Hi.
I using the CodeWarrior IDE (CW for MPC55xx, MPC56xx 2.10) compiler
Project -> Make
Project -> Debug
Setting is RAM is in good operation.
Setting is internal_FLASH
But it did not download below. (Please check the attached file)
Please fix the error TRK-MPC5606B
TRK-MPC5606B
Programming Address $00000000 Error during programming
ERROR 18 during script
in PEMICRO Connection Manager select CPU Target Information MPC5606BK or select Autodetect. If you select MPC5606B you get the error.
Martin
