alloc=556KB free=3MB
E/cutils-trace( 437): Error opening trace file: Permission denied (13)
I/dex2oat ( 437): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/framework/com.android.future.usb.accessory.jar --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@framework@com.android.future.usb.accessory.jar@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 437): Decided to run without swap.
I/dex2oat ( 437): dex2oat took 82.724ms (threads: 1) arena alloc=46KB java alloc=11KB native alloc=524KB free=3MB
E/cutils-trace( 439): Error opening trace file: Permission denied (13)
I/dex2oat ( 439): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/framework/javax.obex.jar --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@framework@javax.obex.jar@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 439): Decided to run without swap.
I/dex2oat ( 439): dex2oat took 325.654ms (threads: 1) arena alloc=424KB java alloc=38KB native alloc=913KB free=3MB
E/cutils-trace( 441): Error opening trace file: Permission denied (13)
I/dex2oat ( 441): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/framework/freescale-extended.jar --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@framework@freescale-extended.jar@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 441): Decided to run without swap.
I/dex2oat ( 441): dex2oat took 56.996ms (threads: 1) arena alloc=23KB java alloc=4KB native alloc=522KB free=3MB
E/cutils-trace( 443): Error opening trace file: Permission denied (13)
I/dex2oat ( 443): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/framework/android.test.runner.jar --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@framework@android.test.runner.jar@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 443): Decided to run without swap.
I/dex2oat ( 443): dex2oat took 836.600ms (threads: 1) arena alloc=30KB java alloc=234KB native alloc=968KB free=3MB
E/cutils-trace( 445): Error opening trace file: Permission denied (13)
I/dex2oat ( 445): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/framework/com.android.media.remotedisplay.jar --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@framework@com.android.media.remotedisplay.jar@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 445): Decided to run without swap.
I/dex2oat ( 445): dex2oat took 83.783ms (threads: 1) arena alloc=31KB java alloc=15KB native alloc=531KB free=3MB
E/cutils-trace( 447): Error opening trace file: Permission denied (13)
I/dex2oat ( 447): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/framework/com.android.mediadrm.signer.jar --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@framework@com.android.mediadrm.signer.jar@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 447): Decided to run without swap.
I/dex2oat ( 447): dex2oat took 62.947ms (threads: 1) arena alloc=26KB java alloc=5KB native alloc=523KB free=3MB
E/cutils-trace( 449): Error opening trace file: Permission denied (13)
I/dex2oat ( 449): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/framework/am.jar --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@framework@am.jar@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 449): Decided to run without swap.
I/dex2oat ( 449): dex2oat took 451.691ms (threads: 1) arena alloc=291KB java alloc=35KB native alloc=911KB free=3MB
E/cutils-trace( 451): Error opening trace file: Permission denied (13)
I/dex2oat ( 451): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/framework/appops.jar --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@framework@appops.jar@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 451): Decided to run without swap.
I/dex2oat ( 451): dex2oat took 77.582ms (threads: 1) arena alloc=26KB java alloc=9KB native alloc=529KB free=3MB
E/cutils-trace( 453): Error opening trace file: Permission denied (13)
I/dex2oat ( 453): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/framework/appwidget.jar --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@framework@appwidget.jar@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 453): Decided to run without swap.
I/dex2oat ( 453): dex2oat took 68.958ms (threads: 1) arena alloc=28KB java alloc=5KB native alloc=533KB free=3MB
E/cutils-trace( 455): Error opening trace file: Permission denied (13)
I/dex2oat ( 455): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/framework/bmgr.jar --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@framework@bmgr.jar@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 455): Decided to run without swap.
I/dex2oat ( 455): dex2oat took 108.133ms (threads: 1) arena alloc=74KB java alloc=15KB native alloc=564KB free=3MB
E/cutils-trace( 457): Error opening trace file: Permission denied (13)
I/dex2oat ( 457): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/framework/bu.jar --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@framework@bu.jar@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 457): Decided to run without swap.
I/dex2oat ( 457): dex2oat took 72.344ms (threads: 1) arena alloc=51KB java alloc=8KB native alloc=524KB free=3MB
E/cutils-trace( 459): Error opening trace file: Permission denied (13)
I/dex2oat ( 459): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/framework/content.jar --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@framework@content.jar@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 459): Decided to run without swap.
I/dex2oat ( 459): dex2oat took 114.175ms (threads: 1) arena alloc=28KB java alloc=13KB native alloc=550KB free=3MB
E/cutils-trace( 461): Error opening trace file: Permission denied (13)
I/dex2oat ( 461): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/framework/dpm.jar --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@framework@dpm.jar@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 461): Decided to run without swap.
I/dex2oat ( 461): dex2oat took 79.060ms (threads: 1) arena alloc=26KB java alloc=4KB native alloc=536KB free=3MB
E/cutils-trace( 463): Error opening trace file: Permission denied (13)
I/dex2oat ( 463): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/framework/ime.jar --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@framework@ime.jar@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 463): Decided to run without swap.
I/dex2oat ( 463): dex2oat took 76.200ms (threads: 1) arena alloc=62KB java alloc=6KB native alloc=549KB free=3MB
E/cutils-trace( 465): Error opening trace file: Permission denied (13)
I/dex2oat ( 465): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/framework/input.jar --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@framework@input.jar@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 465): Decided to run without swap.
I/dex2oat ( 465): dex2oat took 82.757ms (threads: 1) arena alloc=58KB java alloc=5KB native alloc=532KB free=3MB
E/cutils-trace( 467): Error opening trace file: Permission denied (13)
I/dex2oat ( 467): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/framework/media_cmd.jar --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@framework@media_cmd.jar@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 467): Decided to run without swap.
I/dex2oat ( 467): dex2oat took 116.422ms (threads: 1) arena alloc=26KB java alloc=29KB native alloc=547KB free=3MB
E/cutils-trace( 469): Error opening trace file: Permission denied (13)
I/dex2oat ( 469): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/framework/monkey.jar --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@framework@monkey.jar@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 469): Decided to run without swap.
I/dex2oat ( 469): dex2oat took 545.765ms (threads: 1) arena alloc=938KB java alloc=119KB native alloc=1567KB free=2MB
E/cutils-trace( 471): Error opening trace file: Permission denied (13)
I/dex2oat ( 471): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/framework/pm.jar --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@framework@pm.jar@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 471): Decided to run without swap.
I/dex2oat ( 471): dex2oat took 240.963ms (threads: 1) arena alloc=69KB java alloc=38KB native alloc=643KB free=3MB
E/cutils-trace( 473): Error opening trace file: Permission denied (13)
I/dex2oat ( 473): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/framework/requestsync.jar --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@framework@requestsync.jar@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 473): Decided to run without swap.
I/dex2oat ( 473): dex2oat took 476.904ms (threads: 1) arena alloc=26KB java alloc=3KB native alloc=533KB free=3MB
E/cutils-trace( 475): Error opening trace file: Permission denied (13)
I/dex2oat ( 475): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/framework/settings.jar --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@framework@settings.jar@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 475): Decided to run without swap.
I/dex2oat ( 475): dex2oat took 79.565ms (threads: 1) arena alloc=239KB java alloc=5KB native alloc=665KB free=3MB
E/cutils-trace( 477): Error opening trace file: Permission denied (13)
I/dex2oat ( 477): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/framework/svc.jar --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@framework@svc.jar@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 477): Decided to run without swap.
I/dex2oat ( 477): dex2oat took 83.442ms (threads: 1) arena alloc=25KB java alloc=13KB native alloc=540KB free=3MB
E/cutils-trace( 479): Error opening trace file: Permission denied (13)
I/dex2oat ( 479): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/framework/uiautomator.jar --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@framework@uiautomator.jar@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 479): Decided to run without swap.
I/dex2oat ( 479): dex2oat took 528.355ms (threads: 1) arena alloc=164KB java alloc=131KB native alloc=666KB free=3MB
E/cutils-trace( 481): Error opening trace file: Permission denied (13)
I/dex2oat ( 481): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/framework/wm.jar --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@framework@wm.jar@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 481): Decided to run without swap.
I/dex2oat ( 481): dex2oat took 73.662ms (threads: 1) arena alloc=26KB java alloc=3KB native alloc=549KB free=3MB
D/PackageManager( 401): No files in app dir /vendor/overlay
I/PackageManager( 401): /system/framework/framework-res.apk changed; collecting certs
I/art ( 401): Background sticky concurrent mark sweep GC freed 11768(452KB) AllocSpace objects, 0(0B) LOS objects, 9% free, 4MB/4MB, paused 5.516ms total 59.011ms
I/art ( 401): Background partial concurrent mark sweep GC freed 6050(284KB) AllocSpace objects, 0(0B) LOS objects, 33% free, 4MB/6MB, paused 5.954ms total 94.416ms
I/art ( 401): Background partial concurrent mark sweep GC freed 8223(427KB) AllocSpace objects, 0(0B) LOS objects, 33% free, 7MB/11MB, paused 1.738ms total 110.170ms
I/art ( 401): Background partial concurrent mark sweep GC freed 138641(6MB) AllocSpace objects, 10(3MB) LOS objects, 33% free, 5MB/8MB, paused 1.044ms total 102.850ms
I/art ( 401): Background partial concurrent mark sweep GC freed 15002(625KB) AllocSpace objects, 3(2MB) LOS objects, 33% free, 7MB/10MB, paused 2.443ms total 105.912ms
I/PackageManager( 401): /system/priv-app/BackupRestoreConfirmation changed; collecting certs
I/PackageManager( 401): /system/priv-app/CalendarProvider changed; collecting certs
I/PackageManager( 401): New shared user android.uid.calendar: id=10001
I/art ( 401): Background partial concurrent mark sweep GC freed 151255(7MB) AllocSpace objects, 5(1490KB) LOS objects, 37% free, 1739KB/2MB, paused 767us total 113.932ms
W/PackageParser( 401): No actions in intent filter at /system/priv-app/Contacts/Contacts.apk Binary XML file line #356
I/PackageManager( 401): /system/priv-app/Contacts changed; collecting certs
I/PackageManager( 401): New shared user android.uid.shared: id=10002
I/PackageManager( 401): /system/priv-app/ContactsProvider changed; collecting certs
I/PackageManager( 401): /system/priv-app/DefaultContainerService changed; collecting certs
W/PackageParser( 401): No actions in intent filter at /system/priv-app/Dialer/Dialer.apk Binary XML file line #166
I/PackageManager( 401): /system/priv-app/Dialer changed; collecting certs
I/PackageManager( 401): /system/priv-app/DownloadProvider changed; collecting certs
I/PackageManager( 401): New shared user android.media: id=10005
I/PackageManager( 401): /system/priv-app/ExternalStorageProvider changed; collecting certs
I/PackageManager( 401): /system/priv-app/FusedLocation changed; collecting certs
I/PackageManager( 401): /system/priv-app/InputDevices changed; collecting certs
I/PackageManager( 401): /system/priv-app/Launcher2 changed; collecting certs
I/PackageManager( 401): /system/priv-app/ManagedProvisioning changed; collecting certs
I/PackageManager( 401): /system/priv-app/MediaProvider changed; collecting certs
I/PackageManager( 401): /system/priv-app/Mms changed; collecting certs
I/PackageManager( 401): /system/priv-app/MmsService changed; collecting certs
I/PackageManager( 401): /system/priv-app/MusicFX changed; collecting certs
I/PackageManager( 401): /system/priv-app/OneTimeInitializer changed; collecting certs
I/PackageManager( 401): /system/priv-app/ProxyHandler changed; collecting certs
I/PackageManager( 401): /system/priv-app/Settings changed; collecting certs
I/art ( 401): Background sticky concurrent mark sweep GC freed 10023(397KB) AllocSpace objects, 2(145KB) LOS objects, 15% free, 3MB/3MB, paused 7.372ms total 44.163ms
I/PackageManager( 401): /system/priv-app/SettingsProvider changed; collecting certs
I/PackageManager( 401): /system/priv-app/SharedStorageBackup changed; collecting certs
I/PackageManager( 401): /system/priv-app/Shell changed; collecting certs
I/PackageManager( 401): /system/priv-app/SystemUI changed; collecting certs
I/PackageManager( 401): New shared user android.uid.systemui: id=10014
W/ResourceType( 401): Failure getting entry for 0x7f08026f (t=7 e=623) (error -75)
I/PackageManager( 401): /system/priv-app/TeleService changed; collecting certs
W/PackageParser( 401): Unknown element under <intent-filter>: android at /system/priv-app/Telecom/Telecom.apk Binary XML file line #232
I/PackageManager( 401): /system/priv-app/Telecom changed; collecting certs
I/PackageManager( 401): /system/priv-app/TelephonyProvider changed; collecting certs
I/PackageManager( 401): /system/priv-app/VpnDialogs changed; collecting certs
I/PackageManager( 401): /system/priv-app/WallpaperCropper changed; collecting certs
I/PackageManager( 401): /system/app/BasicDreams changed; collecting certs
W/PackageParser( 401): No actions in intent filter at /system/app/Bluetooth/Bluetooth.apk Binary XML file line #209
I/PackageManager( 401): /system/app/Bluetooth changed; collecting certs
I/PackageManager( 401): /system/app/Browser changed; collecting certs
I/PackageManager( 401): /system/app/Calculator changed; collecting certs
I/PackageManager( 401): /system/app/Calendar changed; collecting certs
I/PackageManager( 401): /system/app/CaptivePortalLogin changed; collecting certs
I/PackageManager( 401): /system/app/CertInstaller changed; collecting certs
I/PackageManager( 401): /system/app/CubeLiveWallpapers changed; collecting certs
I/PackageManager( 401): /system/app/DeskClock changed; collecting certs
I/PackageManager( 401): /system/app/DocumentsUI changed; collecting certs
I/PackageManager( 401): /system/app/DownloadProviderUi changed; collecting certs
I/PackageManager( 401): /system/app/Email changed; collecting certs
I/art ( 401): WaitForGcToComplete blocked for 47.279ms for cause HeapTrim
I/PackageManager( 401): /system/app/Exchange2 changed; collecting certs
I/PackageManager( 401): /system/app/FSLOta changed; collecting certs
I/PackageManager( 401): /system/app/Gallery changed; collecting certs
I/PackageManager( 401): /system/app/HTMLViewer changed; collecting certs
I/PackageManager( 401): /system/app/KeyChain changed; collecting certs
I/PackageManager( 401): /system/app/LatinIME changed; collecting certs
I/PackageManager( 401): /system/app/LegacyCamera changed; collecting certs
I/PackageManager( 401): /system/app/LiveWallpapers changed; collecting certs
I/PackageManager( 401): /system/app/LiveWallpapersPicker changed; collecting certs
I/PackageManager( 401): /system/app/Music changed; collecting certs
I/PackageManager( 401): /system/app/PacProcessor changed; collecting certs
I/PackageManager( 401): /system/app/PackageInstaller changed; collecting certs
I/PackageManager( 401): /system/app/PicoTts changed; collecting certs
I/PackageManager( 401): /system/app/PrintSpooler changed; collecting certs
I/PackageManager( 401): /system/app/Provision changed; collecting certs
I/PackageManager( 401): /system/app/QuickSearchBox changed; collecting certs
I/PackageManager( 401): /system/app/SoundRecorder changed; collecting certs
I/PackageManager( 401): /system/app/UserDictionaryProvider changed; collecting certs
I/PackageManager( 401): /system/app/ethernet changed; collecting certs
I/PackageManager( 401): /system/app/webview changed; collecting certs
D/PackageManager( 401): No files in app dir /system/vendor/app
D/PackageManager( 401): No files in app dir /oem/app
W/PackageManager( 401): Failed to parse /data/app/ing: No packages found in split
D/PackageManager( 401): No files in app dir /data/app-private
W/PackageManager( 401): Package com.android.camera desires unavailable shared library com.google.android.media.effects; ignoring!
I/PackageManager( 401): Adjusting ABI for : com.android.inputdevices to armeabi-v7a
I/PackageManager( 401): Running dexopt on: /system/priv-app/InputDevices/InputDevices.apk pkg=com.android.inputdevices isa=arm vmSafeMode=false
E/cutils-trace( 483): Error opening trace file: Permission denied (13)
I/dex2oat ( 483): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/priv-app/InputDevices/InputDevices.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@priv-app@InputDevices@InputDevices.apk@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 483): Decided to run without swap.
I/dex2oat ( 483): dex2oat took 65.764ms (threads: 1) arena alloc=23KB java alloc=1984B native alloc=507KB free=3MB
I/PackageManager( 401): Adjusting ABI for : com.android.location.fused to armeabi-v7a
I/PackageManager( 401): Running dexopt on: /system/priv-app/FusedLocation/FusedLocation.apk pkg=com.android.location.fused isa=arm vmSafeMode=false
E/cutils-trace( 485): Error opening trace file: Permission denied (13)
I/dex2oat ( 485): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/priv-app/FusedLocation/FusedLocation.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@priv-app@FusedLocation@FusedLocation.apk@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 485): Decided to run without swap.
I/dex2oat ( 485): dex2oat took 122.167ms (threads: 1) arena alloc=24KB java alloc=44KB native alloc=558KB free=3MB
I/PackageManager( 401): Adjusting ABI for : com.fsl.ethernet to armeabi-v7a
I/PackageManager( 401): Running dexopt on: /system/app/ethernet/ethernet.apk pkg=com.fsl.ethernet isa=arm vmSafeMode=false
E/cutils-trace( 487): Error opening trace file: Permission denied (13)
I/dex2oat ( 487): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/ethernet/ethernet.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@ethernet@ethernet.apk@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 487): Decided to run without swap.
I/dex2oat ( 487): dex2oat took 179.394ms (threads: 1) arena alloc=27KB java alloc=76KB native alloc=578KB free=3MB
I/PackageManager( 401): Adjusting ABI for : com.fsl.android.ota to armeabi-v7a
I/PackageManager( 401): Running dexopt on: /system/app/FSLOta/FSLOta.apk pkg=com.fsl.android.ota isa=arm vmSafeMode=false
E/cutils-trace( 489): Error opening trace file: Permission denied (13)
I/dex2oat ( 489): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/FSLOta/FSLOta.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@FSLOta@FSLOta.apk@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 489): Decided to run without swap.
I/dex2oat ( 489): dex2oat took 358.282ms (threads: 1) arena alloc=156KB java alloc=32KB native alloc=700KB free=3MB
I/PackageManager( 401): Adjusting ABI for : com.android.keychain to armeabi-v7a
I/PackageManager( 401): Running dexopt on: /system/app/KeyChain/KeyChain.apk pkg=com.android.keychain isa=arm vmSafeMode=false
E/cutils-trace( 491): Error opening trace file: Permission denied (13)
I/dex2oat ( 491): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/KeyChain/KeyChain.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@KeyChain@KeyChain.apk@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 491): Decided to run without swap.
I/dex2oat ( 491): dex2oat took 745.019ms (threads: 1) arena alloc=29KB java alloc=75KB native alloc=575KB free=3MB
I/PackageManager( 401): Adjusting ABI for : com.android.providers.settings to armeabi-v7a
I/PackageManager( 401): Running dexopt on: /system/priv-app/SettingsProvider/SettingsProvider.apk pkg=com.android.providers.settings isa=arm vmSafeMode=false
E/cutils-trace( 493): Error opening trace file: Permission denied (13)
I/dex2oat ( 493): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/priv-app/SettingsProvider/SettingsProvider.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@priv-app@SettingsProvider@SettingsProvider.apk@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 493): Decided to run without swap.
I/dex2oat ( 493): dex2oat took 476.788ms (threads: 1) arena alloc=2MB java alloc=107KB native alloc=3MB free=4MB
I/PackageManager( 401): Adjusting ABI for : com.android.server.telecom to armeabi-v7a
I/PackageManager( 401): Running dexopt on: /system/priv-app/Telecom/Telecom.apk pkg=com.android.server.telecom isa=arm vmSafeMode=false
E/cutils-trace( 495): Error opening trace file: Permission denied (13)
I/dex2oat ( 495): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/priv-app/Telecom/Telecom.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@priv-app@Telecom@Telecom.apk@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 495): Decided to run without swap.
I/dex2oat ( 495): dex2oat took 1.631s (threads: 1) arena alloc=278KB java alloc=376KB native alloc=1463KB free=2MB
I/PackageManager( 401): Adjusting ABI for : com.android.settings to armeabi-v7a
I/PackageManager( 401): Running dexopt on: /system/priv-app/Settings/Settings.apk pkg=com.android.settings isa=arm vmSafeMode=false
E/cutils-trace( 497): Error opening trace file: Permission denied (13)
I/dex2oat ( 497): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/priv-app/Settings/Settings.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@priv-app@Settings@Settings.apk@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 497): Decided to run without swap.
I/dex2oat ( 497): dex2oat took 10.012s (threads: 1) arena alloc=798KB java alloc=4MB native alloc=5MB free=2MB
I/PackageManager( 401): Time to scan packages: 31.328 seconds
W/PackageManager( 401): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH in package com.android.providers.calendar
W/PackageManager( 401): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.cl in package com.android.providers.calendar
W/PackageManager( 401): Not granting permission android.permission.GLOBAL_SEARCH to package com.android.quicksearchbox (protectionLevel=18 flags=0x8be45)
W/PackageManager( 401): Not granting permission android.permission.ACCESS_DOWNLOAD_MANAGER to package com.android.browser (protectionLevel=18 flags=0x9be45)
W/PackageManager( 401): Not granting permission android.permission.SEND_DOWNLOAD_COMPLETED_INTENTS to package com.android.browser (protectionLevel=2 flags=0x9be45)
W/PackageManager( 401): Unknown permission android.permission.INSTALL_DRM in package com.android.mms
W/PackageManager( 401): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.mail in package com.android.calendar
W/PackageManager( 401): Not granting permission android.permission.DELETE_PACKAGES to package com.svox.pico (protectionLevel=18 flags=0x8be45)
W/PackageManager( 401): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH in package com.android.settings
W/PackageManager( 401): Unknown permission com.android.smspush.WAPPUSH_MANAGER_BIND in package com.android.phone
W/PackageManager( 401): Not granting permission android.permission.DEVICE_POWER to package com.android.deskclock (protectionLevel=2 flags=0x48be45)
W/PackageManager( 401): Unknown permission com.google.android.gallery3d.permission.GALLERY_PROVIDER in package com.android.bluetooth
W/PackageManager( 401): Unknown permission com.android.gallery3d.permission.GALLERY_PROVIDER in package com.android.bluetooth
I/art ( 401): Explicit concurrent mark sweep GC freed 20566(1290KB) AllocSpace objects, 10(163KB) LOS objects, 33% free, 2MB/3MB, paused 682us total 40.681ms
I/SystemServer( 401): User Service
I/lowmemorykiller( 122): ActivityManager connected
I/SystemServiceManager( 401): Starting com.android.server.lights.LightsService
I/lights ( 401): max backlight file is /sys/class/backlight/pwm-backlight.0/max_brightness
I/lights ( 401): backlight brightness file is /sys/class/backlight/pwm-backlight.0/brightness
I/SystemServiceManager( 401): Starting com.android.server.BatteryService
I/SystemServiceManager( 401): Starting com.android.server.usage.UsageStatsService
I/UsageStatsDatabase( 401): Upgrading from version 0 to 2
I/UsageStatsDatabase( 401): Deleting all usage stats files
I/UsageStatsService( 401): User[0] Rollover scheduled @ 1970-01-02 00:00:00(86400000)
I/SystemServiceManager( 401): Starting com.android.server.webkit.WebViewUpdateService
I/SystemServer( 401): Reading configuration...
I/SystemServer( 401): Scheduling Policy
I/SystemServiceManager( 401): Starting com.android.server.telecom.TelecomLoaderService
I/SystemServer( 401): Telephony Registry
I/SystemServer( 401): Entropy Mixer
W/EntropyMixer( 401): No existing entropy file -- first boot?
I/EntropyMixer( 401): Writing entropy...
I/SystemServer( 401): Account Manager
I/SystemServer( 401): Content Manager
I/SystemServer( 401): System Content Providers
W/ResourcesManager( 401): Asset path '/system/framework/freescale-extended.jar' does not exist or contains no resources.
I/AudioFlinger( 143): Using module 1 has the primary audio interface
I/AudioFlinger( 143): AudioFlinger's thread 0xb58f5000 ready to run
W/audio_hw_primary( 143): out_set_parameters routing=2, ret 0, out -1249269568
W/audio_hw_primary( 143): In channels 2, rate 48000, devices 0x80000004
W/audio_hw_primary( 143): get_input_buffer_size size = 1120, channel_count = 2
I/AudioFlinger( 143): AudioFlinger's thread 0xb598a000 ready to run
I/audio_a2dp_hw( 143): adev_open: adev_open in A2dp_hw module
I/AudioFlinger( 143): loadHwModule() Loaded a2dp audio interface from A2DP Audio HW HAL (audio) handle 5
I/r_submix( 143): adev_open(name=audio_hw_if)
I/r_submix( 143): adev_init_check()
I/AudioFlinger( 143): loadHwModule() Loaded r_submix audio interface from Wifi Display audio HAL (audio) handle 6
I/AudioFlinger( 143): loadHwModule() Loaded usb audio interface from USB audio HW HAL (audio) handle 7
E/SoundTriggerHwService( 143): couldn't load sound trigger module sound_trigger.primary (No such file or directory)
I/SyncManager( 401): No initial accounts
I/SyncManager( 401): No initial status
I/SyncManager( 401): No initial statistics
D/SettingsProvider( 401): Generated and saved new ANDROID_ID [41b7e9758951564c] for user 0
I/SystemServer( 401): Vibrator Service
I/SystemServer( 401): Consumer IR Service
E/ConsumerIrService( 401): Can't open consumer IR HW Module, error: -2
I/SystemServiceManager( 401): Starting com.android.server.AlarmManagerService
I/SystemServer( 401): Init Watchdog
I/SystemServer( 401): Input Manager
I/InputManager( 401): Initializing input manager, mUseDevInputEventForAudioJack=false
I/SystemServer( 401): Window Manager
I/WindowManager( 401): No existing display settings /data/system/display_settings.xml; starting empty
D/PermissionCache( 125): checking android.permission.ACCESS_SURFACE_FLINGER for uid=1000 => granted (677 us)
I/art ( 401): Background sticky concurrent mark sweep GC freed 9549(686KB) AllocSpace objects, 2(32KB) LOS objects, 13% free, 2MB/3MB, paused 5.347ms total 101.371ms
I/InputManager( 401): Starting input manager
D/EventHub( 401): No input device configuration file found for device 'PixArt USB Optical Mouse'.
I/EventHub( 401): New device: id=1, fd=72, path='/dev/input/event1', name='PixArt USB Optical Mouse', classes=0x80000008, configuration='', keyLayout='', keyCharacterMap='', builtinKeyboard=false, wakeMechanism=EPOLLWAKEUP, usingClockIoctl=true
E/EventHub( 401): could not get driver version for /dev/input/mouse0, Not a typewriter
I/SystemServer( 401): Bluetooth Manager Service
D/BluetoothManagerService( 401): Loading stored name and address
D/BluetoothManagerService( 401): Stored bluetooth Name=null,Address=null
I/SystemServer( 401): Input Method Service
E/EventHub( 401): could not get driver version for /dev/input/mice, Not a typewriter
D/EventHub( 401): No input device configuration file found for device 'WM8962 Beep Generator'.
W/InputMethodManagerService( 401): No IME selected. Choose the most applicable IME.
I/InputMethodManagerService( 401): Default found, using com.android.inputmethod.latin/.LatinIME
I/art ( 401): Background partial concurrent mark sweep GC freed 4010(285KB) AllocSpace objects, 1(16KB) LOS objects, 33% free, 2MB/4MB, paused 3.629ms total 120.554ms
I/SystemServer( 401): Accessibility Manager
I/ActivityManager( 401): Config changes=1df8 {1.0 ?mcc?mnc en_US ?layoutDir sw640dp w1066dp h640dp 120dpi lrg long land ?uimode ?night -touch -keyb/h/h -nav/h s.2}
I/EventHub( 401): New device: id=3, fd=75, path='/dev/input/event0', name='20b8000.kpp', classes=0x1, configuration='/system/usr/idc/20b8000_kpp.idc', keyLayout='/system/usr/keylayout/20b8000_kpp.kl', keyCharacterMap='/system/usr/keychars/Generic.kcm', builtinKeyboard=true, wakeMechanism=EPOLLWAKEUP, usingClockIoctl=true
I/InputReader( 401): Device added: id=-1, name='Virtual', sources=0x00000301
I/InputReader( 401): Device added: id=0, name='20b8000.kpp', sources=0x00000101
I/InputReader( 401): Device added: id=1, name='PixArt USB Optical Mouse', sources=0x00002002
I/InputReader( 401): Reconfiguring input devices. changes=0x00000004
I/imx6.gralloc( 401): open gpu gralloc module!
I/ActivityManager( 401): Config changes=500 {1.0 ?mcc?mnc en_US ?layoutDir sw640dp w1066dp h566dp 120dpi lrg land ?uimode ?night -touch -keyb/h/h -nav/h s.3}
I/InputDispatcher( 401): Dropped event because input dispatch is disabled.
I/SystemServer( 401): Mount Service
D/MountService( 401): got storage path: null description: Internal storage primary: true removable: false emulated: true mtpReserve: 100 allowMassStorage: false maxFileSize: 0
D/MountService( 401): addVolumeLocked() StorageVolume:
D/MountService( 401): mStorageId=65537 mPath=/storage/emulated/0 mDescriptionId=17040805
D/MountService( 401): mPrimary=true mRemovable=false mEmulated=true mMtpReserveSpace=100
D/MountService( 401): mAllowMassStorage=false mMaxFileSize=0 mOwner=UserHandle{0} mUuid=null
D/MountService( 401): mUserLabel=null mState=null
D/MountService( 401): got storage path: /storage/extsd description: SD card primary: false removable: true emulated: false mtpReserve: 0 allowMassStorage: false maxFileSize: 0
D/MountService( 401): mStorageId=0 mPath=/storage/extsd mDescriptionId=17040806 mPrimary=false
D/MountService( 401): mRemovable=true mEmulated=false mMtpReserveSpace=0 mAllowMassStorage=false
D/MountService( 401): mMaxFileSize=0 mOwner=null mUuid=null mUserLabel=null mState=null
D/MountService( 401): got storage path: /storage/udisk description: USB storage primary: false removable: true emulated: false mtpReserve: 0 allowMassStorage: false maxFileSize: 0
D/MountService( 401): mStorageId=0 mPath=/storage/udisk mDescriptionId=17040807 mPrimary=false
I/PackageManager( 401): Running dexopt on: /system/priv-app/TelephonyProvider/TelephonyProvider.apk pkg=com.android.providers.telephony isa=arm vmSafeMode=false
D/MountService( 401): volume state changed for /storage/extsd (unmounted -> removed)
D/MountService( 401): volume state changed for /storage/udisk (unmounted -> removed)
I/PackageManager( 401): No secure containers found
E/cutils-trace( 516): Error opening trace file: Permission denied (13)
I/dex2oat ( 516): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/priv-app/TelephonyProvider/TelephonyProvider.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@priv-app@TelephonyProvider@TelephonyProvider.apk@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 516): Decided to run without swap.
I/dex2oat ( 516): dex2oat took 662.742ms (threads: 1) arena alloc=418KB java alloc=112KB native alloc=989KB free=3MB
I/PackageManager( 401): Running dexopt on: /system/priv-app/TeleService/TeleService.apk pkg=com.android.phone isa=arm vmSafeMode=false
E/cutils-trace( 518): Error opening trace file: Permission denied (13)
I/dex2oat ( 518): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/priv-app/TeleService/TeleService.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@priv-app@TeleService@TeleService.apk@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 518): Decided to run without swap.
I/dex2oat ( 518): dex2oat took 3.001s (threads: 1) arena alloc=544KB java alloc=1406KB native alloc=2MB free=1535KB
I/PackageManager( 401): Running dexopt on: /system/priv-app/SystemUI/SystemUI.apk pkg=com.android.systemui isa=arm vmSafeMode=false
E/cutils-trace( 520): Error opening trace file: Permission denied (13)
I/dex2oat ( 520): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/priv-app/SystemUI/SystemUI.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@priv-app@SystemUI@SystemUI.apk@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 520): Decided to run without swap.
I/dex2oat ( 520): dex2oat took 8.558s (threads: 1) arena alloc=279KB java alloc=3MB native alloc=4MB free=3MB
I/PackageManager( 401): Running dexopt on: /system/priv-app/Dialer/Dialer.apk pkg=com.android.dialer isa=arm vmSafeMode=false
E/cutils-trace( 522): Error opening trace file: Permission denied (13)
I/dex2oat ( 522): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/priv-app/Dialer/Dialer.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@priv-app@Dialer@Dialer.apk@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 522): Decided to run without swap.
I/dex2oat ( 522): dex2oat took 8.180s (threads: 1) arena alloc=288KB java alloc=2MB native alloc=4MB free=3MB
I/PackageManager( 401): Running dexopt on: /system/priv-app/MmsService/MmsService.apk pkg=com.android.mms.service isa=arm vmSafeMode=false
E/cutils-trace( 524): Error opening trace file: Permission denied (13)
I/dex2oat ( 524): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/priv-app/MmsService/MmsService.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@priv-app@MmsService@MmsService.apk@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 524): Decided to run without swap.
I/dex2oat ( 524): dex2oat took 538.188ms (threads: 1) arena alloc=281KB java alloc=121KB native alloc=820KB free=3MB
I/PackageManager( 401): Running dexopt on: /system/priv-app/Shell/Shell.apk pkg=com.android.shell isa=arm vmSafeMode=false
E/cutils-trace( 526): Error opening trace file: Permission denied (13)
I/dex2oat ( 526): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/priv-app/Shell/Shell.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@priv-app@Shell@Shell.apk@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 526): Decided to run without swap.
I/dex2oat ( 526): dex2oat took 1.254s (threads: 1) arena alloc=55KB java alloc=358KB native alloc=1340KB free=2MB
I/PackageManager( 401): Running dexopt on: /system/app/LatinIME/LatinIME.apk pkg=com.android.inputmethod.latin isa=arm vmSafeMode=false
E/cutils-trace( 528): Error opening trace file: Permission denied (13)
I/dex2oat ( 528): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/LatinIME/LatinIME.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@LatinIME@LatinIME.apk@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 528): Decided to run without swap.
I/dex2oat ( 528): dex2oat took 5.141s (threads: 1) arena alloc=171KB java alloc=1642KB native alloc=3MB free=4MB
I/PackageManager( 401): Running dexopt on: /system/priv-app/DefaultContainerService/DefaultContainerService.apk pkg=com.android.defcontainer isa=arm vmSafeMode=false
E/cutils-trace( 530): Error opening trace file: Permission denied (13)
I/dex2oat ( 530): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/priv-app/DefaultContainerService/DefaultContainerService.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@priv-app@DefaultContainerService@DefaultContainerService.apk@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 530): Decided to run without swap.
I/dex2oat ( 530): dex2oat took 98.580ms (threads: 1) arena alloc=25KB java alloc=28KB native alloc=554KB free=3MB
I/PackageManager( 401): Running dexopt on: /system/priv-app/ProxyHandler/ProxyHandler.apk pkg=com.android.proxyhandler isa=arm vmSafeMode=false
E/cutils-trace( 532): Error opening trace file: Permission denied (13)
I/dex2oat ( 532): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/priv-app/ProxyHandler/ProxyHandler.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@priv-app@ProxyHandler@ProxyHandler.apk@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 532): Decided to run without swap.
I/dex2oat ( 532): dex2oat took 85.121ms (threads: 1) arena alloc=38KB java alloc=17KB native alloc=535KB free=3MB
I/PackageManager( 401): Running dexopt on: /system/priv-app/MediaProvider/MediaProvider.apk pkg=com.android.providers.media isa=arm vmSafeMode=false
E/cutils-trace( 534): Error opening trace file: Permission denied (13)
I/dex2oat ( 534): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/priv-app/MediaProvider/MediaProvider.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@priv-app@MediaProvider@MediaProvider.apk@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 534): Decided to run without swap.
I/dex2oat ( 534): dex2oat took 950.338ms (threads: 1) arena alloc=808KB java alloc=144KB native alloc=1575KB free=2MB
I/PackageManager( 401): Running dexopt on: /system/priv-app/ContactsProvider/ContactsProvider.apk pkg=com.android.providers.contacts isa=arm vmSafeMode=false
E/cutils-trace( 536): Error opening trace file: Permission denied (13)
I/dex2oat ( 536): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/priv-app/ContactsProvider/ContactsProvider.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@priv-app@ContactsProvider@ContactsProvider.apk@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 536): Decided to run without swap.
I/dex2oat ( 536): dex2oat took 3.591s (threads: 1) arena alloc=1459KB java alloc=716KB native alloc=3MB free=4MB
I/PackageManager( 401): Running dexopt on: /system/priv-app/ManagedProvisioning/ManagedProvisioning.apk pkg=com.android.managedprovisioning isa=arm vmSafeMode=false
E/cutils-trace( 538): Error opening trace file: Permission denied (13)
I/dex2oat ( 538): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/priv-app/ManagedProvisioning/ManagedProvisioning.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@priv-app@ManagedProvisioning@ManagedProvisioning.apk@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 538): Decided to run without swap.
I/dex2oat ( 538): dex2oat took 1.633s (threads: 1) arena alloc=167KB java alloc=546KB native alloc=1513KB free=2MB
I/PackageManager( 401): Running dexopt on: /system/priv-app/CalendarProvider/CalendarProvider.apk pkg=com.android.providers.calendar isa=arm vmSafeMode=false
E/cutils-trace( 540): Error opening trace file: Permission denied (13)
I/dex2oat ( 540): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/priv-app/CalendarProvider/CalendarProvider.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@priv-app@CalendarProvider@CalendarProvider.apk@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 540): Decided to run without swap.
I/dex2oat ( 540): dex2oat took 1.732s (threads: 1) arena alloc=416KB java alloc=424KB native alloc=1819KB free=2MB
I/PackageManager( 401): Running dexopt on: /system/app/PacProcessor/PacProcessor.apk pkg=com.android.pacprocessor isa=arm vmSafeMode=false
E/cutils-trace( 542): Error opening trace file: Permission denied (13)
I/dex2oat ( 542): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/PacProcessor/PacProcessor.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@PacProcessor@PacProcessor.apk@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 542): Decided to run without swap.
I/dex2oat ( 542): dex2oat took 77.493ms (threads: 1) arena alloc=27KB java alloc=8KB native alloc=523KB free=3MB
I/PackageManager( 401): Running dexopt on: /system/app/Calculator/Calculator.apk pkg=com.android.calculator2 isa=arm vmSafeMode=false
E/cutils-trace( 544): Error opening trace file: Permission denied (13)
I/dex2oat ( 544): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/Calculator/Calculator.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@Calculator@Calculator.apk@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 544): Decided to run without swap.
I/dex2oat ( 544): dex2oat took 2.623s (threads: 1) arena alloc=197KB java alloc=732KB native alloc=1884KB free=2MB
I/PackageManager( 401): Running dexopt on: /system/app/Music/Music.apk pkg=com.android.music isa=arm vmSafeMode=false
E/cutils-trace( 546): Error opening trace file: Permission denied (13)
I/dex2oat ( 546): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/Music/Music.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@Music@Music.apk@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 546): Decided to run without swap.
I/dex2oat ( 546): dex2oat took 1.182s (threads: 1) arena alloc=27KB java alloc=487KB native alloc=1210KB free=2MB
I/PackageManager( 401): Running dexopt on: /system/priv-app/BackupRestoreConfirmation/BackupRestoreConfirmation.apk pkg=com.android.backupconfirm isa=arm vmSafeMode=false
E/cutils-trace( 548): Error opening trace file: Permission denied (13)
I/dex2oat ( 548): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/priv-app/BackupRestoreConfirmation/BackupRestoreConfirmation.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@priv-app@BackupRestoreConfirmation@BackupRestoreConfirmation.apk@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 548): Decided to run without swap.
I/dex2oat ( 548): dex2oat took 86.435ms (threads: 1) arena alloc=41KB java alloc=25KB native alloc=532KB free=3MB
I/PackageManager( 401): Running dexopt on: /system/app/Exchange2/Exchange2.apk pkg=com.android.exchange isa=arm vmSafeMode=false
E/cutils-trace( 550): Error opening trace file: Permission denied (13)
I/dex2oat ( 550): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/Exchange2/Exchange2.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@Exchange2@Exchange2.apk@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 550): Decided to run without swap.
I/dex2oat ( 550): dex2oat took 11.662s (threads: 1) arena alloc=535KB java alloc=3MB native alloc=5MB free=6MB
I/PackageManager( 401): Running dexopt on: /system/app/LiveWallpapers/LiveWallpapers.apk pkg=com.android.wallpaper isa=arm vmSafeMode=false
E/cutils-trace( 552): Error opening trace file: Permission denied (13)
I/dex2oat ( 552): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/LiveWallpapers/LiveWallpapers.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@LiveWallpapers@LiveWallpapers.apk@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 552): Decided to run without swap.
I/dex2oat ( 552): dex2oat took 154.247ms (threads: 1) arena alloc=25KB java alloc=73KB native alloc=558KB free=3MB
I/PackageManager( 401): Running dexopt on: /system/app/SoundRecorder/SoundRecorder.apk pkg=com.android.soundrecorder isa=arm vmSafeMode=false
E/cutils-trace( 554): Error opening trace file: Permission denied (13)
I/dex2oat ( 554): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/SoundRecorder/SoundRecorder.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@SoundRecorder@SoundRecorder.apk@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 554): Decided to run without swap.
I/dex2oat ( 554): dex2oat took 149.501ms (threads: 1) arena alloc=25KB java alloc=40KB native alloc=573KB free=3MB
I/PackageManager( 401): Running dexopt on: /system/app/Provision/Provision.apk pkg=com.android.provision isa=arm vmSafeMode=false
E/cutils-trace( 556): Error opening trace file: Permission denied (13)
I/dex2oat ( 556): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/Provision/Provision.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@Provision@Provision.apk@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 556): Decided to run without swap.
I/dex2oat ( 556): dex2oat took 56.042ms (threads: 1) arena alloc=35KB java alloc=7KB native alloc=507KB free=3MB
I/PackageManager( 401): Running dexopt on: /system/app/PicoTts/PicoTts.apk pkg=com.svox.pico isa=arm vmSafeMode=false
E/cutils-trace( 558): Error opening trace file: Permission denied (13)
I/dex2oat ( 558): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/PicoTts/PicoTts.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@PicoTts@PicoTts.apk@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 558): Decided to run without swap.
I/dex2oat ( 558): dex2oat took 115.900ms (threads: 1) arena alloc=23KB java alloc=57KB native alloc=585KB free=3MB
I/PackageManager( 401): Running dexopt on: /system/priv-app/VpnDialogs/VpnDialogs.apk pkg=com.android.vpndialogs isa=arm vmSafeMode=false
E/cutils-trace( 560): Error opening trace file: Permission denied (13)
I/dex2oat ( 560): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/priv-app/VpnDialogs/VpnDialogs.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@priv-app@VpnDialogs@VpnDialogs.apk@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 560): Decided to run without swap.
I/dex2oat ( 560): dex2oat took 87.261ms (threads: 1) arena alloc=130KB java alloc=32KB native alloc=534KB free=3MB
I/PackageManager( 401): Running dexopt on: /system/priv-app/Contacts/Contacts.apk pkg=com.android.contacts isa=arm vmSafeMode=false
E/cutils-trace( 562): Error opening trace file: Permission denied (13)
I/dex2oat ( 562): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/priv-app/Contacts/Contacts.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@priv-app@Contacts@Contacts.apk@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 562): Decided to run without swap.
I/dex2oat ( 562): dex2oat took 8.523s (threads: 1) arena alloc=416KB java alloc=2MB native alloc=4MB free=3MB
I/PackageManager( 401): Running dexopt on: /system/app/Email/Email.apk pkg=com.android.email isa=arm vmSafeMode=false
E/cutils-trace( 564): Error opening trace file: Permission denied (13)
I/dex2oat ( 564): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/Email/Email.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@Email@Email.apk@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 564): Decided to run without swap.
I/dex2oat ( 564): dex2oat took 17.451s (threads: 1) arena alloc=795KB java alloc=5MB native alloc=9MB free=6MB
I/PackageManager( 401): Running dexopt on: /system/priv-app/DownloadProvider/DownloadProvider.apk pkg=com.android.providers.downloads isa=arm vmSafeMode=false
E/cutils-trace( 566): Error opening trace file: Permission denied (13)
I/dex2oat ( 566): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/priv-app/DownloadProvider/DownloadProvider.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@priv-app@DownloadProvider@DownloadProvider.apk@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 566): Decided to run without swap.
I/dex2oat ( 566): dex2oat took 1.598s (threads: 1) arena alloc=41KB java alloc=412KB native alloc=1380KB free=2MB
I/PackageManager( 401): Running dexopt on: /system/priv-app/ExternalStorageProvider/ExternalStorageProvider.apk pkg=com.android.externalstorage isa=arm vmSafeMode=false
E/cutils-trace( 568): Error opening trace file: Permission denied (13)
I/dex2oat ( 568): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/priv-app/ExternalStorageProvider/ExternalStorageProvider.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@priv-app@ExternalStorageProvider@ExternalStorageProvider.apk@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 568): Decided to run without swap.
I/dex2oat ( 568): dex2oat took 587.199ms (threads: 1) arena alloc=51KB java alloc=36KB native alloc=565KB free=3MB
I/PackageManager( 401): Running dexopt on: /system/priv-app/Launcher2/Launcher2.apk pkg=com.android.launcher isa=arm vmSafeMode=false
E/cutils-trace( 570): Error opening trace file: Permission denied (13)
I/dex2oat ( 570): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/priv-app/Launcher2/Launcher2.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@priv-app@Launcher2@Launcher2.apk@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 570): Decided to run without swap.
I/dex2oat ( 570): dex2oat took 4.135s (threads: 1) arena alloc=442KB java alloc=1325KB native alloc=2MB free=1164KB
I/PackageManager( 401): Running dexopt on: /system/app/Gallery/Gallery.apk pkg=com.android.gallery isa=arm vmSafeMode=false
E/cutils-trace( 572): Error opening trace file: Permission denied (13)
I/dex2oat ( 572): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/Gallery/Gallery.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@Gallery@Gallery.apk@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 572): Decided to run without swap.
I/dex2oat ( 572): dex2oat took 1.263s (threads: 1) arena alloc=29KB java alloc=446KB native alloc=1125KB free=2MB
I/PackageManager( 401): Running dexopt on: /system/app/Bluetooth/Bluetooth.apk pkg=com.android.bluetooth isa=arm vmSafeMode=false
E/cutils-trace( 574): Error opening trace file: Permission denied (13)
I/dex2oat ( 574): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/Bluetooth/Bluetooth.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@Bluetooth@Bluetooth.apk@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 574): Decided to run without swap.
I/dex2oat ( 574): dex2oat took 5.441s (threads: 1) arena alloc=1049KB java alloc=1386KB native alloc=4MB free=3MB
I/PackageManager( 401): Running dexopt on: /system/app/Browser/Browser.apk pkg=com.android.browser isa=arm vmSafeMode=false
E/cutils-trace( 576): Error opening trace file: Permission denied (13)
I/dex2oat ( 576): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/Browser/Browser.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@Browser@Browser.apk@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 576): Decided to run without swap.
I/dex2oat ( 576): dex2oat took 5.014s (threads: 1) arena alloc=160KB java alloc=1944KB native alloc=3MB free=4MB
I/PackageManager( 401): Running dexopt on: /system/app/DeskClock/DeskClock.apk pkg=com.android.deskclock isa=arm vmSafeMode=false
E/cutils-trace( 578): Error opening trace file: Permission denied (13)
I/dex2oat ( 578): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/DeskClock/DeskClock.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@DeskClock@DeskClock.apk@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 578): Decided to run without swap.
I/dex2oat ( 578): dex2oat took 3.238s (threads: 1) arena alloc=174KB java alloc=1101KB native alloc=2MB free=1788KB
I/PackageManager( 401): Running dexopt on: /system/app/LegacyCamera/LegacyCamera.apk pkg=com.android.camera isa=arm vmSafeMode=false
E/cutils-trace( 580): Error opening trace file: Permission denied (13)
I/dex2oat ( 580): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/LegacyCamera/LegacyCamera.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@LegacyCamera@LegacyCamera.apk@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 580): Decided to run without swap.
I/dex2oat ( 580): dex2oat took 1.423s (threads: 1) arena alloc=35KB java alloc=762KB native alloc=1417KB free=2MB
I/PackageManager( 401): Running dexopt on: /system/priv-app/SharedStorageBackup/SharedStorageBackup.apk pkg=com.android.sharedstoragebackup isa=arm vmSafeMode=false
E/cutils-trace( 582): Error opening trace file: Permission denied (13)
I/dex2oat ( 582): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/priv-app/SharedStorageBackup/SharedStorageBackup.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@priv-app@SharedStorageBackup@SharedStorageBackup.apk@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 582): Decided to run without swap.
I/dex2oat ( 582): dex2oat took 347.052ms (threads: 1) arena alloc=111KB java alloc=22KB native alloc=529KB free=3MB
I/PackageManager( 401): Running dexopt on: /system/priv-app/OneTimeInitializer/OneTimeInitializer.apk pkg=com.android.onetimeinitializer isa=arm vmSafeMode=false
E/cutils-trace( 584): Error opening trace file: Permission denied (13)
I/dex2oat ( 584): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/priv-app/OneTimeInitializer/OneTimeInitializer.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@priv-app@OneTimeInitializer@OneTimeInitializer.apk@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 584): Decided to run without swap.
I/dex2oat ( 584): dex2oat took 196.709ms (threads: 1) arena alloc=37KB java alloc=61KB native alloc=607KB free=3MB
I/PackageManager( 401): Running dexopt on: /system/app/CertInstaller/CertInstaller.apk pkg=com.android.certinstaller isa=arm vmSafeMode=false
E/cutils-trace( 586): Error opening trace file: Permission denied (13)
I/dex2oat ( 586): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/CertInstaller/CertInstaller.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@CertInstaller@CertInstaller.apk@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 586): Decided to run without swap.
I/dex2oat ( 586): dex2oat took 704.726ms (threads: 1) arena alloc=30KB java alloc=82KB native alloc=585KB free=3MB
I/PackageManager( 401): Running dexopt on: /system/app/HTMLViewer/HTMLViewer.apk pkg=com.android.htmlviewer isa=arm vmSafeMode=false
E/cutils-trace( 588): Error opening trace file: Permission denied (13)
I/dex2oat ( 588): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/HTMLViewer/HTMLViewer.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@HTMLViewer@HTMLViewer.apk@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 588): Decided to run without swap.
I/dex2oat ( 588): dex2oat took 81.245ms (threads: 1) arena alloc=25KB java alloc=52KB native alloc=536KB free=3MB
I/PackageManager( 401): Running dexopt on: /system/app/CubeLiveWallpapers/CubeLiveWallpapers.apk pkg=com.example.android.livecubes isa=arm vmSafeMode=false
E/cutils-trace( 590): Error opening trace file: Permission denied (13)
I/dex2oat ( 590): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/CubeLiveWallpapers/CubeLiveWallpapers.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@CubeLiveWallpapers@CubeLiveWallpapers.apk@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 590): Decided to run without swap.
I/dex2oat ( 590): dex2oat took 111.724ms (threads: 1) arena alloc=23KB java alloc=35KB native alloc=573KB free=3MB
I/PackageManager( 401): Running dexopt on: /system/app/DocumentsUI/DocumentsUI.apk pkg=com.android.documentsui isa=arm vmSafeMode=false
E/cutils-trace( 592): Error opening trace file: Permission denied (13)
I/dex2oat ( 592): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/DocumentsUI/DocumentsUI.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@DocumentsUI@DocumentsUI.apk@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 592): Decided to run without swap.
I/dex2oat ( 592): dex2oat took 2.910s (threads: 1) arena alloc=160KB java alloc=952KB native alloc=2MB free=1977KB
I/PackageManager( 401): Running dexopt on: /system/app/Calendar/Calendar.apk pkg=com.android.calendar isa=arm vmSafeMode=false
E/cutils-trace( 594): Error opening trace file: Permission denied (13)
I/dex2oat ( 594): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/Calendar/Calendar.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@Calendar@Calendar.apk@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 594): Decided to run without swap.
I/dex2oat ( 594): dex2oat took 5.787s (threads: 1) arena alloc=211KB java alloc=1967KB native alloc=3MB free=4MB
I/PackageManager( 401): Running dexopt on: /system/app/QuickSearchBox/QuickSearchBox.apk pkg=com.android.quicksearchbox isa=arm vmSafeMode=false
E/cutils-trace( 596): Error opening trace file: Permission denied (13)
I/dex2oat ( 596): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/QuickSearchBox/QuickSearchBox.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@QuickSearchBox@QuickSearchBox.apk@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 596): Decided to run without swap.
I/dex2oat ( 596): dex2oat took 1.409s (threads: 1) arena alloc=32KB java alloc=582KB native alloc=1300KB free=2MB
I/PackageManager( 401): Running dexopt on: /system/app/webview/webview.apk pkg=com.android.webview isa=arm vmSafeMode=false
E/cutils-trace( 598): Error opening trace file: Permission denied (13)
I/dex2oat ( 598): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/webview/webview.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@webview@webview.apk@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 598): Decided to run without swap.
I/dex2oat ( 598): dex2oat took 3.750s (threads: 1) arena alloc=37KB java alloc=1365KB native alloc=2MB free=1496KB
I/PackageManager( 401): Running dexopt on: /system/app/BasicDreams/BasicDreams.apk pkg=com.android.dreams.basic isa=arm vmSafeMode=false
E/cutils-trace( 600): Error opening trace file: Permission denied (13)
I/dex2oat ( 600): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/BasicDreams/BasicDreams.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@BasicDreams@BasicDreams.apk@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 600): Decided to run without swap.
I/dex2oat ( 600): dex2oat took 99.275ms (threads: 1) arena alloc=26KB java alloc=29KB native alloc=548KB free=3MB
I/PackageManager( 401): Running dexopt on: /system/app/PrintSpooler/PrintSpooler.apk pkg=com.android.printspooler isa=arm vmSafeMode=false
E/cutils-trace( 602): Error opening trace file: Permission denied (13)
I/dex2oat ( 602): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/PrintSpooler/PrintSpooler.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@PrintSpooler@PrintSpooler.apk@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 602): Decided to run without swap.
I/dex2oat ( 602): dex2oat took 3.313s (threads: 1) arena alloc=410KB java alloc=963KB native alloc=2MB free=1529KB
I/PackageManager( 401): Running dexopt on: /system/app/UserDictionaryProvider/UserDictionaryProvider.apk pkg=com.android.providers.userdictionary isa=arm vmSafeMode=false
E/cutils-trace( 604): Error opening trace file: Permission denied (13)
I/dex2oat ( 604): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/UserDictionaryProvider/UserDictionaryProvider.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@UserDictionaryProvider@UserDictionaryProvider.apk@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 604): Decided to run without swap.
I/dex2oat ( 604): dex2oat took 101.837ms (threads: 1) arena alloc=65KB java alloc=20KB native alloc=549KB free=3MB
I/PackageManager( 401): Running dexopt on: /system/priv-app/MusicFX/MusicFX.apk pkg=com.android.musicfx isa=arm vmSafeMode=false
E/cutils-trace( 606): Error opening trace file: Permission denied (13)
I/dex2oat ( 606): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/priv-app/MusicFX/MusicFX.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@priv-app@MusicFX@MusicFX.apk@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 606): Decided to run without swap.
I/dex2oat ( 606): dex2oat took 467.204ms (threads: 1) arena alloc=911KB java alloc=151KB native alloc=1510KB free=2MB
I/PackageManager( 401): Running dexopt on: /system/priv-app/Mms/Mms.apk pkg=com.android.mms isa=arm vmSafeMode=false
E/cutils-trace( 608): Error opening trace file: Permission denied (13)
I/dex2oat ( 608): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/priv-app/Mms/Mms.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@priv-app@Mms@Mms.apk@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 608): Decided to run without swap.
I/dex2oat ( 608): dex2oat took 5.680s (threads: 1) arena alloc=409KB java alloc=1755KB native alloc=3MB free=4MB
I/PackageManager( 401): Running dexopt on: /system/app/CaptivePortalLogin/CaptivePortalLogin.apk pkg=com.android.captiveportallogin isa=arm vmSafeMode=false
E/cutils-trace( 610): Error opening trace file: Permission denied (13)
I/dex2oat ( 610): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/CaptivePortalLogin/CaptivePortalLogin.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@CaptivePortalLogin@CaptivePortalLogin.apk@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 610): Decided to run without swap.
I/dex2oat ( 610): dex2oat took 99.349ms (threads: 1) arena alloc=32KB java alloc=68KB native alloc=584KB free=3MB
I/PackageManager( 401): Running dexopt on: /system/app/LiveWallpapersPicker/LiveWallpapersPicker.apk pkg=com.android.wallpaper.livepicker isa=arm vmSafeMode=false
E/cutils-trace( 612): Error opening trace file: Permission denied (13)
I/dex2oat ( 612): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/LiveWallpapersPicker/LiveWallpapersPicker.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@LiveWallpapersPicker@LiveWallpapersPicker.apk@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 612): Decided to run without swap.
I/dex2oat ( 612): dex2oat took 137.239ms (threads: 1) arena alloc=47KB java alloc=57KB native alloc=561KB free=3MB
I/PackageManager( 401): Running dexopt on: /system/app/DownloadProviderUi/DownloadProviderUi.apk pkg=com.android.providers.downloads.ui isa=arm vmSafeMode=false
E/cutils-trace( 614): Error opening trace file: Permission denied (13)
I/dex2oat ( 614): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/DownloadProviderUi/DownloadProviderUi.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@DownloadProviderUi@DownloadProviderUi.apk@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 614): Decided to run without swap.
I/dex2oat ( 614): dex2oat took 97.471ms (threads: 1) arena alloc=87KB java alloc=48KB native alloc=535KB free=3MB
I/PackageManager( 401): Running dexopt on: /system/priv-app/WallpaperCropper/WallpaperCropper.apk pkg=com.android.wallpapercropper isa=arm vmSafeMode=false
E/cutils-trace( 616): Error opening trace file: Permission denied (13)
I/dex2oat ( 616): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/priv-app/WallpaperCropper/WallpaperCropper.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@priv-app@WallpaperCropper@WallpaperCropper.apk@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 616): Decided to run without swap.
I/dex2oat ( 616): dex2oat took 1.696s (threads: 1) arena alloc=162KB java alloc=472KB native alloc=1561KB free=2MB
I/PackageManager( 401): Running dexopt on: /system/app/PackageInstaller/PackageInstaller.apk pkg=com.android.packageinstaller isa=arm vmSafeMode=false
E/cutils-trace( 618): Error opening trace file: Permission denied (13)
I/dex2oat ( 618): /system/bin/dex2oat --zip-fd=6 --zip-location=/system/app/PackageInstaller/PackageInstaller.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/system@app@PackageInstaller@PackageInstaller.apk@classes.dex --instruction-set=arm --instruction-set-features=default --runtime-arg -Xms64m --runtime-arg -Xmx512m --swap-fd=10
I/dex2oat ( 618): Decided to run without swap.
I/dex2oat ( 618): dex2oat took 1.598s (threads: 1) arena alloc=52KB java alloc=538KB native alloc=1515KB free=2MB
I/SystemServer( 401): LockSettingsService
I/SystemServiceManager( 401): Starting com.android.server.devicepolicy.DevicePolicyManagerService$Lifecycle
I/SystemServer( 401): Status Bar
I/SystemServer( 401): Clipboard Service
I/SystemServer( 401): NetworkManagement Service
I/SystemServer( 401): Text Service Manager Service
I/SystemServer( 401): Network Score Service
I/SystemServer( 401): NetworkStats Service
I/SystemServer( 401): NetworkPolicy Service
I/SystemServiceManager( 401): Starting com.android.server.wifi.p2p.WifiP2pService
I/WifiP2pService( 401): Registering wifip2p
I/SystemServiceManager( 401): Starting com.android.server.wifi.WifiService
E/WifiConfigStore( 401): associatedPartialScanPeriodMilli set to 20000
E/WifiStateMachine( 401): completeConstruction: E
E/WifiStateMachine( 401): completeConstruction: maxDepth=6
E/WifiStateMachine( 401): setupInitialStateStack: E mInitialState=InitialState
E/WifiStateMachine( 401): moveTempStackToStateStack: i=1,j=0
E/WifiStateMachine( 401): moveTempStackToStateStack: i=0,j=1
E/WifiStateMachine( 401): moveTempStackToStateStack: X mStateStackTop=1,startingIndex=0,Top=InitialState
E/WifiStateMachine( 401): handleMessage: E msg.what=-2
E/WifiStateMachine( 401): invokeEnterMethods: DefaultState
E/WifiStateMachine( 401): invokeEnterMethods: InitialState
E/WifiStateMachine( 401): ********Mutyala rao is in WIFI_STATE_MACHINE *******
D/wifi ( 401): *************MUTYALARAO IS IN WIFI UNLOAD DRIVER IN CPP FILE **************
E/WifiStateMachine( 401): completeConstruction: X
D/WifiController( 401): isAirplaneModeOn = false, isWifiEnabled = false, isScanningAvailable = false
I/WifiService( 401): Registering wifi
I/SystemServiceManager( 401): Starting com.android.server.wifi.WifiScanningService
I/WifiScanningService( 401): Creating wifiscanner
I/WifiScanningService( 401): Starting wifiscanner
I/SystemServiceManager( 401): Starting com.android.server.wifi.RttService
I/RttService( 401): Creating rttmanager
I/RttService( 401): Starting rttmanager
I/SystemServiceManager( 401): Starting com.android.server.ethernet.EthernetService
I/EthernetServiceImpl( 401): Creating EthernetConfigStore
E/IpConfigStore( 401): Error parsing configuration: java.io.FileNotFoundException: /data/misc/ethernet/ipconfig.txt: open failed: ENOENT (No such file or directory)
W/EthernetConfigStore( 401): No Ethernet configuration found. Using default.
I/EthernetServiceImpl( 401): Read stored IP configuration: IP assignment: DHCP
I/EthernetServiceImpl( 401): Proxy settings: NONE
I/EthernetService( 401): Registering service ethernet
I/SystemServer( 401): Connectivity Service
D/ConnectivityService( 401): ConnectivityService starting up
D/ConnectivityService( 401): wifiOnly=false
E/ConnectivityService( 401): Ignoring protectedNetwork 14
E/ConnectivityService( 401): Ignoring protectedNetwork 15
I/SystemServer( 401): Network Service Discovery Service
D/NsdService( 401): Network service discovery enabled true
I/SystemServer( 401): UpdateLock Service
I/SystemServiceManager( 401): Starting com.android.server.notification.NotificationManagerService
D/ZenLog ( 401): set_zen_mode: off,setting
I/SystemServiceManager( 401): Starting com.android.server.storage.DeviceStorageMonitorService
E/WifiStateMachine( 401): handleMessage: X
E/WifiStateMachine( 401): handleMessage: E msg.what=131154
E/WifiStateMachine( 401): processMsg: InitialState
E/WifiStateMachine( 401): InitialState !CMD_ENABLE_RSSI_POLL 1 0
E/WifiStateMachine( 401): processMsg: DefaultState
E/WifiStateMachine( 401): DefaultState !CMD_ENABLE_RSSI_POLL 1 0
E/WifiStateMachine( 401): handleMessage: E msg.what=69632
E/WifiStateMachine( 401): InitialState !AsyncChannel.CMD_CHANNEL_HALF_CONNECTED 0 0
E/WifiStateMachine( 401): DefaultState !AsyncChannel.CMD_CHANNEL_HALF_CONNECTED 0 0
I/SystemServer( 401): Location Manager
I/art ( 401): Background partial concurrent mark sweep GC freed 10542(762KB) AllocSpace objects, 0(0B) LOS objects, 33% free, 4MB/6MB, paused 3.005ms total 140.489ms
I/SystemServer( 401): Country Detector
I/SystemServer( 401): Search Service
I/SystemServer( 401): DropBox Service
I/SystemServer( 401): Wallpaper Service
W/WallpaperManagerService( 401): no current wallpaper -- first boot?
I/SystemServer( 401): Audio Service
W/TelecomManager( 401): Telecom Service not found.
I/SystemServiceManager( 401): Starting com.android.server.DockObserver
W/DockObserver( 401): This kernel does not have dock station support
I/SystemServer( 401): Wired Accessory Manager
W/WiredAccessoryManager( 401): This kernel does not have HDMI audio support
I/SystemServiceManager( 401): Starting com.android.server.usb.UsbService$Lifecycle
I/SystemServer( 401): Serial Service
I/SystemServiceManager( 401): Starting com.android.server.twilight.TwilightService
I/SystemServiceManager( 401): Starting com.android.server.UiModeManagerService
I/SystemServiceManager( 401): Starting com.android.server.job.JobSchedulerService
I/SystemServiceManager( 401): Starting com.android.server.backup.BackupManagerService$Lifecycle
I/SystemServiceManager( 401): Starting com.android.server.appwidget.AppWidgetService
I/SystemServiceManager( 401): Starting com.android.server.voiceinteraction.VoiceInteractionManagerService
W/SoundTriggerHelper( 401): listModules status=0, # of modules=0
I/SystemServer( 401): DiskStats Service
I/SystemServer( 401): SamplingProfiler Service
I/SystemServer( 401): NetworkTimeUpdateService
I/SystemServer( 401): CommonTimeManagementService
I/SystemServer( 401): CertBlacklister
I/SystemServiceManager( 401): Starting com.android.server.dreams.DreamManagerService
I/SystemServer( 401): Assets Atlas Service
I/SystemServiceManager( 401): Starting com.android.server.print.PrintManagerService
D/AssetAtlas( 401): Computing best atlas configuration...
D/AssetAtlas( 401): Running Thread-57
D/AssetAtlas( 401): Found best atlas configuration in 0.01s
I/SystemServiceManager( 401): Starting com.android.server.restrictions.RestrictionsManagerService
I/SystemServiceManager( 401): Starting com.android.server.media.MediaSessionService
D/AssetAtlas( 401): Loaded configuration: SliceMinArea (768x768) flags=0x2 count=2
I/SystemServer( 401): Media Router Service
I/SystemServiceManager( 401): Starting com.android.server.trust.TrustManagerService
W/AssetAtlasService( 401): Could not find EGL configuration
D/AssetAtlas( 401): Rendered atlas in 0.62ms (0.17+0.45ms)
I/SystemServiceManager( 401): Starting com.android.server.fingerprint.FingerprintService
V/Fingerprint-JNI( 401): nativeInit()
V/Fingerprint-JNI( 401): nativeOpenHal()
E/Fingerprint-JNI( 401): Can't open fingerprint HW Module, error: -2
I/SystemServer( 401): BackgroundDexOptService
I/SystemServiceManager( 401): Starting com.android.server.pm.LauncherAppsService
I/SystemServiceManager( 401): Starting com.android.server.media.projection.MediaProjectionManagerService
I/WindowManager( 401): SAFE MODE not enabled
I/SystemServiceManager( 401): Starting com.android.server.MmsServiceBroker
E/SQLiteLog( 401): (1) no such table: locksettings
I/LockSettingsService( 401): Migrated lock settings to new location
I/LockSettingsService( 401): Migrated per-user lock settings to new location
E/LockSettingsStorage( 401): Cannot read file java.io.FileNotFoundException: /data/system/password.key: open failed: ENOENT (No such file or directory)
E/LockSettingsStorage( 401): Cannot read file java.io.FileNotFoundException: /data/system/gesture.key: open failed: ENOENT (No such file or directory)
I/SystemServiceManager( 401): Starting phase 480
I/SystemServiceManager( 401): Starting phase 500
I/WifiService( 401): WifiService starting up with Wi-Fi disabled
E/WifiStateMachine( 401): handleMessage: E msg.what=131084
E/WifiStateMachine( 401): InitialState !CMD_STOP_SUPPLICANT 0 0
E/WifiStateMachine( 401): DefaultState !CMD_STOP_SUPPLICANT 0 0
D/WifiService( 401): New client listening to asynchronous messages
I/WifiScanningService( 401): Registering wifiscanner
D/WifiScanningService( 401): New client, channel: null messenger: null
D/WifiScanningService( 401): DefaultState
D/WifiChangeStateMachine( 401): Entering IdleState
I/RttService( 401): Registering rttmanager
I/EthernetServiceImpl( 401): Starting Ethernet service
D/Ethernet( 401): Registering NetworkFactory
D/ConnectivityService( 401): Got NetworkFactory Messenger for Ethernet
D/Ethernet( 401): got request NetworkRequest [ id=1, legacyType=-1, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN] ] with score 0
D/EthernetNetworkFactory( 401): Started tracking interface eth0
D/CommandListener( 139): Setting iface cfg
D/CommandListener( 139): Trying to bring up eth0
I/ActivityManager( 401): Config changes=200 {1.0 ?mcc?mnc en_US ?layoutDir sw640dp w1066dp h566dp 120dpi lrg land -touch -keyb/h/h -nav/h s.4}
I/SELinux ( 401): SELinux: Loaded file_contexts from /file_contexts
V/BackupManagerService( 401): No ancestral data
D/BackupManagerService( 401): Now staging backup of com.android.browser
D/BackupManagerService( 401): Now staging backup of android
D/BackupManagerService( 401): Now staging backup of com.android.calendar
D/BackupManagerService( 401): Now staging backup of com.android.providers.settings
D/BackupManagerService( 401): Now staging backup of com.android.sharedstoragebackup
W/art ( 401): Long monitor contention event with owner method=void com.android.server.backup.BackupManagerService.dataChangedImpl(java.lang.String, java.util.HashSet) from BackupManagerService.java:8074 waiters=0 for 408ms
D/BackupManagerService( 401): Now staging backup of com.android.dialer
D/BackupManagerService( 401): Now staging backup of com.android.providers.userdictionary
V/BackupManagerService( 401): Starting with transport android/com.android.internal.backup.LocalTransport
V/BackupManagerService( 401): Found transports: 1
I/BackupManagerService( 401): Binding to transport host ComponentInfo{android/com.android.internal.backup.LocalTransportService}
I/ActivityManager( 401): Sending system update to ComponentInfo{com.android.providers.calendar/com.android.providers.calendar.CalendarUpgradeReceiver} for user 0
I/ActivityManager( 401): Sending system update to ComponentInfo{com.android.providers.contacts/com.android.providers.contacts.ContactsUpgradeReceiver} for user 0
I/ActivityManager( 401): Sending system update to ComponentInfo{com.android.managedprovisioning/com.android.managedprovisioning.PreBootListener} for user 0
I/ActivityManager( 401): Sending system update to ComponentInfo{com.android.providers.media/com.android.providers.media.MediaUpgradeReceiver} for user 0
I/ActivityManager( 401): Sending system update to ComponentInfo{com.android.settings/com.android.settings.ManagedProfileSetup} for user 0
I/SystemServer( 401): Enabled StrictMode for system server main thread.
I/DisplayManagerService( 401): Display device changed: DisplayDeviceInfo{"Built-in Screen": uniqueId="local:0", 800 x 480, 60.000004 fps, supportedRefreshRates [60.000004], density 120, 160.0 x 160.421 dpi, appVsyncOff 0, presDeadline 17666666, touch INTERNAL, rotation 0, type BUILT_IN, state ON, FLAG_DEFAULT_DISPLAY, FLAG_ROTATES_WITH_CONTENT, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
D/SurfaceFlinger( 125): Set power mode=2, type=0 flinger=0xb6082000
D/SurfaceFlinger( 125): Screen type=0 is already mode=2
I/Zygote ( 401): Process: zygote socket opened, supported ABIS: armeabi-v7a,armeabi
I/art ( 401): Background sticky concurrent mark sweep GC freed 20337(1326KB) AllocSpace objects, 1(16KB) LOS objects, 20% free, 4MB/6MB, paused 4.235ms total 144.080ms
I/ActivityManager( 401): Start proc 642:com.android.providers.calendar/u0a1 for broadcast com.android.providers.calendar/.CalendarUpgradeReceiver
V/ActivityManager( 401): Display changed displayId=0
D/WifiScanningService( 401): SCAN_AVAILABLE : 1
D/WifiScanningService( 401): DefaultState got{ when=-4ms what=160007 target=com.android.internal.util.StateMachine$SmHandler }
D/RttService( 401): SCAN_AVAILABLE : 1
D/RttService( 401): DefaultState got{ when=0 what=160513 target=com.android.internal.util.StateMachine$SmHandler }
I/ActivityManager( 401): Launching preboot mode app: ProcessRecord{26b67483 642:com.android.providers.calendar/u0a1}
V/BackupManagerService( 401): Connected to transport ComponentInfo{android/com.android.internal.backup.LocalTransportService}
V/BackupManagerService( 401): Registering transport android/com.android.internal.backup.LocalTransportService::android/com.android.internal.backup.LocalTransport = android.app.backup.BackupTransport$TransportImpl@3381b600
W/ResourcesManager( 642): Asset path '/system/framework/android.test.runner.jar' does not exist or contains no resources.
I/ActivityManager( 401): Start proc 668:android.process.acore/u0a2 for broadcast com.android.providers.contacts/.ContactsUpgradeReceiver
I/ActivityManager( 401): Launching preboot mode app: ProcessRecord{37aeae39 668:android.process.acore/u0a2}
I/ContactsUpgradeReceiver( 668): Creating or opening contacts database
I/ContactsDatabaseHelper( 668): Bootstrapping database version: 910
I/ContactsProviderV1( 668): Bootstrapping database legacy support
I/ContactsProvider( 668): Locale has changed from null to en-US
I/ContactsDatabaseHelper( 668): Switching to locale en-US (ICU v53.1.0.1)
I/ContactsDatabaseHelper( 668): Locale change completed in 284ms
I/ContactsDatabaseHelper( 668): Locale change completed in 1019ms
I/ActivityManager( 401): Start proc 686:com.android.managedprovisioning/u0a8 for broadcast com.android.managedprovisioning/.PreBootListener
I/ActivityManager( 401): Launching preboot mode app: ProcessRecord{278bbc7e 686:com.android.managedprovisioning/u0a8}
I/ActivityManager( 401): Start proc 702:android.process.media/u0a5 for broadcast com.android.providers.media/.MediaUpgradeReceiver
I/ActivityManager( 401): Launching preboot mode app: ProcessRecord{3161d5df 702:android.process.media/u0a5}
I/ActivityManager( 401): Start proc 718:com.android.settings/1000 for broadcast com.android.settings/.ManagedProfileSetup
I/ActivityManager( 401): Launching preboot mode app: ProcessRecord{1f4c322c 718:com.android.settings/1000}
W/ResourcesManager( 718): Asset path '/system/framework/freescale-extended.jar' does not exist or contains no resources.
I/ActivityManager( 401): Removing system update proc: ProcessRecord{26b67483 642:com.android.providers.calendar/u0a1}
I/ActivityManager( 401): Killing 642:com.android.providers.calendar/u0a1 (adj 15): system update done
I/ActivityManager( 401): Removing system update proc: ProcessRecord{37aeae39 668:android.process.acore/u0a2}
I/ActivityManager( 401): Killing 668:android.process.acore/u0a2 (adj 15): system update done
I/ActivityManager( 401): Removing system update proc: ProcessRecord{278bbc7e 686:com.android.managedprovisioning/u0a8}
I/ActivityManager( 401): Killing 686:com.android.managedprovisioning/u0a8 (adj 13): system update done
I/ActivityManager( 401): Removing system update proc: ProcessRecord{3161d5df 702:android.process.media/u0a5}
I/ActivityManager( 401): Killing 702:android.process.media/u0a5 (adj 11): system update done
I/ActivityManager( 401): Removing system update proc: ProcessRecord{1f4c322c 718:com.android.settings/1000}
I/ActivityManager( 401): Killing 718:com.android.settings/1000 (adj 9): system update done
I/ActivityManager( 401): System now ready
W/art ( 401): Long monitor contention event with owner method=void com.android.server.am.ActivityManagerService.systemReady(java.lang.Runnable) from ActivityManagerService.java:11248 waiters=0 for 529ms
W/ActivityManager( 401): Spurious death for ProcessRecord{26b67483 642:com.android.providers.calendar/u0a1}, curProc for 642: null
W/art ( 401): Long monitor contention event with owner method=void com.android.server.am.ActivityManagerService.systemReady(java.lang.Runnable) from ActivityManagerService.java:11248 waiters=2 for 264ms
W/ActivityManager( 401): Spurious death for ProcessRecord{278bbc7e 686:com.android.managedprovisioning/u0a8}, curProc for 686: null
W/ActivityManager( 401): Spurious death for ProcessRecord{3161d5df 702:android.process.media/u0a5}, curProc for 702: null
W/ActivityManager( 401): Spurious death for ProcessRecord{1f4c322c 718:com.android.settings/1000}, curProc for 718: null
W/art ( 401): Long monitor contention event with owner method=void com.android.server.am.ActivityManagerService.systemReady(java.lang.Runnable) from ActivityManagerService.java:11248 waiters=1 for 365ms
W/ActivityManager( 401): Spurious death for ProcessRecord{37aeae39 668:android.process.acore/u0a2}, curProc for 668: null
I/SystemServer( 401): Making services ready
I/SystemServiceManager( 401): Starting phase 550
I/Telecom ( 401): TelecomGlobals: TelecomGlobals initializing
I/SystemServer( 401): WebViewFactory preparation
D/UsbHostManager( 401): Added device UsbDevice[mName=/dev/bus/usb/001/007,mVendorId=1121,mProductId=20002,mClass=0,mSubclass=0,mProtocol=0,mManufacturerName=PixArt,mProductName=USB Optical Mouse,mSerialNumber=null,mConfigurations=[
D/UsbHostManager( 401): UsbConfiguration[mId=1,mName=null,mAttributes=160,mMaxPower=50,mInterfaces=[
D/UsbHostManager( 401): UsbInterface[mId=0,mAlternateSetting=0,mName=null,mClass=3,mSubclass=1,mProtocol=2,mEndpoints=[
D/UsbHostManager( 401): UsbEndpoint[mAddress=129,mAttributes=3,mMaxPacketSize=4,mInterval=10]]]]
W/ContextImpl( 401): Calling a method in the system process without a qualified user: android.app.ContextImpl.sendBroadcast:1327 com.android.server.usb.UsbSettingsManager.deviceAttached:741 com.android.server.usb.UsbHostManager.endUsbDeviceAdded:224 com.android.server.usb.UsbHostManager.monitorUsbHostBus:-2 com.android.server.usb.UsbHostManager.access$000:42
I/ActivityManager( 401): Start proc 741:android.process.acore/u0a2 for content provider com.android.providers.contacts/.CallLogProvider
D/BluetoothManagerService( 401): Message: 20
D/BluetoothManagerService( 401): Added callback: android.bluetooth.BluetoothAdapter$1@f6e9f30:true
D/BluetoothManagerService( 401): Message: 30
D/BluetoothManagerService( 401): Trying to bind to profile: 1, while Bluetooth was disabled
I/ActivityManager( 401): Start proc 756:WebViewLoader-armeabi-v7a/1037 [android.webkit.WebViewFactory$RelroFileCreator] for
V/WebViewFactory( 756): RelroFileCreator (64bit = false), 32-bit lib: /system/app/webview/lib/arm/libwebviewchromium.so, 64-bit lib:
I/ActivityManager( 401): Start proc 771:com.android.systemui/u0a14 for service com.android.systemui/.SystemUIService
W/art ( 401): Long monitor contention event with owner method=int com.android.server.am.ActivityManagerService.startIsolatedProcess(java.lang.String, java.lang.String[], java.lang.String, java.lang.String, int, java.lang.Runnable) from ActivityManagerService.java:2741 waiters=1 for 122ms
W/MountService( 401): Duplicate state transition (mounted -> mounted) for /storage/emulated/0
W/art ( 401): Long monitor contention event with owner method=int com.android.server.am.ActivityManagerService.startIsolatedProcess(java.lang.String, java.lang.String[], java.lang.String, java.lang.String, int, java.lang.Runnable) from ActivityManagerService.java:2741 waiters=2 for 120ms
D/UsbHostManager( 401): Added device UsbDevice[mName=/dev/bus/usb/001/004,mVendorId=5656,mProductId=37139,mClass=0,mSubclass=0,mProtocol=0,mManufacturerName=Redpine Inc,mProductName=RPI USB Device,mSerialNumber=000000000001,mConfigurations=[
D/UsbHostManager( 401): UsbConfiguration[mId=1,mName=#02,mAttributes=192,mMaxPower=1,mInterfaces=[
D/UsbHostManager( 401): UsbInterface[mId=0,mAlternateSetting=0,mName=null,mClass=0,mSubclass=0,mProtocol=0,mEndpoints=[
D/UsbHostManager( 401): UsbEndpoint[mAddress=129,mAttributes=2,mMaxPacketSize=512,mInterval=0]
D/UsbHostManager( 401): UsbEndpoint[mAddress=1,mAttributes=2,mMaxPacketSize=512,mInterval=0]
D/UsbHostManager( 401): UsbEndpoint[mAddress=130,mAttributes=2,mMaxPacketSize=512,mInterval=0]
D/UsbHostManager( 401): UsbEndpoint[mAddress=2,mAttributes=2,mMaxPacketSize=512,mInterval=0]
D/UsbHostManager( 401): UsbEndpoint[mAddress=131,mAttributes=2,mMaxPacketSize=512,mInterval=0]
D/UsbHostManager( 401): UsbEndpoint[mAddress=3,mAttributes=2,mMaxPacketSize=512,mInterval=0]]]]
D/NetworkManagementService( 401): enabling bandwidth control
I/Telecom ( 401): TelecomGlobals: CallsManager initialized
W/ContextImpl( 401): Calling a method in the system process without a qualified user: android.app.ContextImpl.startService:1692 android.content.ContextWrapper.startService:516 com.android.server.telecom.BluetoothPhoneService.start:440 com.android.server.telecom.TelecomGlobals.initialize:93 com.android.server.telecom.TelecomService.onCreate:164
I/ValidateNoPeople( 401): skipping global notification
I/art ( 148): Explicit concurrent mark sweep GC freed 704(30KB) AllocSpace objects, 0(0B) LOS objects, 91% free, 92KB/1116KB, paused 279us total 125.683ms
W/ResourcesManager( 771): Asset path '/system/framework/freescale-extended.jar' does not exist or contains no resources.
I/art ( 148): Explicit concurrent mark sweep GC freed 7(240B) AllocSpace objects, 0(0B) LOS objects, 91% free, 92KB/1116KB, paused 264us total 74.278ms
I/art ( 148): Explicit concurrent mark sweep GC freed 5(160B) AllocSpace objects, 0(0B) LOS objects, 91% free, 92KB/1116KB, paused 262us total 26.497ms
V/SystemUIService( 771): Starting SystemUI services.
V/FingerprintService( 401): startListening(android.service.fingerprint.IFingerprintServiceReceiver$Stub$Proxy@7a7d7a2)
E/NetdConnector( 401): NDC Command {6 bandwidth enable} took too long (1126ms)
D/NuPlayerDriver( 143): start(0xb5873ee0)
I/GenericSource( 143): start
W/OMXNodeInstance( 143): [e:google.mpeg4.decoder] component does not support metadata mode; using fallback
W/OMXNodeInstance( 143): [f:google.h263.decoder] component does not support metadata mode; using fallback
W/OMXNodeInstance( 143): [10:google.h264.decoder] component does not support metadata mode; using fallback
I/art ( 756): System.exit called, status: 0
I/AndroidRuntime( 756): VM exiting with result code 0, cleanup skipped.
D/SoftHEVC( 143): Number of CPU cores: 1
D/SoftHEVC( 143): Initializing decoder
D/SoftHEVC( 143): Set number of cores to 1
D/SoftHEVC( 143): Ittiam decoder version number: @(#)Id:HEVCDEC_production Ver:04.01 Released by ITTIAM Build: Feb 25 2016 @ 15:32:06
W/OMXNodeInstance( 143): [11:google.hevc.decoder] component does not support metadata mode; using fallback
D/SoftHEVC( 143): Freeing codec memory
D/SoftHEVC( 143): In SoftHEVC::~SoftHEVC
W/OMXNodeInstance( 143): [12:google.vp8.decoder] component does not support metadata mode; using fallback
W/OMXNodeInstance( 143): [13:google.vp9.decoder] component does not support metadata mode; using fallback
I/SoftMPEG4Encoder( 143): Construct SoftMPEG4Encoder
W/ACodec ( 143): do not know color format 0x7f000789 = 2130708361
I/SoftAVCEncoder( 143): Construct SoftAVCEncoder
W/art ( 771): Suspending all threads took: 7.976ms
D/NuPlayerDriver( 143): reset(0xb5873ee0)
D/NuPlayerDriver( 143): notifyResetComplete(0xb5873ee0)
D/NuPlayerDriver( 143): start(0xb5987100)
D/NuPlayerDriver( 143): reset(0xb5987100)
D/NuPlayerDriver( 143): notifyResetComplete(0xb5987100)
D/PermissionMonitor( 401): Monitoring
D/PermissionMonitor( 401): Users: 1, Apps: 46
I/SystemServiceManager( 401): Starting phase 600
D/ZenLog ( 401): downtime: Autotrigger skipped: not in downtime
I/BackupManagerService( 401): Backup enabled => false
I/BackupManagerService( 401): Opting out of backup
E/InputMethodManagerService( 401): Ignoring setImeWindowStatus due to an invalid token. uid:1000 token:null
W/InputMethodManagerService( 401): Reset the default IME as "Resource" is ready here.
I/InputMethodManagerService( 401): Selected default: com.android.inputmethod.latin/.LatinIME
I/ActivityManager( 401): Config changes=20 {1.0 ?mcc?mnc en_US ?layoutDir sw640dp w1066dp h566dp 120dpi lrg land -touch -keyb/v/h -nav/h s.5}
D/VolumeUI( 771): Registering volume controller
I/ActivityManager( 401): Start proc 924:com.android.inputmethod.latin/u0a29 for service com.android.inputmethod.latin/.LatinIME
V/InputMethodManagerService( 401): Adding window token: android.os.Binder@1d1236ca
W/InputMethodManagerService( 401): Illegal subtype state: old subtype = null, new subtype = android.view.inputmethod.InputMethodSubtype@c9194f98
D/GpsLocationProvider( 401): Reset GPS properties, previous size = 0
D/GpsLocationProvider( 401): GpsParamsResource: SUPL_HOST=supl.google.com
D/GpsLocationProvider( 401): GpsParamsResource: SUPL_PORT=7275
D/GpsLocationProvider( 401): GpsParamsResource: NTP_SERVER=north-america.pool.ntp.org
D/GpsLocationProvider( 401): GpsParamsResource: SUPL_VER=0x20000
D/GpsLocationProvider( 401): GpsParamsResource: SUPL_MODE=1
W/GpsLocationProvider( 401): Could not open GPS configuration file /etc/gps.conf
D/GpsLocationProvider( 401): GPS properties reloaded, size = 5
E/GpsLocationProvider( 401): no AGPS interface in set_agps_server
E/GpsLocationProvider( 401): no GPS configuration interface in configuraiton_update
D/GpsLocationProvider( 401): final config = #Thu Jan 01 00:09:23 GMT+00:00 1970
D/GpsLocationProvider( 401): SUPL_VER=0x20000
D/GpsLocationProvider( 401): SUPL_HOST=supl.google.com
D/GpsLocationProvider( 401): NTP_SERVER=north-america.pool.ntp.org
D/GpsLocationProvider( 401): SUPL_PORT=7275
D/GpsLocationProvider( 401): SUPL_MODE=1
W/LocationManagerService( 401): no network location provider found
W/ResourcesManager( 401): Asset path '/system/framework/com.android.location.provider.jar' does not exist or contains no resources.
E/LocationManagerService( 401): no geocoder provider found
E/FlpHardwareProvider( 401): Error hw_get_module 'flp': -2
E/LocationManagerService( 401): FLP HAL not supported
E/LocationManagerService( 401): Unable to bind FLP Geofence proxy.
E/ActivityRecognitionHardware( 401): Error hw_get_module: -2
E/LocationManagerService( 401): Hardware Activity-Recognition not supported.
I/CommonTimeManagementService( 401): No common time service detected on this platform. Common time services will be unavailable.
I/InputReader( 401): Reconfiguring input devices. changes=0x00000020
I/InputReader( 401): Reconfiguring input devices. changes=0x00000010
I/MmsServiceBroker( 401): Delay connecting to MmsService until an API is called
W/VoiceInteractionManagerService( 401): no available voice interaction services found for user 0
W/VoiceInteractionManagerService( 401): no available voice recognition services found for user 0
I/art ( 771): Background sticky concurrent mark sweep GC freed 3121(150KB) AllocSpace objects, 0(0B) LOS objects, 16% free, 1175KB/1406KB, paused 825us total 147.079ms
I/StatusBarManagerService( 401): registerStatusBar bar=com.android.internal.statusbar.IStatusBar$Stub$Proxy@3e71bff4
I/ActivityManager( 401): Start proc 957:com.android.phone/1001 for added application com.android.phone
I/ActivityManager( 401): START u0 {act=android.intent.action.MAIN cat=[android.intent.category.HOME] flg=0x10000000 cmp=com.android.settings/.CryptKeeper} from uid 0 on display 0
W/ResourcesManager( 401): Asset path '/system/framework/freescale-extended.jar' does not exist or contains no resources.
V/WindowManager( 401): addAppToken: AppWindowToken{1e4e760 token=Token{108c0f63 ActivityRecord{3e649992 u0 com.android.settings/.CryptKeeper t1}}} to stack=0 task=1 at 0
D/NuPlayerDriver( 143): start(0xb5987220)
D/NuPlayerDriver( 143): reset(0xb5987220)
D/NuPlayerDriver( 143): notifyResetComplete(0xb5987220)
I/ActivityManager( 401): Start proc 984:com.android.settings/1000 for activity com.android.settings/.CryptKeeper
W/art ( 401): Long monitor contention event with owner method=void com.android.server.am.ActivityManagerService.systemReady(java.lang.Runnable) from ActivityManagerService.java:11318 waiters=0 for 364ms
V/WiredAccessoryManager( 401): init()
W/art ( 401): Long monitor contention event with owner method=void com.android.server.am.ActivityManagerService.systemReady(java.lang.Runnable) from ActivityManagerService.java:11318 waiters=2 for 131ms
I/art ( 148): Background concurrent mark sweep GC freed 796(33KB) AllocSpace objects, 0(0B) LOS objects, 91% free, 93KB/1117KB, paused 228us total 127.568ms
I/ActivityManager( 401): Start proc 1019:android.process.media/u0a5 for broadcast com.android.providers.media/.MtpReceiver
D/GpsNetInitiatedHandler( 401): location enabled :false
W/ResourcesManager( 984): Asset path '/system/framework/freescale-extended.jar' does not exist or contains no resources.
I/art ( 401): Background sticky concurrent mark sweep GC freed 23905(1893KB) AllocSpace objects, 1(16KB) LOS objects, 19% free, 5MB/7MB, paused 4.373ms total 570.435ms
W/art ( 401): No such thread id for suspend: 70
W/art ( 741): Long monitor contention event with owner method=long android.database.sqlite.SQLiteConnection.nativePrepareStatement(long, java.lang.String) from SQLiteConnection.java:4294967294 waiters=0 for 3.207s
I/ActivityManager( 401): START u0 {act=android.intent.action.MAIN cat=[android.intent.category.HOME] flg=0x10000000 cmp=com.android.provision/.DefaultActivity} from uid 0 on display 0
W/AppWidgetServiceImpl( 401): Failed to read state: java.io.FileNotFoundException: /data/system/users/0/appwidgets.xml: open failed: ENOENT (No such file or directory)
V/AppWidgetServiceImpl( 401): Upgrading widget database from 0 to 1
V/WindowManager( 401): addAppToken: AppWindowToken{1bb255af token=Token{3bf2198e ActivityRecord{1c0f1589 u0 com.android.provision/.DefaultActivity t2}}} to stack=0 task=2 at 0
D/BluetoothManagerService( 401): Message: 300
D/BluetoothManagerService( 401): MESSAGE_USER_SWITCHED
D/PermissionCache( 125): checking android.permission.HARDWARE_TEST for uid=1000 => granted (246 us)
I/LatinIME( 924): Hardware accelerated drawing: true
I/ActivityManager( 401): Start proc 1048:com.android.provision/u0a38 for activity com.android.provision/.DefaultActivity
I/art ( 771): Background sticky concurrent mark sweep GC freed 6062(499KB) AllocSpace objects, 0(0B) LOS objects, 24% free, 1731KB/2MB, paused 5.925ms total 50.874ms
W/BackupManagerService( 401): dataChanged but no participant pkg='com.android.providers.settings' uid=10038
W/InputAttributes( 924): No editor info for this field. Bug?
I/LatinIME:LogUtils( 924): Dictionary info: dictionary = UserHistoryDictionary.en_US ; version = 565 ; date = ?
I/LatinIME:LogUtils( 924): Dictionary info: dictionary = PersonalizationDictionary.en_US ; version = 565 ; date = ?
I/LatinIME:LogUtils( 924): Dictionary info: dictionary = userunigram.en_US ; version = 565 ; date = ?
I/LatinIME:LogUtils( 924): Dictionary info: dictionary = contacts.en_US ; version = 565 ; date = ?
I/LatinIME:LogUtils( 924): Dictionary info: dictionary = ContextualDictionary.en_US ; version = 565 ; date = ?
I/art ( 401): WaitForGcToComplete blocked for 476.688ms for cause Background
I/ActivityManager( 401): START u0 {act=android.intent.action.MAIN cat=[android.intent.category.HOME] flg=0x10000000 cmp=com.android.launcher/com.android.launcher2.Launcher} from uid 0 on display 0
V/WindowManager( 401): addAppToken: AppWindowToken{31446e84 token=Token{134e6c97 ActivityRecord{33361b16 u0 com.android.launcher/com.android.launcher2.Launcher t3}}} to stack=0 task=3 at 0
I/ActivityManager( 401): Start proc 1079:com.android.launcher/u0a7 for activity com.android.launcher/com.android.launcher2.Launcher
I/art ( 401): Background partial concurrent mark sweep GC freed 15613(1637KB) AllocSpace objects, 12(520KB) LOS objects, 33% free, 5MB/8MB, paused 6.778ms total 557.110ms
I/art ( 771): Background partial concurrent mark sweep GC freed 1935(146KB) AllocSpace objects, 0(0B) LOS objects, 39% free, 2MB/3MB, paused 10.360ms total 82.457ms
D/BluetoothManagerService( 401): Added callback: android.bluetooth.IBluetoothManagerCallback$Stub$Proxy@2651324c:true
D/BluetoothAdapter( 771): 580511426: getState() : mService = null. Returning STATE_OFF
E/BluetoothA2dpSink( 771): Could not bind to Bluetooth A2DP Service with Intent { act=android.bluetooth.IBluetoothA2dpSink }
E/BluetoothAvrcpController( 771): Could not bind to Bluetooth AVRCP Controller Service with Intent { act=android.bluetooth.IBluetoothAvrcpController }
E/BluetoothHeadsetClient( 771): Could not bind to Bluetooth Headset Client Service with Intent { act=android.bluetooth.IBluetoothHeadsetClient }
D/BluetoothMap( 771): Create BluetoothMap proxy object
D/ConnectivityService( 401): listenForNetwork for NetworkRequest [ id=2, legacyType=-1, [] ]
I/CameraManagerGlobal( 771): getCameraService: Reconnecting to camera service
I/CameraService( 143): getCameraCharacteristics: Switching to HAL1 shim implementation...
I/ActivityManager( 401): Start proc 1102:com.android.printspooler/u0a37 for service com.android.printspooler/.model.PrintSpoolerService
I/PrintSpoolerService( 1102): No existing print spooler state.
I/FusedLocation( 401): engine started (com.android.location.fused)
I/CameraClient( 143): Opening camera 0
I/FslCameraHAL( 143): camera_device open: 0
I/FslCameraHAL( 143): initialize name:csi, path:/dev/video0
I/FslCameraHAL( 143): DeviceAdapter: Create ov5640 device
I/FslCameraHAL( 143): sfmt[0]=NV12, dfmt[0]=YUYV
I/FslCameraHAL( 143): sfmt[1]=YUYV, dfmt[0]=YUYV
I/FslCameraHAL( 143): pixel format: 0x14
I/FslCameraHAL( 143): SupportedPictureSizes is
I/FslCameraHAL( 143): SupportedPreviewSizes is
I/FslCameraHAL( 143): SupportedFPS is 15,30
I/FslCameraHAL( 143): Preview callback not enabled c0d
I/FslCameraHAL( 143): enableMsgType 0xc0d
I/FslCameraHAL( 143): Disabling Preview Callback
I/FslCameraHAL( 143): disableMsgType 0xffff
I/FslCameraHAL( 143): stopPreview
I/FslCameraHAL( 143): stopPreview return with preview not enabled
I/FslCameraHAL( 143): cancelPicture
I/FslCameraHAL( 143): stopPicture
E/FslCameraHAL( 143): takePicture not running
I/CameraClient( 143): Destroying camera 0
I/FslCameraHAL( 143): Bridge Thread exiting...
D/NuPlayerDriver( 143): reset(0xb5987520)
D/NuPlayerDriver( 143): notifyResetComplete(0xb5987520)
E/Camera2-Metadata( 143): updateImpl: Unable to update metadata entry android.scaler.availableStreamConfigurations (d000a): Unknown error -1 (1)
E/FlashlightController( 771): Couldn't initialize.
E/FlashlightController( 771): java.lang.AssertionError: Expected to get non-empty characteristics
E/FlashlightController( 771): at android.hardware.camera2.CameraManager.getOrCreateDeviceIdListLocked(CameraManager.java:465)
E/FlashlightController( 771): at android.hardware.camera2.CameraManager.getCameraIdList(CameraManager.java:92)
E/FlashlightController( 771): at com.android.systemui.statusbar.policy.FlashlightController.getCameraId(FlashlightController.java:167)
E/FlashlightController( 771): at com.android.systemui.statusbar.policy.FlashlightController.initialize(FlashlightController.java:76)
E/FlashlightController( 771): at com.android.systemui.statusbar.policy.FlashlightController.<init>(FlashlightController.java:71)
E/FlashlightController( 771): at com.android.systemui.statusbar.phone.PhoneStatusBar.makeStatusBarView(PhoneStatusBar.java:873)
E/FlashlightController( 771): at com.android.systemui.statusbar.phone.PhoneStatusBar.addStatusBarWindow(PhoneStatusBar.java:3047)
E/FlashlightController( 771): at com.android.systemui.statusbar.phone.PhoneStatusBar.createAndAddWindows(PhoneStatusBar.java:3043)
E/FlashlightController( 771): at com.android.systemui.statusbar.BaseStatusBar.start(BaseStatusBar.java:562)
E/FlashlightController( 771): at com.android.systemui.statusbar.phone.PhoneStatusBar.start(PhoneStatusBar.java:588)
E/FlashlightController( 771): at com.android.systemui.statusbar.SystemBars.createStatusBarFromConfig(SystemBars.java:106)
E/FlashlightController( 771): at com.android.systemui.statusbar.SystemBars.onNoService(SystemBars.java:58)
E/FlashlightController( 771): at com.android.systemui.statusbar.ServiceMonitor.startService(ServiceMonitor.java:228)
E/FlashlightController( 771): at com.android.systemui.statusbar.ServiceMonitor.access$000(ServiceMonitor.java:49)
E/FlashlightController( 771): at com.android.systemui.statusbar.ServiceMonitor$1.handleMessage(ServiceMonitor.java:73)
E/FlashlightController( 771): at android.os.Handler.dispatchMessage(Handler.java:102)
E/FlashlightController( 771): at android.os.Looper.loop(Looper.java:135)
E/FlashlightController( 771): at android.app.ActivityThread.main(ActivityThread.java:5254)
E/FlashlightController( 771): at java.lang.reflect.Method.invoke(Native Method)
E/FlashlightController( 771): at java.lang.reflect.Method.invoke(Method.java:372)
E/FlashlightController( 771): at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:903)
E/FlashlightController( 771): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:698)
I/art ( 957): Background sticky concurrent mark sweep GC freed 10650(504KB) AllocSpace objects, 0(0B) LOS objects, 33% free, 927KB/1396KB, paused 9.361ms total 99.071ms
D/PhoneStatusBar( 771): disable: < EXPAND* icons alerts system_info BACK* HOME* RECENT* clock SEARCH* >
D/PhoneStatusBar( 771): heads up is enabled
D/StatusBar( 771): user hasn't seen notification about hidden notifications
D/StatusBar( 771): insecure lockscreen, skipping notification
W/BackupManagerService( 401): dataChanged but no participant pkg='com.android.providers.settings' uid=10014
I/Choreographer( 771): Skipped 281 frames! The application may be doing too much work on its main thread.
D/ViewRootImpl( 771): changeCanvasOpacity: opaque=true
D/TelephonyProvider( 957): dbh.onCreate:+ db=SQLiteDatabase: /data/data/com.android.providers.telephony/databases/telephony.db
D/TelephonyProvider( 957): dbh.createSimInfoTable:+
D/TelephonyProvider( 957): dbh.createSimInfoTable:-
D/TelephonyProvider( 957): dbh.createCarriersTable:+
D/TelephonyProvider( 957): dbh.createCarriersTable:-
D/TelephonyProvider( 957): No APNs in OEM image = /oem/telephony/apns-conf.xml Load APNs from system image
D/TelephonyProvider( 957): confFile = /system/etc/apns-conf.xml
I/art ( 771): Background sticky concurrent mark sweep GC freed 6736(509KB) AllocSpace objects, 0(0B) LOS objects, 16% free, 2MB/3MB, paused 5.457ms total 96.143ms
D/TelephonyProvider( 957): dbh.onCreate:- db=SQLiteDatabase: /data/data/com.android.providers.telephony/databases/telephony.db
D/TelephonyProvider( 957): dbh.onOpen: ok, queried table=siminfo
D/TelephonyProvider( 957): dbh.onOpen: ok, queried table=carriers
E/DcSwitchStateMachine-0( 957): DctController is not ready
E/ConnectivityService( 401): Failed to find Messenger in unregisterNetworkFactory
D/ConnectivityService( 401): Got NetworkFactory Messenger for Telephony
D/GpsLocationProvider( 401): received SIM realted action:
I/art ( 957): Background partial concurrent mark sweep GC freed 3290(286KB) AllocSpace objects, 1(16KB) LOS objects, 49% free, 1052KB/2MB, paused 6.811ms total 149.966ms
I/art ( 771): Background partial concurrent mark sweep GC freed 1395(162KB) AllocSpace objects, 0(0B) LOS objects, 39% free, 18MB/30MB, paused 664us total 156.034ms
I/imx6.gralloc( 771): open gpu gralloc module!
D/GpsLocationProvider( 401): SIM MCC/MNC is still not available
I/PackageManager( 401): Replacing preferred activity com.android.mms/.ui.ComposeMessageActivity for user 0:
I/PackageManager( 401): Action: "android.intent.action.SENDTO"
I/PackageManager( 401): Category: "android.intent.category.DEFAULT"
I/PackageManager( 401): Scheme: "sms"
I/PackageManager( 401): Scheme: "smsto"
I/PackageManager( 401): Scheme: "mms"
I/PackageManager( 401): Scheme: "mmsto"
I/art ( 1019): WaitForGcToComplete blocked for 25.277ms for cause HomogeneousSpaceCompact
D/BluetoothManagerService( 401): Added callback: android.bluetooth.IBluetoothManagerCallback$Stub$Proxy@3447dbad:true
W/art ( 1079): Suspending all threads took: 17.845ms
I/art ( 1079): Background sticky concurrent mark sweep GC freed 2758(280KB) AllocSpace objects, 1(16KB) LOS objects, 33% free, 747KB/1117KB, paused 18.715ms total 85.728ms
I/Telephony( 957): TtyManager: updateUiTtyMode -1 -> 0
I/Choreographer( 771): Skipped 103 frames! The application may be doing too much work on its main thread.
W/OpenGLRenderer( 771): can't set property, no Caches instance
V/KeyguardUpdateMonitor( 771): action android.intent.action.SIM_STATE_CHANGED state: NOT_READY slotId: 0 subid: -2
D/TelephonyDebugService( 957): TelephonyDebugService()
I/art ( 1079): Background partial concurrent mark sweep GC freed 590(124KB) AllocSpace objects, 0(0B) LOS objects, 44% free, 1253KB/2MB, paused 504us total 105.891ms
I/Choreographer( 771): Skipped 30 frames! The application may be doing too much work on its main thread.
D/KeyguardUpdateMonitor( 771): handleSimStateChange(subId=-2, slotId=0, state=UNKNOWN)
W/KeyguardUpdateMonitor( 771): invalid subId in handleSimStateChange()
V/KeyguardUpdateMonitor( 771): onSubscriptionInfoChanged()
V/KeyguardUpdateMonitor( 771): onSubscriptionInfoChanged: list is null
W/Resources( 1079): Converting to int: TypedValue{t=0x3/d=0x15 "2" a=-1}
I/Telephony( 957): PstnIncomingCallNotifier: Registering: Handler (com.android.internal.telephony.gsm.GSMPhone) {39b29ab2}
W/Launcher.LauncherProvider( 1079): Unable to add favorite: com.android.gallery3d/com.android.gallery3d.app.Gallery
W/Launcher.LauncherProvider( 1079): android.content.pm.PackageManager$NameNotFoundException: ComponentInfo{com.android.gallery3d/com.android.gallery3d.app.Gallery}
W/Launcher.LauncherProvider( 1079): at android.app.ApplicationPackageManager.getActivityInfo(ApplicationPackageManager.java:314)
W/Launcher.LauncherProvider( 1079): at com.android.launcher2.LauncherProvider$DatabaseHelper.addAppShortcut(LauncherProvider.java:997)
W/Launcher.LauncherProvider( 1079): at com.android.launcher2.LauncherProvider$DatabaseHelper.loadFavorites(LauncherProvider.java:901)
W/Launcher.LauncherProvider( 1079): at com.android.launcher2.LauncherProvider$DatabaseHelper.access$000(LauncherProvider.java:254)
W/Launcher.LauncherProvider( 1079): at com.android.launcher2.LauncherProvider.loadDefaultFavoritesIfNecessary(LauncherProvider.java:238)
W/Launcher.LauncherProvider( 1079): at com.android.launcher2.LauncherModel$LoaderTask.loadWorkspace(LauncherModel.java:1276)
W/Launcher.LauncherProvider( 1079): at com.android.launcher2.LauncherModel$LoaderTask.loadAndBindWorkspace(LauncherModel.java:1030)
W/Launcher.LauncherProvider( 1079): at com.android.launcher2.LauncherModel$LoaderTask.run(LauncherModel.java:1133)
W/Launcher.LauncherProvider( 1079): at android.os.Handler.handleCallback(Handler.java:739)
W/Launcher.LauncherProvider( 1079): at android.os.Handler.dispatchMessage(Handler.java:95)
W/Launcher.LauncherProvider( 1079): at android.os.Looper.loop(Looper.java:135)
W/Launcher.LauncherProvider( 1079): at android.os.HandlerThread.run(HandlerThread.java:61)
V/WindowManager( 401): Based on layer: Adding window Window{16e05578 u0 com.android.launcher/com.android.launcher2.Launcher} at 1 of 6
I/art ( 401): Explicit concurrent mark sweep GC freed 9829(936KB) AllocSpace objects, 16(755KB) LOS objects, 33% free, 5MB/8MB, paused 1.937ms total 490.210ms
W/art ( 957): Suspending all threads took: 14.453ms
I/art ( 957): Background sticky concurrent mark sweep GC freed 10213(780KB) AllocSpace objects, 1(16KB) LOS objects, 33% free, 1384KB/2MB, paused 15.230ms total 459.513ms
I/art ( 957): WaitForGcToComplete blocked for 315.484ms for cause HeapTrim
I/imx6.gralloc( 1079): open gpu gralloc module!
I/art ( 1019): WaitForGcToComplete blocked for 74.535ms for cause DisableMovingGc
I/ActivityManager( 401): Displayed com.android.launcher/com.android.launcher2.Launcher: +5s151ms (total +7s640ms)
V/KeyguardServiceDelegate( 401): *** Keyguard started
W/KeyguardServiceDelegate( 401): onScreenTurnedOn(): no keyguard service!
V/KeyguardServiceDelegate( 401): *** Keyguard connected (yay!)
D/VoldCmdListener( 124): cryptfs getpw
D/VoldCmdListener( 124): cryptfs clearpw
D/PhoneStatusBar( 771): disable: < EXPAND ICONS* alerts SYSTEM_INFO* BACK HOME RECENT clock SEARCH >
D/PhoneStatusBar( 771): disable: < EXPAND ICONS alerts SYSTEM_INFO BACK HOME RECENT clock SEARCH >
I/MediaProvider( 1019): Upgrading media database from version 0 to 800, which will destroy all old data
W/art ( 401): Long monitor contention event with owner method=java.io.FileDescriptor libcore.io.Posix.open(java.lang.String, int, int) from Posix.java:4294967294 waiters=0 for 649ms
D/PhoneStatusBar( 771): disable: < expand* ICONS alerts SYSTEM_INFO back* HOME RECENT clock SEARCH >
V/KeyguardServiceDelegate( 401): **** SHOWN CALLED ****
I/SurfaceFlinger( 125): Boot is finished (407847 ms)
E/installd( 144): Unable to unlink boot marker at /data/dalvik-cache/arm/.booting, error=No such file or directory
E/ActivityManager( 401): Unable to mark boot complete for abi: armeabi-v7a
I/SystemServiceManager( 401): Starting phase 1000
D/MediaProvider( 1019): Adjusting external storage paths to: /storage/emulated/0
I/Choreographer( 1079): Skipped 34 frames! The application may be doing too much work on its main thread.
I/ContactLocale( 741): AddressBook Labels [en-US]: [, A, B, C, D, E, F, G, H, I, J, K, L, M, N, O, P, Q, R, S, T, U, V, W, X, Y, Z, Α, Β, Γ, Δ, Ε, Ζ, Η, Θ, Ι, Κ, Λ, Μ, Ν, Ξ, Ο, Π, Ρ, Σ, Τ, Υ, Φ, Χ, Ψ, Ω, , А, Б, В, Г, Д, Ђ, Е, Є, Ж, З, И, І, Ї, Й, Ј, К, Л, Љ, М, Н, Њ, О, П, Р, С, Т, Ћ, У, Ф, Х, Ц, Ч, Џ, Ш, Щ, Ю, Я, , א, ב, ג, ד, ה, ו, ז, ח, ט, י, כ, ל, מ, נ, ס, ע, פ, צ, ק, ר, ש, ת, , ا, ب, ت, ث, ج, ح, خ, د, ذ, ر, ز, س, ش, ص, ض, ط, ظ, ع, غ, ف, ق, ك, ل, م, ن, ه, و, ي, , ก, ข, ฃ, ค, ฅ, ฆ, ง, จ, ฉ, ช, ซ, ฌ, ญ, ฎ, ฏ, ฐ, ฑ, ฒ, ณ, ด, ต, ถ, ท, ธ, น, บ, ป, ผ, ฝ, พ, ฟ, ภ, ม, ย, ร, ฤ, ล, ฦ, ว, ศ, ษ, ส, ห, ฬ, อ, ฮ, , ㄱ, ㄴ, ㄷ, ㄹ, ㅁ, ㅂ, ㅅ, ㅇ, ㅈ, ㅊ, ㅋ, ㅌ, ㅍ, ㅎ, , あ, か, さ, た, な, は, ま, や, ら, わ, #, ]
D/BackupManagerService( 401): Received broadcast Intent { act=android.intent.action.PACKAGE_CHANGED dat=package:com.android.provision flg=0x4000010 (has extras) }
D/BackupManagerService( 401): Received broadcast Intent { act=android.intent.action.PACKAGE_CHANGED dat=package:com.android.settings flg=0x4000010 (has extras) }
I/LatinIME:LogUtils( 924): Dictionary info: dictionary = main:de ; version = 44 ; date = 1393228134
I/LatinIME:LogUtils( 924): Dictionary info: dictionary = main:fr ; version = 45 ; date = 1400639634
I/LatinIME:LogUtils( 924): Dictionary info: dictionary = main:es ; version = 49 ; date = 1404131686
I/LatinIME:LogUtils( 924): Dictionary info: dictionary = main:it ; version = 44 ; date = 1393228135
I/LatinIME:LogUtils( 924): Dictionary info: dictionary = main:ru ; version = 50 ; date = 1406597821
I/LatinIME:LogUtils( 924): Dictionary info: dictionary = main:en ; version = 47 ; date = 1402373178
E/SQLiteLog( 1019): (1) no such table: album_info
I/art ( 1079): Background sticky concurrent mark sweep GC freed 6734(398KB) AllocSpace objects, 1(16KB) LOS objects, 7% free, 6MB/6MB, paused 5.473ms total 24.216ms
I/ActivityManager( 401): Start proc 1167:com.android.music/u0a33 for broadcast com.android.music/.MediaButtonIntentReceiver
D/MtpService( 1019): updating state; isCurrentUser=true, mMtpLocked=false
D/MtpService( 1019): addStorageLocked 65537 /storage/emulated/0
D/MtpService( 1019): starting MTP server in MTP mode
W/art ( 1079): Long monitor contention event with owner method=long android.database.sqlite.SQLiteConnection.nativeOpen(java.lang.String, int, java.lang.String, boolean, boolean) from SQLiteConnection.java:4294967294 waiters=0 for 4.992s
I/ActivityManager( 401): Start proc 1187:com.android.deskclock/u0a24 for broadcast com.android.deskclock/com.android.alarmclock.AnalogAppWidgetProvider
D/BluetoothManagerService( 401): Retrieving Bluetooth Adapter name and address...
D/BluetoothManagerService( 401): getNameAndAddress(): mBluetooth = null mBinding = false
D/BluetoothManagerService( 401): Message: 200
D/BluetoothManagerService( 401): MESSAGE_GET_NAME_AND_ADDRESS
D/BluetoothManagerService( 401): Binding to service to get name and address
I/ActivityManager( 401): Start proc 1208:com.android.bluetooth/1002 for service com.android.bluetooth/.btservice.AdapterService
E/WifiStateMachine( 401): handleMessage: E msg.what=131206
E/WifiStateMachine( 401): InitialState !CMD_BOOT_COMPLETED 0 0
E/WifiStateMachine( 401): DefaultState !CMD_BOOT_COMPLETED 0 0
D/WIFI ( 401): Registering NetworkFactory
D/ConnectivityService( 401): Got NetworkFactory Messenger for WIFI
D/WIFI_UT ( 401): Registering NetworkFactory
D/ConnectivityService( 401): Got NetworkFactory Messenger for WIFI_UT
D/WIFI ( 401): got request NetworkRequest [ id=1, legacyType=-1, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN] ] with score 0
D/WIFI_UT ( 401): got request NetworkRequest [ id=1, legacyType=-1, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN] ] with score 0
W/ResourcesManager( 1208): Asset path '/system/framework/javax.obex.jar' does not exist or contains no resources.
W/art ( 401): Long monitor contention event with owner method=boolean android.os.MessageQueue.enqueueMessage(android.os.Message, long) from MessageQueue.java:323 waiters=0 for 123ms
I/ActivityManager( 401): Start proc 1226:com.android.calendar/u0a20 for broadcast com.android.calendar/.UpgradeReceiver
I/art ( 148): Explicit concurrent mark sweep GC freed 706(30KB) AllocSpace objects, 0(0B) LOS objects, 91% free, 92KB/1116KB, paused 260us total 45.185ms
I/art ( 148): Explicit concurrent mark sweep GC freed 5(160B) AllocSpace objects, 0(0B) LOS objects, 91% free, 92KB/1116KB, paused 258us total 15.778ms
I/art ( 148): Explicit concurrent mark sweep GC freed 5(160B) AllocSpace objects, 0(0B) LOS objects, 91% free, 92KB/1116KB, paused 258us total 21.055ms
I/ActivityManager( 401): Start proc 1243:com.android.keychain/1000 for service com.android.keychain/.KeyChainService
I/RecoverySystem( 401): Deleted: /cache/recovery/log
D/AdapterServiceConfig( 1208): Adding HeadsetService
D/AdapterServiceConfig( 1208): Adding A2dpService
D/AdapterServiceConfig( 1208): Adding HidService
D/AdapterServiceConfig( 1208): Adding HealthService
D/AdapterServiceConfig( 1208): Adding PanService
D/AdapterServiceConfig( 1208): Adding GattService
D/AdapterServiceConfig( 1208): Adding BluetoothMapService
I/DownloadManager( 1019): Upgrading downloads database from version 0 to version 109, which will destroy all old data
I/BootReceiver( 401): Copying /cache/recovery/last_kmsg to DropBox (SYSTEM_RECOVERY_KMSG)
D/BluetoothManagerService( 401): Added callback: android.bluetooth.IBluetoothManagerCallback$Stub$Proxy@260b1f3:true
D/BluetoothAdapterState( 1208): make
I/bluedroid( 1208): init
E/bt-btif ( 1208): btif_config_get(L190): assert failed: section && *section && key && *key && name && *name && bytes && type
I/BluetoothAdapterState( 1208): Entering OffState
I/bte_conf( 1208): bte_load_conf attempt to load stack conf from /etc/bluetooth/bt_stack.conf
I/bte_conf( 1208): bte_load_ble_conf attempt to load ble stack conf from /etc/bluetooth/ble_stack.conf
E/bt_osi_config( 1208): config_new unable to open file '/etc/bluetooth/ble_stack.conf': No such file or directory
I/bte_conf( 1208): bte_load_ble_conf file >/etc/bluetooth/ble_stack.conf< not found
I/BootReceiver( 401): Copying audit failures to DropBox
I/BootReceiver( 401): Checking for fsck errors
I/bluedroid( 1208): get_profile_interface socket
I/bluedroid( 1208): get_profile_interface map_client
D/BluetoothManagerService( 401): BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService
D/BluetoothManagerService( 401): Message: 40
D/BluetoothManagerService( 401): MESSAGE_BLUETOOTH_SERVICE_CONNECTED: 1
I/bluedroid( 1208): config_hci_snoop_log
D/BluetoothManagerService( 401): Message: 201
D/BluetoothManagerService( 401): MESSAGE_SAVE_NAME_AND_ADDRESS
D/BluetoothAdapterState( 1208): CURRENT_STATE=OFF, MESSAGE = USER_TURN_ON
D/BluetoothAdapterProperties( 1208): Setting state to 11
I/BluetoothAdapterState( 1208): Bluetooth adapter state changed: 10-> 11
D/BluetoothBondStateMachine( 1208): make
D/BluetoothAdapterService( 1208): getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@1b972243
D/HeadsetService( 1208): Received start request. Starting profile...
I/BluetoothHeadsetServiceJni( 1208): classInitNative: succeeds
D/HeadsetStateMachine( 1208): make
I/GKI_LINUX( 1208): gki_task_entry task_id=1 [BTIF] starting
D/BluetoothAdapterProperties( 1208): Address is:22:22:9B:76:08:D7
D/BluetoothManagerService( 401): Bluetooth Adapter name changed to EVK_MX6SL
D/BluetoothAdapterProperties( 1208): Name is: EVK_MX6SL
I/BluetoothBondStateMachine( 1208): StableState(): Entering Off State
D/HeadsetStateMachine( 1208): max_hf_connections = 1
I/bluedroid( 1208): get_profile_interface handsfree
D/BluetoothA2dp( 771): Proxy object connected
D/A2dpService( 1208): Received start request. Starting profile...
I/BluetoothAvrcpServiceJni( 1208): classInitNative: succeeds
I/bluedroid( 1208): get_profile_interface avrcp
D/HeadsetStateMachine( 1208): Enter Disconnected: -2, size: 0
E/RemoteController( 1208): Cannot set synchronization mode on an unregistered RemoteController
I/BluetoothA2dpServiceJni( 1208): classInitNative: succeeds
D/A2dpStateMachine( 1208): make
I/bluedroid( 1208): get_profile_interface a2dp
I/GKI_LINUX( 1208): gki_task_entry task_id=2 [A2DP-MEDIA] starting
I/BluetoothHidServiceJni( 1208): classInitNative: succeeds
D/BluetoothInputDevice( 771): Proxy object connected
D/HidService( 1208): Received start request. Starting profile...
I/bluedroid( 1208): get_profile_interface hidhost
I/BluetoothHealthServiceJni( 1208): classInitNative: succeeds
D/HealthService( 1208): Received start request. Starting profile...
D/HeadsetStateMachine( 1208): Disconnected process message: 10, size: 0
D/HeadsetPhoneState( 1208): sendDeviceStateChanged. mService=0 mSignal=0 mRoam=0 mBatteryCharge=5
D/HeadsetStateMachine( 1208): Disconnected process message: 11, size: 0
D/A2dpStateMachine( 1208): Enter Disconnected: -2
I/BluetoothAdapterState( 1208): Entering PendingCommandState State: isTurningOn()=true, isTurningOff()=false
I/bluedroid( 1208): get_profile_interface health
I/BluetoothPanServiceJni( 1208): classInitNative(L105): succeeds
D/BluetoothPan( 771): BluetoothPAN Proxy object connected
D/PanService( 1208): Received start request. Starting profile...
D/BluetoothPanServiceJni( 1208): initializeNative(L110): pan
I/bluedroid( 1208): get_profile_interface pan
I/BtGatt.JNI( 1208): classInitNative(L873): classInitNative: Success!
D/BtGatt.DebugUtils( 1208): handleDebugAction() action=null
D/BtGatt.GattService( 1208): Received start request. Starting profile...
D/BtGatt.GattService( 1208): start()
I/bluedroid( 1208): get_profile_interface gatt
D/BtGatt.AdvertiseManager( 1208): advertise manager created
D/BluetoothMap( 771): Proxy object connected
D/BluetoothMapService( 1208): Received start request. Starting profile...
D/BluetoothMapService( 1208): start()
D/BluetoothMapEmailSettingsLoader( 1208): Found 0 applications
D/BluetoothMapEmailAppObserver( 1208): createReceiver()
D/BluetoothMapEmailAppObserver( 1208): initObservers()
D/BluetoothMapEmailAppObserver( 1208): getEnabledAccountItems()
D/BluetoothAdapterState( 1208): CURRENT_STATE=PENDING, MESSAGE = STARTED, isTurningOn=true, isTurningOff=false
I/bluedroid( 1208): enable
D/ExtensionsFactory( 1226): No custom extensions.
I/ActivityManager( 401): Waited long enough for: ServiceRecord{11e7766d u0 com.android.providers.downloads/.DownloadService}
I/bt_hci_bdroid( 1208): init
W/bt_vendor( 1208): ro.boot.btdev is and no mapped bt-vendor
I/GKI_LINUX( 1208): gki_task_entry task_id=0 [BTU] starting
I/bt-btu ( 1208): btu_task pending for preload complete event
I/bt_vendor( 1208): Redpine vendor init got called here!!!
D/BluetoothManagerService( 401): Stored Bluetooth name: EVK_MX6SL
D/HeadsetStateMachine( 1208): Proxy object connected
D/BluetoothA2dp( 401): Proxy object connected
D/BluetoothAdapter( 401): 326757687: getState() : mService = null. Returning STATE_OFF
W/art ( 1019): Long monitor contention event with owner method=boolean android.database.sqlite.SQLiteDatabase.isMainThread() from SQLiteDatabase.java:391 waiters=0 for 935ms
E/bt_vendor( 1208): Mutyam enabling protocol bluetooth protocol:
E/bt_vendor( 1208): ROTOCOL ***
E/bt_vendor( 1208):
I/ActivityManager( 401): Start proc 1290:com.android.providers.calendar/u0a1 for broadcast com.android.providers.calendar/.CalendarReceiver
W/ResourcesManager( 1290): Asset path '/system/framework/android.test.runner.jar' does not exist or contains no resources.
D/ContactDirectoryManager( 741): Found com.android.exchange.directory.provider
I/PowerManagerService( 401): Going to sleep due to screen timeout (uid 1000)...
I/PowerManagerService( 401): Waking up from dozing (uid 1000)...
D/PermissionCache( 125): checking android.permission.READ_FRAME_BUFFER for uid=1000 => granted (9869 us)
I/ARMAssembler( 125): generated scanline__00000077:03010104_00008002_00000000 [ 89 ipp] (110 ins) at [0xacc921f0:0xacc923a8] in 170166 ns
I/ActivityManager( 401): Start proc 1306:com.android.exchange/u0a27 for content provider com.android.exchange/.provider.ExchangeDirectoryProvider
V/KeyguardServiceDelegate( 401): onScreenTurnedOn(showListener = com.android.internal.policy.impl.PhoneWindowManager$2@345f780d)
D/PhoneStatusBar( 771): disable: < expand ICONS alerts SYSTEM_INFO back HOME RECENT clock SEARCH >
E/WifiStateMachine( 401): handleMessage: E msg.what=131167
E/WifiStateMachine( 401): InitialState !CMD_SCREEN_STATE_CHANGED 1 0
E/WifiStateMachine( 401): DefaultState !CMD_SCREEN_STATE_CHANGED 1 0
I/WifiNative-HAL( 401): startHal
E/wifi ( 401): getStaticLongField sWifiHalHandle 0x9a9df85c
D/wifi ( 401): halHandle = 0x0, mVM = 0xb489d200, mCls = 0x100c6a
I/WifiNative-HAL( 401): Could not start hal
E/WifiStateMachine( 401): cancelDelayedScan -> 1
D/WifiStateMachine( 401): backgroundScan enabled=false startBackgroundScanIfNeeded:false
E/WifiStateMachine( 401): handleScreenStateChanged Exit: true
E/WifiStateMachine( 401): handleMessage: E msg.what=131127
E/WifiStateMachine( 401): InitialState !CMD_ENABLE_ALL_NETWORKS 0 0
E/WifiStateMachine( 401): DefaultState !CMD_ENABLE_ALL_NETWORKS 0 0
E/WifiStateMachine( 401): handleMessage: E msg.what=131158
E/WifiStateMachine( 401): InitialState !CMD_SET_SUSPEND_OPT_ENABLED 0 0
E/WifiStateMachine( 401): DefaultState !CMD_SET_SUSPEND_OPT_ENABLED 0 0
E/WifiStateMachine( 401): setSuspendOptimizations: 4 false
E/WifiStateMachine( 401): mSuspendOptNeedsDisabled 4
E/WifiStateMachine( 401): handleMessage: E msg.what=131129
E/WifiStateMachine( 401): InitialState !CMD_CLEAR_BLACKLIST 0 0
E/WifiStateMachine( 401): DefaultState !CMD_CLEAR_BLACKLIST 0 0
W/audio_hw_primary( 143): set parameters screen_state=on
I/ARMAssembler( 125): generated scanline__00000077:03515104_00008001_00000000 [113 ipp] (134 ins) at [0xacc923b0:0xacc925c8] in 144917 ns
E/libEGL ( 401): called unimplemented OpenGL ES API
E/ColorFade( 401): Could not compile shader 0, 35633:
E/ColorFade( 401): Could not compile shader 0, 35632:
I/DisplayPowerController( 401): Blocking screen on until initial contents have been drawn.
I/CalendarDatabaseHelper( 1290): Bootstrapping database
D/bt_userial( 1208): userial_init
I/bt_vendor( 1208): userial vendor open: opening rsi
E/bt_vendor( 1208): userial vendor open: unable to open rsi: No such file or directory
E/bt_userial( 1208): userial_open opened wrong number of ports: got 0, expected 1.
E/bt_vendor( 1208): Fariya Fw configuration is a success
I/bt-btu ( 1208): btu_task received preload complete event
I/ ( 1208): BTE_InitTraceLevels -- TRC_HCI
I/ ( 1208): BTE_InitTraceLevels -- TRC_L2CAP
I/ ( 1208): BTE_InitTraceLevels -- TRC_RFCOMM
I/ ( 1208): BTE_InitTraceLevels -- TRC_AVDT
I/ ( 1208): BTE_InitTraceLevels -- TRC_AVRC
I/ ( 1208): BTE_InitTraceLevels -- TRC_A2D
I/ ( 1208): BTE_InitTraceLevels -- TRC_BNEP
I/ ( 1208): BTE_InitTraceLevels -- TRC_BTM
I/ ( 1208): BTE_InitTraceLevels -- TRC_GAP
I/ ( 1208): BTE_InitTraceLevels -- TRC_PAN
I/ ( 1208): BTE_InitTraceLevels -- TRC_SDP
I/ ( 1208): BTE_InitTraceLevels -- TRC_GATT
I/ ( 1208): BTE_InitTraceLevels -- TRC_SMP
I/ ( 1208): BTE_InitTraceLevels -- TRC_BTAPP
I/ ( 1208): BTE_InitTraceLevels -- TRC_BTIF
E/bt_userial( 1208): userial_write error writing to serial port: Bad file number
I/DisplayPowerController( 401): Unblocked screen on after 138 ms
W/art ( 401): Long monitor contention event with owner method=void com.android.server.am.BroadcastQueue.processNextBroadcast(boolean) from BroadcastQueue.java:542 waiters=0 for 153ms
E/WifiStateMachine( 401): InitialState !CMD_SCREEN_STATE_CHANGED 0 0
E/WifiStateMachine( 401): DefaultState !CMD_SCREEN_STATE_CHANGED 0 0
E/WifiStateMachine( 401): cancelDelayedScan -> 2
E/WifiStateMachine( 401): handleScreenStateChanged Exit: false
E/WifiStateMachine( 401): InitialState CMD_ENABLE_RSSI_POLL 0 0
E/WifiStateMachine( 401): DefaultState CMD_ENABLE_RSSI_POLL 0 0
W/audio_hw_primary( 143): set parameters screen_state=off
E/WifiStateMachine( 401): InitialState CMD_SET_SUSPEND_OPT_ENABLED 1 0
E/WifiStateMachine( 401): DefaultState CMD_SET_SUSPEND_OPT_ENABLED 1 0
E/WifiStateMachine( 401): setSuspendOptimizations: 4 true
E/WifiStateMachine( 401): mSuspendOptNeedsDisabled 0
E/WifiStateMachine( 401): InitialState CMD_SCREEN_STATE_CHANGED 1 0
E/WifiStateMachine( 401): DefaultState CMD_SCREEN_STATE_CHANGED 1 0
E/WifiStateMachine( 401): cancelDelayedScan -> 3
I/ActivityManager( 401): Start proc 1323:com.android.email/u0a26 for content provider com.android.email/.provider.EmailProvider
I/ContactDirectoryManager( 741): deleted 0 stale rows which don't have any relevant directory
I/CalendarProvider2( 1290): Created com.android.providers.calendar.CalendarAlarmManager@2e82a2fd(com.android.providers.calendar.CalendarProvider2@27f6abf2)
I/ContactDirectoryManager( 741): Discovered 0 contact directories in 2626ms
E/BluetoothManagerService( 401): waitForOnOff time out
I/ActivityManager( 401): Start proc 1343:com.android.managedprovisioning/u0a8 for broadcast com.android.managedprovisioning/.BootReminder
E/cutils-trace( 143): Error opening trace file: Permission denied (13)
I/audio_hw_primary( 143): start_output_stream... -1249269568, device 2
W/audio_hw_primary( 143): card 0, port 0 device 0x2
W/audio_hw_primary( 143): rate 44100, channel 2 period_size 0xc0
D/PhoneStatusBar( 771): disable: < expand icons* alerts system_info* back HOME RECENT clock SEARCH >
I/ValidateNoPeople( 401): mEvictionCount: 0
D/PhoneStatusBar( 771): disable: < expand icons alerts system_info back home* recent* clock search* >
D/BluetoothManagerService( 401): Stored Bluetoothaddress: 22:22:9B:76:08:D7
D/BluetoothAdapterState( 1208): CURRENT_STATE=PENDING, MESSAGE = USER_TURN_ON, isTurningOn=true, isTurningOff=false
I/BluetoothAdapterState( 1208): CURRENT_STATE=PENDING: Deferring request USER_TURN_OFF
W/AudioTrack( 401): AUDIO_OUTPUT_FLAG_FAST denied by client
I/ContactsProvider( 741): Upgrading aggregation algorithm
D/ActivityThread( 1323): Loading provider com.android.email.provider;com.android.email.notifier: com.android.email.provider.EmailProvider
I/ContactAggregator( 741): Marked all visible contacts for aggregation: 0 raw contacts, 9 ms
I/ActivityManager( 401): Start proc 1372:com.android.mms/u0a9 for broadcast com.android.mms/.transaction.MmsSystemEventReceiver
D/CountryDetector( 401): The first listener is added
I/ContactsProvider( 741): Aggregation algorithm upgraded for 0 raw contacts in 442ms
D/btif_config_util( 1208): btif_config_save_file(L188): in file name:/data/misc/bluedroid/bt_config.new
I/CalendarProvider2( 1290): Sending notification intent: Intent { act=android.intent.action.PROVIDER_CHANGED dat=content://com.android.calendar }
W/ContentResolver( 1290): Failed to get type for: content://com.android.calendar (Unknown URL content://com.android.calendar)
V/Mms ( 1372): mnc/mcc:
V/Mms ( 1372): tag: bool value: enabledMMS - true
V/Mms ( 1372): tag: int value: maxMessageSize - 307200
V/Mms ( 1372): tag: int value: maxImageHeight - 480
V/Mms ( 1372): tag: int value: maxImageWidth - 640
V/Mms ( 1372): tag: int value: defaultSMSMessagesPerThread - 10000
V/Mms ( 1372): tag: int value: defaultMMSMessagesPerThread - 1000
V/Mms ( 1372): tag: int value: minMessageCountPerThread - 10
V/Mms ( 1372): tag: int value: maxMessageCountPerThread - 5000
V/Mms ( 1372): tag: string value: uaProfUrl - http://www.google.com/oha/rdf/ua-profile-kila.xml
V/Mms ( 1372): tag: int value: recipientLimit - -1
V/Mms ( 1372): tag: bool value: enableMultipartSMS - true
V/Mms ( 1372): tag: int value: smsToMmsTextThreshold - -1
V/Mms ( 1372): tag: bool value: enableSlideDuration - true
V/Mms ( 1372): tag: int value: maxMessageTextSize - -1
I/Choreographer( 1079): Skipped 32 frames! The application may be doing too much work on its main thread.
I/art ( 741): WaitForGcToComplete blocked for 1.570s for cause HomogeneousSpaceCompact
D/BluetoothManagerService( 401): unbindAndFinish(): android.bluetooth.IBluetooth$Stub$Proxy@99e6ab1 mBinding = false
D/BluetoothManagerService( 401): Sending unbind request.
W/bt_userial( 1208): userial_close_reader Already closed userial reader thread
I/GKI_LINUX( 1208): gki_task task_id=0 [BTU] terminating
I/GKI_LINUX( 1208): GKI_exit_task 0 done
I/GKI_LINUX( 1208): GKI_shutdown(): task [BTU] terminated
E/BluetoothServiceJni( 1208): Callback env check fail: env: 0xb4878ac0, callback: 0xb4abc0a0
E/BluetoothServiceJni( 1208): Callback: 'adapter_state_change_callback' is not called on the correct thread
I/GKI_LINUX( 1208): gki_task task_id=1 [BTIF] terminating
I/GKI_LINUX( 1208): GKI_exit_task 1 done
I/GKI_LINUX( 1208): GKI_shutdown(): task [BTIF] terminated
I/GKI_LINUX( 1208): gki_task task_id=2 [A2DP-MEDIA] terminating
I/GKI_LINUX( 1208): GKI_exit_task 2 done
I/BluetoothServiceJni( 1208): cleanupNative: return from cleanup
I/art ( 1208): System.exit called, status: 0
I/AndroidRuntime( 1208): VM exiting with result code 0, cleanup skipped.
D/BluetoothA2dp( 401): Proxy object disconnected
D/BluetoothA2dp( 771): Proxy object disconnected
D/BluetoothMap( 771): Proxy object disconnected
D/BluetoothInputDevice( 771): Proxy object disconnected
D/BluetoothPan( 771): BluetoothPAN Proxy object disconnected
I/ActivityManager( 401): Process com.android.bluetooth (pid 1208) has died
W/ActivityManager( 401): Scheduling restart of crashed service com.android.bluetooth/.hdp.HealthService in 1000ms
W/ActivityManager( 401): Scheduling restart of crashed service com.android.bluetooth/.map.BluetoothMapService in 1000ms
W/ActivityManager( 401): Scheduling restart of crashed service com.android.bluetooth/.gatt.GattService in 1000ms
W/ActivityManager( 401): Scheduling restart of crashed service com.android.bluetooth/.a2dp.A2dpService in 1000ms
W/ActivityManager( 401): Scheduling restart of crashed service com.android.bluetooth/.hid.HidService in 1000ms
W/ActivityManager( 401): Scheduling restart of crashed service com.android.bluetooth/.pan.PanService in 1000ms
W/ActivityManager( 401): Scheduling restart of crashed service com.android.bluetooth/.hfp.HeadsetService in 1000ms
I/ActivityManager( 401): Start proc 1404:com.android.onetimeinitializer/u0a11 for broadcast com.android.onetimeinitializer/.OneTimeInitializerReceiver
D/Mms ( 1372): cancelNotification
D/ConnectivityManager( 1372): getMobileDataEnabled()+ subId=-1
D/PhoneInterfaceManager( 957): [PhoneIntfMgr] getDataEnabled: subId=-1 phoneId=-1
E/PhoneInterfaceManager( 957): [PhoneIntfMgr] getDataEnabled: no phone subId=-1 retVal=false
D/ConnectivityManager( 1372): getMobileDataEnabled()- subId=-1 retVal=false
V/OneTimeInitializerRece( 1404): OneTimeInitializerReceiver.onReceive
I/OneTimeInitializerServ( 1404): Updating to version 1.
I/ContactsFTS( 741): Rebuild contact search index in 1819ms, 0 contacts
D/AlertReceiver( 1226): onReceive: a=android.intent.action.BOOT_COMPLETED Intent { act=android.intent.action.BOOT_COMPLETED flg=0x8000010 cmp=com.android.calendar/.alerts.AlertReceiver (has extras) }
V/AlarmClock( 1187): AlarmInitReceiver android.intent.action.BOOT_COMPLETED
D/AlertService( 1226): 0 Action = android.intent.action.BOOT_COMPLETED
D/AlertService( 1226): Scheduling next alarm with AlarmScheduler. sEventReminderReceived: null
D/MmsSmsDatabaseHelper( 957): [MmsSmsDb] tableName: threads hasAutoIncrement: CREATE TABLE threads (_id INTEGER PRIMARY KEY AUTOINCREMENT,date INTEGER DEFAULT 0,message_count INTEGER DEFAULT 0,recipient_ids TEXT,snippet TEXT,snippet_cs INTEGER DEFAULT 0,read INTEGER DEFAULT 1,archived INTEGER DEFAULT 0,type INTEGER DEFAULT 0,error INTEGER DEFAULT 0,has_attachment INTEGER DEFAULT 0) result: true
D/MmsSmsDatabaseHelper( 957): [MmsSmsDb] tableName: canonical_addresses hasAutoIncrement: CREATE TABLE canonical_addresses (_id INTEGER PRIMARY KEY AUTOINCREMENT,address TEXT) result: true
D/MmsSmsDatabaseHelper( 957): [MmsSmsDb] tableName: part hasAutoIncrement: CREATE TABLE part (_id INTEGER PRIMARY KEY AUTOINCREMENT,mid INTEGER,seq INTEGER DEFAULT 0,ct TEXT,name TEXT,chset INTEGER,cd TEXT,fn TEXT,cid TEXT,cl TEXT,ctt_s INTEGER,ctt_t TEXT,_data TEXT,text TEXT) result: true
D/MmsSmsDatabaseHelper( 957): [MmsSmsDb] tableName: pdu hasAutoIncrement: CREATE TABLE pdu (_id INTEGER PRIMARY KEY AUTOINCREMENT,thread_id INTEGER,date INTEGER,date_sent INTEGER DEFAULT 0,msg_box INTEGER,read INTEGER DEFAULT 0,m_id TEXT,sub TEXT,sub_cs INTEGER,ct_t TEXT,ct_l TEXT,exp INTEGER,m_cls TEXT,m_type INTEGER,v INTEGER,m_size INTEGER,pri INTEGER,rr INTEGER,rpt_a INTEGER,resp_st INTEGER,st INTEGER,tr_id TEXT,retr_st INTEGER,retr_txt TEXT,retr_txt_cs INTEGER,read_status INTEGER,ct_cls INTEGER,resp_txt TEXT,d_tm INTEGER,d_rpt INTEGER,locked INTEGER DEFAULT 0,sub_id INTEGER DEFAULT -1, seen INTEGER DEFAULT 0,creator TEXT,text_only INTEGER DEFAULT 0) result: true
D/MmsSmsDatabaseHelper( 957): [getWritableDatabase] hasAutoIncrementThreads: true hasAutoIncrementAddresses: true hasAutoIncrementPart: true hasAutoIncrementPdu: true
W/audio_hw_primary( 143): do_out_standby... -1249269568
I/art ( 1079): Background partial concurrent mark sweep GC freed 1014(124KB) AllocSpace objects, 12(5MB) LOS objects, 40% free, 11MB/19MB, paused 5.375ms total 34.308ms
V/AlarmClock( 1187): AlarmInitReceiver - Reset timers and clear stopwatch data
V/AlarmClock( 1187): AlarmInitReceiver - resetting volume button default
I/ActivityManager( 401): START u0 {act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10200000 cmp=com.android.settings/.Settings (has extras)} from uid 10007 on display 0
V/WindowManager( 401): addAppToken: AppWindowToken{15ac0646 token=Token{fae6221 ActivityRecord{1831a888 u0 com.android.settings/.Settings t4}}} to stack=1 task=4 at 0
V/WindowManager( 401): Adding window Window{ea8461b u0 Starting com.android.settings} at 2 of 7 (after Window{16e05578 u0 com.android.launcher/com.android.launcher2.Launcher})
I/InputDispatcher( 401): Dropping event because there is no touchable window at (671, 207).
W/art ( 984): Suspending all threads took: 8.195ms
I/art ( 984): Background sticky concurrent mark sweep GC freed 261(150KB) AllocSpace objects, 0(0B) LOS objects, 26% free, 610KB/830KB, paused 10.562ms total 50.460ms
V/WindowManager( 401): Adding window Window{1aa2ec0b u0 com.android.settings/com.android.settings.Settings} at 2 of 8 (before Window{ea8461b u0 Starting com.android.settings})
E/SQLiteLog( 1019): (1) no such table: files
I/InputDispatcher( 401): Dropping event because there is no touchable window at (669, 207).
I/InputDispatcher( 401): Dropping event because there is no touchable window at (667, 206).
I/InputDispatcher( 401): Dropping event because there is no touchable window at (665, 206).
I/InputDispatcher( 401): Dropping event because there is no touchable window at (664, 206).
I/InputDispatcher( 401): Dropping event because there is no touchable window at (661, 206).
I/InputDispatcher( 401): Dropping event because there is no touchable window at (660, 206).
I/InputDispatcher( 401): Dropping event because there is no touchable window at (659, 206).
I/InputDispatcher( 401): Dropping event because there is no touchable window at (658, 206).
I/InputDispatcher( 401): Dropping event because there is no touchable window at (656, 206).
I/InputDispatcher( 401): Dropping event because there is no touchable window at (655, 206).
I/InputDispatcher( 401): Dropping event because there is no touchable window at (653, 206).
I/InputDispatcher( 401): Dropping event because there is no touchable window at (650, 207).
I/InputDispatcher( 401): Dropping event because there is no touchable window at (649, 207).
I/InputDispatcher( 401): Dropping event because there is no touchable window at (644, 208).
I/InputDispatcher( 401): Dropping event because there is no touchable window at (643, 209).
I/InputDispatcher( 401): Dropping event because there is no touchable window at (641, 210).
I/InputDispatcher( 401): Dropping event because there is no touchable window at (639, 211).
I/InputDispatcher( 401): Dropping event because there is no touchable window at (635, 212).
I/InputDispatcher( 401): Dropping event because there is no touchable window at (632, 214).
I/InputDispatcher( 401): Dropping event because there is no touchable window at (630, 215).
I/InputDispatcher( 401): Dropping event because there is no touchable window at (628, 215).
I/InputDispatcher( 401): Dropping event because there is no touchable window at (625, 216).
I/InputDispatcher( 401): Dropping event because there is no touchable window at (623, 217).
I/InputDispatcher( 401): Dropping event because there is no touchable window at (621, 219).
I/InputDispatcher( 401): Dropping event because there is no touchable window at (619, 219).
I/InputDispatcher( 401): Dropping event because there is no touchable window at (617, 220).
I/InputDispatcher( 401): Dropping event because there is no touchable window at (616, 220).
I/InputDispatcher( 401): Dropping event because there is no touchable window at (614, 220).
I/InputDispatcher( 401): Dropping event because there is no touchable window at (613, 221).
D/DashboardSummary( 984): rebuildUI took: 1064 ms
I/Choreographer( 984): Skipped 63 frames! The application may be doing too much work on its main thread.
D/BackupManagerService( 401): Received broadcast Intent { act=android.intent.action.PACKAGE_CHANGED dat=package:com.android.calendar flg=0x4000010 (has extras) }
D/AlarmScheduler( 1226): No events found starting within 1 week.
I/Launcher( 1079): Deferring update until onResume
D/DashboardSummary( 984): rebuildUI took: 130 ms
I/Choreographer( 984): Skipped 45 frames! The application may be doing too much work on its main thread.
I/imx6.gralloc( 984): open gpu gralloc module!
I/ActivityManager( 401): Displayed com.android.settings/.Settings: +2s512ms
I/AlarmClock( 1187): Alarms Table created
I/AlarmClock( 1187): Instance table created
I/AlarmClock( 1187): Cities table created
I/AlarmClock( 1187): Inserting default alarms
I/ActivityManager( 401): Waited long enough for: ServiceRecord{1b4ee205 u0 com.android.music/.MediaPlaybackService}
I/IndexDatabaseHelper( 984): Bootstrapped database
W/ActivityManager( 401): Unable to start service Intent { act=com.android.mail.action.BACKUP_DATA_CHANGED pkg=com.android.email } U=0: not found
V/AlarmClock( 1187): AlarmInitReceiver finished
I/ActivityManager( 401): START u0 {act=android.intent.action.MAIN cmp=com.android.settings/.SubSettings (has extras)} from uid 1000 on display 0
V/WindowManager( 401): addAppToken: AppWindowToken{6c9fca9 token=Token{9387830 ActivityRecord{30c32173 u0 com.android.settings/.SubSettings t4}}} to stack=1 task=4 at 1
D/SubSettings( 984): Launching fragment com.android.settings.DeviceInfoSettings
D/DeviceInfoSettings( 984): Property 'ro.url.safetylegal' missing and no 'safetylegal' preference
V/WindowManager( 401): Adding window Window{1746906 u0 com.android.settings/com.android.settings.SubSettings} at 3 of 8 (after Window{1aa2ec0b u0 com.android.settings/com.android.settings.Settings})
I/ActivityManager( 401): Displayed com.android.settings/.SubSettings: +472ms
E/MetadataRetrieverClient( 143): failed to extract an album art
I/IndexDatabaseHelper( 984): Using schema version: 115
I/IndexDatabaseHelper( 984): Index is fine
I/art ( 984): Background sticky concurrent mark sweep GC freed 1999(166KB) AllocSpace objects, 0(0B) LOS objects, 11% free, 2MB/2MB, paused 5.634ms total 30.042ms
V/NFC ( 984): this device does not have NFC support
W/BackupManagerService( 401): dataChanged but no participant pkg='com.android.providers.settings' uid=10005
W/art ( 1323): Long monitor contention event with owner method=boolean android.os.BinderProxy.transactNative(int, android.os.Parcel, android.os.Parcel, int) from Binder.java:4294967294 waiters=0 for 12.809s
W/art ( 1323): Long monitor contention event with owner method=boolean android.os.BinderProxy.transactNative(int, android.os.Parcel, android.os.Parcel, int) from Binder.java:4294967294 waiters=1 for 12.689s
I/Exchange( 1306): EasService.onCreate
I/SystemBroadcastReceiver( 924): Boot has been completed
I/Exchange( 1306): RestartPingTask
I/LauncherIconVisibilityManager( 924): Disable activity: ComponentInfo{com.android.inputmethod.latin/com.android.inputmethod.latin.setup.SetupActivity}
W/art ( 401): Long monitor contention event with owner method=void com.android.server.pm.PackageManagerService.setEnabledSetting(java.lang.String, java.lang.String, int, int, int, java.lang.String) from PackageManagerService.java:12159 waiters=0 for 353ms
W/art ( 401): Long monitor contention event with owner method=void com.android.server.pm.PackageManagerService.setEnabledSetting(java.lang.String, java.lang.String, int, int, int, java.lang.String) from PackageManagerService.java:12159 waiters=1 for 350ms
W/art ( 401): Long monitor contention event with owner method=void com.android.server.pm.PackageManagerService.setEnabledSetting(java.lang.String, java.lang.String, int, int, int, java.lang.String) from PackageManagerService.java:12159 waiters=2 for 273ms
W/art ( 401): Long monitor contention event with owner method=android.app.IActivityManager$ContentProviderHolder com.android.server.am.ActivityManagerService.getContentProviderImpl(android.app.IApplicationThread, java.lang.String, android.os.IBinder, boolean, int) from ActivityManagerService.java:9159 waiters=1 for 345ms
W/art ( 401): Long monitor contention event with owner method=android.app.IActivityManager$ContentProviderHolder com.android.server.am.ActivityManagerService.getContentProviderImpl(android.app.IApplicationThread, java.lang.String, android.os.IBinder, boolean, int) from ActivityManagerService.java:9159 waiters=2 for 349ms
W/art ( 401): Long monitor contention event with owner method=android.app.IActivityManager$ContentProviderHolder com.android.server.am.ActivityManagerService.getContentProviderImpl(android.app.IApplicationThread, java.lang.String, android.os.IBinder, boolean, int) from ActivityManagerService.java:9159 waiters=3 for 350ms
W/ActivityManager( 401): Unable to start service Intent { cmp=com.android.email/.service.AttachmentService } U=0: not found
I/Email ( 1323): Onetime initialization: 1
I/Email ( 1323): Onetime initialization: 2
I/art ( 1323): WaitForGcToComplete blocked for 8.025ms for cause DisableMovingGc
I/art ( 1323): WaitForGcToComplete blocked for 7.361ms for cause DisableMovingGc
I/Email ( 1323): Onetime initialization: completed.
I/Email ( 1323): Observing account changes for notifications
D/AlertReceiver( 1226): onReceive: a=android.intent.action.PROVIDER_CHANGED Intent { act=android.intent.action.PROVIDER_CHANGED dat=content://com.android.calendar flg=0x10 cmp=com.android.calendar/.alerts.AlertReceiver }
D/AlertService( 1226): 0 Action = android.intent.action.PROVIDER_CHANGED
I/Exchange( 1306): RestartPingsTask did not start any pings.
I/Exchange( 1306): PSS stopIfIdle
I/Exchange( 1306): PSS has no active accounts; stopping service.
W/art ( 1323): Long monitor contention event with owner method=boolean android.os.BinderProxy.transactNative(int, android.os.Parcel, android.os.Parcel, int) from Binder.java:4294967294 waiters=0 for 174ms
V/Mms ( 1372): onStart: #1 mResultCode: -1 = Activity.RESULT_OK
E/SQLiteLog( 1290): (284) automatic index on view_events(_id)
E/ActivityThread( 1323): Service com.android.email.service.EmailBroadcastProcessorService has leaked ServiceConnection com.android.emailcommon.service.ServiceProxy$ProxyConnection@3240b525 that was originally bound here
E/ActivityThread( 1323): android.app.ServiceConnectionLeaked: Service com.android.email.service.EmailBroadcastProcessorService has leaked ServiceConnection com.android.emailcommon.service.ServiceProxy$ProxyConnection@3240b525 that was originally bound here
E/ActivityThread( 1323): at android.app.LoadedApk$ServiceDispatcher.<init>(LoadedApk.java:1077)
E/ActivityThread( 1323): at android.app.LoadedApk.getServiceDispatcher(LoadedApk.java:971)
E/ActivityThread( 1323): at android.app.ContextImpl.bindServiceCommon(ContextImpl.java:1774)
E/ActivityThread( 1323): at android.app.ContextImpl.bindService(ContextImpl.java:1757)
E/ActivityThread( 1323): at android.content.ContextWrapper.bindService(ContextWrapper.java:539)
E/ActivityThread( 1323): at com.android.emailcommon.service.ServiceProxy.setTask(ServiceProxy.java:181)
E/ActivityThread( 1323): at com.android.emailcommon.service.ServiceProxy.test(ServiceProxy.java:224)
E/ActivityThread( 1323): at com.android.email.service.EmailServiceUtils.isServiceAvailable(EmailServiceUtils.java:160)
E/ActivityThread( 1323): at com.android.email.provider.AccountReconciler.reconcileAccountsInternal(AccountReconciler.java:171)
E/ActivityThread( 1323): at com.android.email.provider.AccountReconciler.reconcileAccounts(AccountReconciler.java:115)
E/ActivityThread( 1323): at com.android.email.service.EmailBroadcastProcessorService.reconcileAndStartServices(EmailBroadcastProcessorService.java:305)
E/ActivityThread( 1323): at com.android.email.service.EmailBroadcastProcessorService.onBootCompleted(EmailBroadcastProcessorService.java:295)
E/ActivityThread( 1323): at com.android.email.service.EmailBroadcastProcessorService.onHandleIntent(EmailBroadcastProcessorService.java:130)
E/ActivityThread( 1323): at android.app.IntentService$ServiceHandler.handleMessage(IntentService.java:65)
E/ActivityThread( 1323): at android.os.Handler.dispatchMessage(Handler.java:102)
E/ActivityThread( 1323): at android.os.Looper.loop(Looper.java:135)
E/ActivityThread( 1323): at android.os.HandlerThread.run(HandlerThread.java:61)
I/ActivityManager( 401): Waited long enough for: ServiceRecord{252b7e7d u0 com.android.providers.media/.MediaScannerService}
E/EmailServiceProxy( 1323): RuntimeException when trying to unbind from service
E/EmailServiceProxy( 1323): java.lang.IllegalArgumentException: Service not registered: com.android.emailcommon.service.ServiceProxy$ProxyConnection@3240b525
E/EmailServiceProxy( 1323): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:1029)
E/EmailServiceProxy( 1323): at android.app.ContextImpl.unbindService(ContextImpl.java:1808)
E/EmailServiceProxy( 1323): at android.content.ContextWrapper.unbindService(ContextWrapper.java:551)
E/EmailServiceProxy( 1323): at com.android.emailcommon.service.ServiceProxy$ProxyConnection$1.doInBackground(ServiceProxy.java:124)
E/EmailServiceProxy( 1323): at com.android.emailcommon.service.ServiceProxy$ProxyConnection$1.doInBackground(ServiceProxy.java:111)
E/EmailServiceProxy( 1323): at android.os.AsyncTask$2.call(AsyncTask.java:292)
E/EmailServiceProxy( 1323): at java.util.concurrent.FutureTask.run(FutureTask.java:237)
E/EmailServiceProxy( 1323): at android.os.AsyncTask$SerialExecutor$1.run(AsyncTask.java:231)
E/EmailServiceProxy( 1323): at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1112)
E/EmailServiceProxy( 1323): at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:587)
E/EmailServiceProxy( 1323): at java.lang.Thread.run(Thread.java:818)
I/NotificationService( 401): cancelToast pkg=com.android.settings callback=android.app.ITransientNotification$Stub$Proxy@b6e6f8e
I/NotificationService( 401): cancelToast pkg=com.android.settings callback=android.app.ITransientNotification$Stub$Proxy@18a91bcb
I/NotificationService( 401): cancelToast pkg=com.android.settings callback=android.app.ITransientNotification$Stub$Proxy@191ce266
I/NotificationService( 401): cancelToast pkg=com.android.settings callback=android.app.ITransientNotification$Stub$Proxy@2a8121fd
I/ActivityManager( 401): Waited long enough for: ServiceRecord{180bfc2b u0 com.android.calendar/.alerts.InitAlarmsService}
D/WifiService( 401): New client listening to asynchronous messages
E/WifiStateMachine( 401): handleMessage: E msg.what=131131
E/WifiStateMachine( 401): processMsg: InitialState
E/WifiStateMachine( 401): InitialState !CMD_GET_CONFIGURED_NETWORKS uid=1000 1000 0 num=0
E/WifiStateMachine( 401): processMsg: DefaultState
E/WifiStateMachine( 401): DefaultState !CMD_GET_CONFIGURED_NETWORKS uid=1000 1000 0 num=0
E/WifiStateMachine( 401): handleMessage: X
D/BluetoothManagerService( 401): Added callback: android.bluetooth.IBluetoothManagerCallback$Stub$Proxy@3ac2e0f9:true
D/BluetoothAdapter( 984): 393406194: getState() : mService = null. Returning STATE_OFF
D/LocalBluetoothProfileManager( 984): Adding local MAP profile
D/BluetoothMap( 984): Create BluetoothMap proxy object
D/LocalBluetoothProfileManager( 984): LocalBluetoothProfileManager construction complete
I/GlobalDismissManager( 1226): no sender configured
D/AlertService( 1226): Beginning updateAlertNotification
D/AlertService( 1226): No fired or scheduled alerts
D/Index ( 984): Indexing locale 'en_US' took 7907 millis
D/Index ( 984): Deleting data for locale 'en_US' took 2 millis
D/Index ( 984): Indexing locale 'en_US' took 198 millis
D/DashboardSummary( 984): rebuildUI took: 249 ms
V/WindowManager( 401): addAppToken: AppWindowToken{1fcd1095 token=Token{844f84c ActivityRecord{2687607f u0 com.android.settings/.SubSettings t4}}} to stack=1 task=4 at 1
D/SubSettings( 984): Launching fragment com.android.settings.DevelopmentSettings
D/BackupManagerService( 401): Received broadcast Intent { act=android.intent.action.PACKAGE_CHANGED dat=package:com.android.inputmethod.latin flg=0x4000010 (has extras) }
D/BackupManagerService( 401): Received broadcast Intent { act=android.intent.action.PACKAGE_CHANGED dat=package:com.android.email flg=0x4000010 (has extras) }
W/Settings( 984): Setting bugreport_in_power_menu has moved from android.provider.Settings.Secure to android.provider.Settings.Global.
I/DevelopmentSettings( 984): updateCpuUsageOptions:0
I/DevelopmentSettings( 984): updateSystemTimeOptions:0
V/WindowManager( 401): Adding window Window{13fa8cac u0 com.android.settings/com.android.settings.SubSettings} at 3 of 8 (after Window{1aa2ec0b u0 com.android.settings/com.android.settings.Settings})
I/Choreographer( 984): Skipped 54 frames! The application may be doing too much work on its main thread.
I/art ( 984): Background partial concurrent mark sweep GC freed 13634(915KB) AllocSpace objects, 6(96KB) LOS objects, 39% free, 2MB/4MB, paused 1.963ms total 145.781ms
I/art ( 984): WaitForGcToComplete blocked for 33.957ms for cause HeapTrim
I/Choreographer( 984): Skipped 34 frames! The application may be doing too much work on its main thread.
I/ActivityManager( 401): Displayed com.android.settings/.SubSettings: +1s583ms
D/InitAlarmsService( 1226): Clearing and rescheduling alarms.
V/WindowManager( 401): not Base app: Adding window Window{21c9e657 u0 com.android.settings/com.android.settings.SubSettings} at 4 of 9
W/MediaScanner( 1019): Error opening directory '/oem/media/', skipping: No such file or directory.
W/InputMethodManagerService( 401): Window already focused, ignoring focus gain of: com.android.internal.view.IInputMethodClient$Stub$Proxy@7710774 attribute=null, token = android.os.BinderProxy@2dbf0a5f
I/ValidateNoPeople( 401): skipping global notification
W/art ( 1019): Suspending all threads took: 19.566ms
E/MtpServerJNI( 1019): server is null in send_object_added
V/MediaScanner( 1019): pruneDeadThumbnailFiles... android.database.sqlite.SQLiteCursor@b6ae087
V/MediaScanner( 1019): /pruneDeadThumbnailFiles... android.database.sqlite.SQLiteCursor@b6ae087
I/ActivityManager( 401): Start proc 1498:com.android.musicfx/u0a10 for broadcast com.android.musicfx/.ControlPanelReceiver
I/MediaFocusControl( 401): AudioFocus abandonAudioFocus() from android.media.AudioManager@e9c30c0com.android.music.MediaPlaybackService$3@3db71f9
I/art ( 401): Explicit concurrent mark sweep GC freed 18934(1336KB) AllocSpace objects, 14(268KB) LOS objects, 33% free, 6MB/9MB, paused 1.386ms total 75.904ms
V/MusicFXControlPanelReceiver( 1498): onReceive
V/MusicFXControlPanelReceiver( 1498): Action: android.media.action.CLOSE_AUDIO_EFFECT_CONTROL_SESSION
V/MusicFXControlPanelReceiver( 1498): Package name: com.android.music
V/MusicFXControlPanelReceiver( 1498): Audio session: 10
V/MusicFXControlPanelEffect( 1498): closeSession(android.app.ReceiverRestrictedContext@25a20bc1, com.android.music, 10)
D/UsbDebuggingManager( 401): Received public key: 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 root@cpu331
W/ContextImpl( 401): Calling a method in the system process without a qualified user: android.app.ContextImpl.startActivity:1224 com.android.server.usb.UsbDebuggingManager.startConfirmationActivity:283 com.android.server.usb.UsbDebuggingManager.startConfirmation:265 com.android.server.usb.UsbDebuggingManager.access$900:49 com.android.server.usb.UsbDebuggingManager$UsbDebuggingHandler.handleMessage:217
W/ContextImpl( 401): Calling a method in the system process without a qualified user: android.app.ContextImpl.startActivity:1236 android.app.ContextImpl.startActivity:1225 com.android.server.usb.UsbDebuggingManager.startConfirmationActivity:283 com.android.server.usb.UsbDebuggingManager.startConfirmation:265 com.android.server.usb.UsbDebuggingManager.access$900:49
I/ActivityManager( 401): START u0 {flg=0x10000000 cmp=com.android.systemui/.usb.UsbDebuggingActivity (has extras)} from uid 1000 on display 0
W/ResourcesManager( 401): Asset path '/system/framework/freescale-extended.jar' does not exist or contains no resources.
V/WindowManager( 401): addAppToken: AppWindowToken{bb3c127 token=Token{33e0a7e6 ActivityRecord{17700641 u0 com.android.systemui/.usb.UsbDebuggingActivity t5}}} to stack=1 task=5 at 0
I/ARMAssembler( 125): generated scanline__00000077:03010104_00008001_00000000 [ 89 ipp] (110 ins) at [0xacc925d0:0xacc92788] in 134416 ns
V/WindowManager( 401): Adding window Window{2c599540 u0 com.android.systemui/com.android.systemui.usb.UsbDebuggingActivity} at 4 of 9 (after Window{13fa8cac u0 com.android.settings/com.android.settings.SubSettings})
I/ActivityManager( 401): Displayed com.android.systemui/.usb.UsbDebuggingActivity: +197ms
W/ResourceType( 771): No package identifier when getting value for resource number 0x00000000
W/PackageManager( 771): Failure retrieving resources for com.android.settings: Resource ID #0x0
W/InputMethodManagerService( 401): Window already focused, ignoring focus gain of: com.android.internal.view.IInputMethodClient$Stub$Proxy@2e8e5604 attribute=null, token = android.os.BinderProxy@2dbf0a5f
D/DashboardSummary( 984): rebuildUI took: 187 ms
V/WindowManager( 401): addAppToken: AppWindowToken{188dfbd2 token=Token{3967c65d ActivityRecord{34b54834 u0 com.android.settings/.SubSettings t4}}} to stack=1 task=4 at 1
D/SubSettings( 984): Launching fragment com.android.settings.bluetooth.BluetoothSettings
D/LocalBluetoothManager( 984): setting foreground activity to non-null context
V/WindowManager( 401): Adding window Window{217044d0 u0 com.android.settings/com.android.settings.SubSettings} at 3 of 8 (after Window{1aa2ec0b u0 com.android.settings/com.android.settings.Settings})
D/Index ( 984): Deleting data for locale 'en_US' took 3 millis
I/ActivityManager( 401): Displayed com.android.settings/.SubSettings: +293ms
D/Index ( 984): Indexing locale 'en_US' took 4 millis
D/BluetoothManagerService( 401): enable(): mBluetooth =null mBinding = false
D/BluetoothManagerService( 401): Message: 1
D/BluetoothManagerService( 401): MESSAGE_ENABLE: mBluetooth = null
I/ActivityManager( 401): Start proc 1522:com.android.bluetooth/1002 for service com.android.bluetooth/.btservice.AdapterService
W/ResourcesManager( 1522): Asset path '/system/framework/javax.obex.jar' does not exist or contains no resources.
D/AdapterServiceConfig( 1522): Adding HeadsetService
D/AdapterServiceConfig( 1522): Adding A2dpService
D/AdapterServiceConfig( 1522): Adding HidService
D/AdapterServiceConfig( 1522): Adding HealthService
D/AdapterServiceConfig( 1522): Adding PanService
D/AdapterServiceConfig( 1522): Adding GattService
D/AdapterServiceConfig( 1522): Adding BluetoothMapService
D/BluetoothManagerService( 401): Added callback: android.bluetooth.IBluetoothManagerCallback$Stub$Proxy@35f3aaa6:true
D/BluetoothAdapterState( 1522): make
I/bluedroid( 1522): init
I/BluetoothAdapterState( 1522): Entering OffState
I/bte_conf( 1522): bte_load_conf attempt to load stack conf from /etc/bluetooth/bt_stack.conf
I/bte_conf( 1522): bte_load_ble_conf attempt to load ble stack conf from /etc/bluetooth/ble_stack.conf
E/bt_osi_config( 1522): config_new unable to open file '/etc/bluetooth/ble_stack.conf': No such file or directory
I/bte_conf( 1522): bte_load_ble_conf file >/etc/bluetooth/ble_stack.conf< not found
I/bluedroid( 1522): get_profile_interface socket
I/bluedroid( 1522): get_profile_interface map_client
I/GKI_LINUX( 1522): gki_task_entry task_id=1 [BTIF] starting
I/bluedroid( 1522): config_hci_snoop_log
D/BluetoothManagerService( 401): Calling onBluetoothServiceUp callbacks
D/BluetoothManagerService( 401): Broadcasting onBluetoothServiceUp() to 5 receivers.
D/BluetoothAdapterState( 1522): CURRENT_STATE=OFF, MESSAGE = USER_TURN_ON
D/BluetoothAdapterProperties( 1522): Address is:22:22:9B:76:08:D7
D/BluetoothAdapterProperties( 1522): Name is: EVK_MX6SL
D/BluetoothAdapterProperties( 1522): Setting state to 11
I/BluetoothAdapterState( 1522): Bluetooth adapter state changed: 10-> 11
D/BluetoothManagerService( 401): Message: 60
D/BluetoothManagerService( 401): MESSAGE_BLUETOOTH_STATE_CHANGE: prevState = 10, newState=11
D/BluetoothManagerService( 401): Bluetooth State Change Intent: 10 -> 11
D/BluetoothBondStateMachine( 1522): make
D/BluetoothAdapterService( 1522): getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@1b972243
D/HeadsetService( 1522): Received start request. Starting profile...
I/BluetoothHeadsetServiceJni( 1522): classInitNative: succeeds
D/HeadsetStateMachine( 1522): make
I/BluetoothBondStateMachine( 1522): StableState(): Entering Off State
D/HeadsetStateMachine( 1522): max_hf_connections = 1
I/bluedroid( 1522): get_profile_interface handsfree
D/A2dpService( 1522): Received start request. Starting profile...
I/BluetoothAvrcpServiceJni( 1522): classInitNative: succeeds
I/bluedroid( 1522): get_profile_interface avrcp
D/HeadsetStateMachine( 1522): Enter Disconnected: -2, size: 0
E/RemoteController( 1522): Cannot set synchronization mode on an unregistered RemoteController
I/BluetoothA2dpServiceJni( 1522): classInitNative: succeeds
D/A2dpStateMachine( 1522): make
I/bluedroid( 1522): get_profile_interface a2dp
I/GKI_LINUX( 1522): gki_task_entry task_id=2 [A2DP-MEDIA] starting
I/BluetoothHidServiceJni( 1522): classInitNative: succeeds
D/HidService( 1522): Received start request. Starting profile...
I/bluedroid( 1522): get_profile_interface hidhost
I/BluetoothHealthServiceJni( 1522): classInitNative: succeeds
D/HealthService( 1522): Received start request. Starting profile...
D/A2dpStateMachine( 1522): Enter Disconnected: -2
I/BluetoothAdapterState( 1522): Entering PendingCommandState State: isTurningOn()=true, isTurningOff()=false
I/bluedroid( 1522): get_profile_interface health
D/HeadsetStateMachine( 1522): Disconnected process message: 10, size: 0
D/HeadsetPhoneState( 1522): sendDeviceStateChanged. mService=0 mSignal=0 mRoam=0 mBatteryCharge=5
D/HeadsetStateMachine( 1522): Disconnected process message: 11, size: 0
D/HeadsetStateMachine( 1522): Proxy object connected
I/BluetoothPanServiceJni( 1522): classInitNative(L105): succeeds
D/PanService( 1522): Received start request. Starting profile...
D/BluetoothPanServiceJni( 1522): initializeNative(L110): pan
I/bluedroid( 1522): get_profile_interface pan
I/BtGatt.JNI( 1522): classInitNative(L873): classInitNative: Success!
D/BtGatt.DebugUtils( 1522): handleDebugAction() action=null
D/BtGatt.GattService( 1522): Received start request. Starting profile...
D/BtGatt.GattService( 1522): start()
I/bluedroid( 1522): get_profile_interface gatt
D/BtGatt.AdvertiseManager( 1522): advertise manager created
D/BluetoothMapService( 1522): Received start request. Starting profile...
D/BluetoothMapService( 1522): start()
D/BluetoothMapEmailSettingsLoader( 1522): Found 0 applications
D/BluetoothMapEmailAppObserver( 1522): createReceiver()
D/BluetoothMapEmailAppObserver( 1522): initObservers()
D/BluetoothMapEmailAppObserver( 1522): getEnabledAccountItems()
D/BluetoothAdapterState( 1522): CURRENT_STATE=PENDING, MESSAGE = STARTED, isTurningOn=true, isTurningOff=false
I/bluedroid( 1522): enable
I/bt_hci_bdroid( 1522): init
W/bt_vendor( 1522): ro.boot.btdev is and no mapped bt-vendor
I/bt_vendor( 1522): Redpine vendor init got called here!!!
I/GKI_LINUX( 1522): gki_task_entry task_id=0 [BTU] starting
I/bt-btu ( 1522): btu_task pending for preload complete event
E/bt_vendor( 1522): Mutyam enabling protocol bluetooth protocol:
E/bt_vendor( 1522): ROTOCOL ***
E/bt_vendor( 1522):
D/BluetoothInputDevice( 984): Proxy object connected
D/HidProfile( 984): Bluetooth service connected
D/BluetoothPan( 984): BluetoothPAN Proxy object connected
D/PanProfile( 984): Bluetooth service connected
D/BluetoothMap( 984): Proxy object connected
D/MapProfile( 984): Bluetooth service connected
D/BluetoothMap( 984): getConnectedDevices()
D/BluetoothMap( 984): Bluetooth is Not enabled
D/bt_userial( 1522): userial_init
I/bt_vendor( 1522): userial vendor open: opening rsi
E/bt_vendor( 1522): userial vendor open: unable to open rsi: No such file or directory
E/bt_userial( 1522): userial_open opened wrong number of ports: got 0, expected 1.
E/bt_vendor( 1522): Fariya Fw configuration is a success
I/bt-btu ( 1522): btu_task received preload complete event
I/ ( 1522): BTE_InitTraceLevels -- TRC_HCI
I/ ( 1522): BTE_InitTraceLevels -- TRC_L2CAP
I/ ( 1522): BTE_InitTraceLevels -- TRC_RFCOMM
I/ ( 1522): BTE_InitTraceLevels -- TRC_AVDT
I/ ( 1522): BTE_InitTraceLevels -- TRC_AVRC
I/ ( 1522): BTE_InitTraceLevels -- TRC_A2D
I/ ( 1522): BTE_InitTraceLevels -- TRC_BNEP
I/ ( 1522): BTE_InitTraceLevels -- TRC_BTM
I/ ( 1522): BTE_InitTraceLevels -- TRC_GAP
I/ ( 1522): BTE_InitTraceLevels -- TRC_PAN
I/ ( 1522): BTE_InitTraceLevels -- TRC_SDP
I/ ( 1522): BTE_InitTraceLevels -- TRC_GATT
I/ ( 1522): BTE_InitTraceLevels -- TRC_SMP
I/ ( 1522): BTE_InitTraceLevels -- TRC_BTAPP
I/ ( 1522): BTE_InitTraceLevels -- TRC_BTIF
E/bt_userial( 1522): userial_write error writing to serial port: Bad file number
D/BluetoothAdapterState( 1522): CURRENT_STATE=PENDING, MESSAGE = ENABLE_TIMEOUT, isTurningOn=true, isTurningOff=false
E/BluetoothAdapterState( 1522): Error enabling Bluetooth
D/BluetoothAdapterProperties( 1522): Setting state to 10
I/BluetoothAdapterState( 1522): Bluetooth adapter state changed: 11-> 10
D/BluetoothManagerService( 401): MESSAGE_BLUETOOTH_STATE_CHANGE: prevState = 11, newState=10
D/BluetoothManagerService( 401): Broadcasting onBluetoothStateChange(false) to 17 receivers.
D/BluetoothMap( 771): onBluetoothStateChange: up=false
D/BluetoothMap( 984): onBluetoothStateChange: up=false
D/BluetoothPbap( 984): onBluetoothStateChange: up=false
D/BluetoothHeadset( 401): onBluetoothStateChange: up=false
D/BluetoothA2dpSink( 771): onBluetoothStateChange: up=false
E/BluetoothA2dpSink( 771):
E/BluetoothA2dpSink( 771): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothA2dpSink$2@36a543e5
E/BluetoothA2dpSink( 771): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:1029)
E/BluetoothA2dpSink( 771): at android.app.ContextImpl.unbindService(ContextImpl.java:1808)
E/BluetoothA2dpSink( 771): at android.content.ContextWrapper.unbindService(ContextWrapper.java:551)
E/BluetoothA2dpSink( 771): at android.bluetooth.BluetoothA2dpSink$1.onBluetoothStateChange(BluetoothA2dpSink.java:139)
E/BluetoothA2dpSink( 771): at android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact(IBluetoothStateChangeCallback.java:55)
E/BluetoothA2dpSink( 771): at android.os.Binder.execTransact(Binder.java:446)
D/BluetoothInputDevice( 771): onBluetoothStateChange: up=false
D/BluetoothA2dp( 401): onBluetoothStateChange: up=false
D/BluetoothHeadset( 771): onBluetoothStateChange: up=false
D/BluetoothHeadsetClient( 771): onBluetoothStateChange: up=false
E/BluetoothHeadsetClient( 771):
E/BluetoothHeadsetClient( 771): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothHeadsetClient$2@72bdeba
E/BluetoothHeadsetClient( 771): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:1029)
E/BluetoothHeadsetClient( 771): at android.app.ContextImpl.unbindService(ContextImpl.java:1808)
E/BluetoothHeadsetClient( 771): at android.content.ContextWrapper.unbindService(ContextWrapper.java:551)
E/BluetoothHeadsetClient( 771): at android.bluetooth.BluetoothHeadsetClient$1.onBluetoothStateChange(BluetoothHeadsetClient.java:382)
E/BluetoothHeadsetClient( 771): at android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact(IBluetoothStateChangeCallback.java:55)
E/BluetoothHeadsetClient( 771): at android.os.Binder.execTransact(Binder.java:446)
D/BluetoothInputDevice( 984): onBluetoothStateChange: up=false
D/BluetoothAvrcpController( 771): onBluetoothStateChange: up=false
E/BluetoothAvrcpController( 771):
E/BluetoothAvrcpController( 771): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothAvrcpController$2@2966b16b
E/BluetoothAvrcpController( 771): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:1029)
E/BluetoothAvrcpController( 771): at android.app.ContextImpl.unbindService(ContextImpl.java:1808)
E/BluetoothAvrcpController( 771): at android.content.ContextWrapper.unbindService(ContextWrapper.java:551)
E/BluetoothAvrcpController( 771): at android.bluetooth.BluetoothAvrcpController$1.onBluetoothStateChange(BluetoothAvrcpController.java:80)
E/BluetoothAvrcpController( 771): at android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact(IBluetoothStateChangeCallback.java:55)
E/BluetoothAvrcpController( 771): at android.os.Binder.execTransact(Binder.java:446)
D/BluetoothHeadset( 957): onBluetoothStateChange: up=false
D/BluetoothA2dp( 771): onBluetoothStateChange: up=false
D/BluetoothManagerService( 401): Bluetooth State Change Intent: 11 -> 10
D/BluetoothMapService( 1522): onReceive
E/BluetoothManagerService( 401): recoverBluetoothServiceFromError
W/ContextImpl( 984): Calling a method in the system process without a qualified user: android.app.ContextImpl.startService:1692 android.content.ContextWrapper.startService:516 android.content.ContextWrapper.startService:516 com.android.settings.bluetooth.DockEventReceiver.beginStartingService:134 com.android.settings.bluetooth.DockEventReceiver.onReceive:115
D/DockEventReceiver( 984): finishStartingService: stopping service
D/Index ( 984): Deleting data for locale 'en_US' took 31 millis
D/Index ( 984): Indexing locale 'en_US' took 15 millis
D/BluetoothManagerService( 401): Sending off request.
D/BluetoothAdapterState( 1522): CURRENT_STATE=OFF, MESSAGE = USER_TURN_OFF
D/BluetoothManagerService( 401): Calling onBluetoothServiceDown callbacks
D/BluetoothManagerService( 401): Broadcasting onBluetoothServiceDown() to 5 receivers.
W/bt_userial( 1522): userial_close_reader Already closed userial reader thread
I/GKI_LINUX( 1522): gki_task task_id=0 [BTU] terminating
I/GKI_LINUX( 1522): GKI_exit_task 0 done
I/GKI_LINUX( 1522): GKI_shutdown(): task [BTU] terminated
E/BluetoothServiceJni( 1522): Callback env check fail: env: 0xb4878ac0, callback: 0xb4a97ee0
E/BluetoothServiceJni( 1522): Callback: 'adapter_state_change_callback' is not called on the correct thread
I/GKI_LINUX( 1522): gki_task task_id=1 [BTIF] terminating
I/GKI_LINUX( 1522): GKI_exit_task 1 done
I/GKI_LINUX( 1522): GKI_shutdown(): task [BTIF] terminated
I/GKI_LINUX( 1522): gki_task task_id=2 [A2DP-MEDIA] terminating
I/GKI_LINUX( 1522): GKI_exit_task 2 done
I/BluetoothServiceJni( 1522): cleanupNative: return from cleanup
I/art ( 1522): System.exit called, status: 0
I/AndroidRuntime( 1522): VM exiting with result code 0, cleanup skipped.
I/ActivityManager( 401): Process com.android.bluetooth (pid 1522) has died
D/BluetoothManagerService( 401): Message: 42
D/BluetoothManagerService( 401): MESSAGE_RESTART_BLUETOOTH_SERVICE: Restart IBluetooth service
I/ActivityManager( 401): Start proc 1560:com.android.bluetooth/1002 for service com.android.bluetooth/.btservice.AdapterService
W/ResourcesManager( 1560): Asset path '/system/framework/javax.obex.jar' does not exist or contains no resources.
D/AdapterServiceConfig( 1560): Adding HeadsetService
D/AdapterServiceConfig( 1560): Adding A2dpService
D/AdapterServiceConfig( 1560): Adding HidService
D/AdapterServiceConfig( 1560): Adding HealthService
D/AdapterServiceConfig( 1560): Adding PanService
D/AdapterServiceConfig( 1560): Adding GattService
D/AdapterServiceConfig( 1560): Adding BluetoothMapService
D/BluetoothManagerService( 401): Added callback: android.bluetooth.IBluetoothManagerCallback$Stub$Proxy@291d7406:true
D/BluetoothAdapterState( 1560): make
I/bluedroid( 1560): init
I/BluetoothAdapterState( 1560): Entering OffState
I/bte_conf( 1560): bte_load_conf attempt to load stack conf from /etc/bluetooth/bt_stack.conf
I/bte_conf( 1560): bte_load_ble_conf attempt to load ble stack conf from /etc/bluetooth/ble_stack.conf
E/bt_osi_config( 1560): config_new unable to open file '/etc/bluetooth/ble_stack.conf': No such file or directory
I/bte_conf( 1560): bte_load_ble_conf file >/etc/bluetooth/ble_stack.conf< not found
I/bluedroid( 1560): get_profile_interface socket
I/bluedroid( 1560): get_profile_interface map_client
I/GKI_LINUX( 1560): gki_task_entry task_id=1 [BTIF] starting
D/BluetoothAdapterProperties( 1560): Address is:22:22:9B:76:08:D7
I/bluedroid( 1560): config_hci_snoop_log
D/BluetoothAdapterState( 1560): CURRENT_STATE=OFF, MESSAGE = USER_TURN_ON
D/BluetoothAdapterProperties( 1560): Name is: EVK_MX6SL
D/BluetoothAdapterProperties( 1560): Setting state to 11
I/BluetoothAdapterState( 1560): Bluetooth adapter state changed: 10-> 11
D/BluetoothBondStateMachine( 1560): make
I/BluetoothBondStateMachine( 1560): StableState(): Entering Off State
D/BluetoothAdapterService( 1560): getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@1b972243
D/HeadsetService( 1560): Received start request. Starting profile...
I/BluetoothHeadsetServiceJni( 1560): classInitNative: succeeds
D/HeadsetStateMachine( 1560): make
D/HeadsetStateMachine( 1560): max_hf_connections = 1
I/bluedroid( 1560): get_profile_interface handsfree
D/HeadsetStateMachine( 1560): Proxy object connected
D/HeadsetStateMachine( 1560): Enter Disconnected: -2, size: 0
D/HeadsetStateMachine( 1560): Disconnected process message: 10, size: 0
D/HeadsetPhoneState( 1560): sendDeviceStateChanged. mService=0 mSignal=0 mRoam=0 mBatteryCharge=5
D/HeadsetStateMachine( 1560): Disconnected process message: 11, size: 0
D/A2dpService( 1560): Received start request. Starting profile...
I/BluetoothAvrcpServiceJni( 1560): classInitNative: succeeds
I/bluedroid( 1560): get_profile_interface avrcp
E/RemoteController( 1560): Cannot set synchronization mode on an unregistered RemoteController
I/BluetoothA2dpServiceJni( 1560): classInitNative: succeeds
D/A2dpStateMachine( 1560): make
I/BluetoothAdapterState( 1560): Entering PendingCommandState State: isTurningOn()=true, isTurningOff()=false
I/bluedroid( 1560): get_profile_interface a2dp
I/GKI_LINUX( 1560): gki_task_entry task_id=2 [A2DP-MEDIA] starting
I/BluetoothHidServiceJni( 1560): classInitNative: succeeds
D/A2dpStateMachine( 1560): Enter Disconnected: -2
D/HidService( 1560): Received start request. Starting profile...
I/bluedroid( 1560): get_profile_interface hidhost
I/BluetoothHealthServiceJni( 1560): classInitNative: succeeds
D/HealthService( 1560): Received start request. Starting profile...
I/bluedroid( 1560): get_profile_interface health
I/BluetoothPanServiceJni( 1560): classInitNative(L105): succeeds
D/PanService( 1560): Received start request. Starting profile...
D/BluetoothPanServiceJni( 1560): initializeNative(L110): pan
I/bluedroid( 1560): get_profile_interface pan
I/BtGatt.JNI( 1560): classInitNative(L873): classInitNative: Success!
D/BtGatt.DebugUtils( 1560): handleDebugAction() action=null
D/BtGatt.GattService( 1560): Received start request. Starting profile...
D/BtGatt.GattService( 1560): start()
I/bluedroid( 1560): get_profile_interface gatt
D/BtGatt.AdvertiseManager( 1560): advertise manager created
D/BluetoothMapService( 1560): Received start request. Starting profile...
D/BluetoothMapService( 1560): start()
D/BluetoothMapEmailSettingsLoader( 1560): Found 0 applications
D/BluetoothMapEmailAppObserver( 1560): createReceiver()
D/BluetoothMapEmailAppObserver( 1560): initObservers()
D/BluetoothMapEmailAppObserver( 1560): getEnabledAccountItems()
D/BluetoothAdapterState( 1560): CURRENT_STATE=PENDING, MESSAGE = STARTED, isTurningOn=true, isTurningOff=false
I/bluedroid( 1560): enable
I/bt_hci_bdroid( 1560): init
W/bt_vendor( 1560): ro.boot.btdev is and no mapped bt-vendor
I/bt_vendor( 1560): Redpine vendor init got called here!!!
I/GKI_LINUX( 1560): gki_task_entry task_id=0 [BTU] starting
I/bt-btu ( 1560): btu_task pending for preload complete event
E/bt_vendor( 1560): Mutyam enabling protocol bluetooth protocol:
E/bt_vendor( 1560): ROTOCOL ***
E/bt_vendor( 1560):
Hi mutyalarao
lollipop 5.1.1 supports Broadcom BCM4339 as bluetooth,
please refer to steps for enabling usb dongle bluetooth on
https://community.freescale.com/docs/DOC-93985
