Hello, I'm using USB MSD Bootloader V3_2 for Coldfire V2 (MCF52259). Now I have problem with enumeration in OS windows 10. Is there any solution of this problem? Thank you. Jiri
Then the solution is to create a Windows 7 VM (or even an XP VM) specifically to support that debugger and your development environment.
Tom
I am afriad that the USB MSD bootloader for ColdFire does not tested under the WIN 10. Have you tried with Win 7?
Yes, I did. There is no problem under WIN 7.
