Hello all,
I am trying to interface IMX6Q with a device(an FPGA actually) which directly gives 8 bit YCbCr format output with HSYNC , VSYNC and PIXCLK.
I went through the .dtsi files, the camera driver has been written as a part of the I2C driver.
So, as I am not using any decoder, I need some guidance on
which driver I should use, to capture the CSI data?
Thank you your time,
regards,
Nishad
Solved! Go to Solution.
Hi Nishad
seems one can try to remove i2c references or write new driver using
guidelines in attached Porting Guide Chapter 7 Supporting the i.MX 6Dual/6Quad/
6Solo/6DualLite Camera Sensor with CSI. As help is attached baremetal sensor
example from sdk.
Hi Nishad
example from sdk.
