Imx6 Framerate with LVDS split-mode
shuyuchou
I have 1920x1200 LVDS panel and add "split-mode" in dtsi of i.mx6.
There's cts refreshrate failed on "  android.view.cts.DisplayRefreshRateTest -- testRefreshRate" , the freshrate is only 32 fps.
I do the same test in imx6 bsp and ev board
The followings are test results of testRefreshRate on IMX6 evb:
Claimed fps
Average Achieve fps
evb Imx6Q ( wsithout split-mode)
  1. 60.000004  fps
59 fps
evb Imx6Q (with split-mode)
  1. 60.000004  fps
34 fps
Does anyone know how to resolve this problems ?
Is any limitation of  split-mode with resolution on IMX6?
Test info :
Image: Android 6.0. I.MX6 Q(download from NXP i.MX 6 Series Software and Development Tool Resource)
CPU : iMX6Q
EVB info : IMX6 Series SABRE for Smart Devices (detail info)
evb Imx6Q   split-mode  setting :
kernel_imx_/arch/arm/boot/dts/Imx6qdl-sabresd.dtsi
&ldb {
    status = "okay";
    split-mode;
    lvds-channel@0 {
fsl,data-mapping = "spwg";
fsl,data-width = <18>;
            status = "okay";
display-timings {
native-mode = <&timing0>;
timing0: hsd100pxn1 {
clock-frequency = <65000000>;
hactive = <1024>;
vactive = <768>;
hback-porch = <220>;
  hfront-porch = <40>;
vback-porch = <21>;
vfront-porch = <7>;
hsync-len = <60>;
vsync-len = <10>;
shuyu
Labels (2)
joanxie
do you mean refeshrate or framerate? the unit of refresh rate is HZ, fps is for frame rate.
_at
joanxie
Hi Joan Xie,
Same kind of question from me.
I have 1920x720 LVDS panel and add "split-mode" in dtsi of i.mx6.
LVDS panel says: 1920x720 @ 60 = 47.5 Mhz.
Is any limitation of  split-mode (odd/even) with resolution on IMX6?
Can you explain IPU DI0 clock settings and LVDS CH0/CH1 serialize clock settings for split-mode ?
The below settings is not functional:
  • IPU1 DI0 clock = 47.5 MHz, LDB CH0 serialzer clock = 166 MHz.
  • Screen is not synchronized to full 1920x720 panel
//// **  Not functional *** /////
&ldb {
status = "okay";
split-mode;
lvds-channel@0 {
fsl,data-width = <24>;
primary;
status = "okay";
display-timings {
timing0: C123HAN021 {
clock-frequency = <47500000>;
hactive = <1920>;
vactive = <720>;
hback-porch = <20>;
vback-porch = <20>;
vfront-porch = <10>;
hsync-len = <20>;
vsync-len = <10>;
The below settings functional but with limitation
  • Screen synchronized to full 1920x720
  • But 1/3 portion of screen's color is not proper RGB
  • 2/3 portion of screen is proper RGB
  • IPU1 DI0 clock = 142.5 MHz, LDB (CH0 serialzer clock) = 498 MHz.
//// **  functional with color limitation*** /////
&ldb {
status = "okay";
split-mode;
lvds-channel@0 {
primary;
status = "okay";
display-timings {
clock-frequency = <142500000>;
hactive = <1920>;
vactive = <720>;
hback-porch = <20>;
vback-porch = <20>;
hsync-len = <20>;
vsync-len = <10>;
Please help us to resolve this.
-Ankit.
