请问,iMX6UL EVK的板子,如果没有接LCD,直接接HDMI线到显示器会有输出吗?我使用mfgtool烧写的sd卡,但是启动的时候,HDMI接了显示器,显示器无任何输出。
一般情况下不接LCD的情况下是可以接HDMI显示器的
我们也有iMX6UL开发板,但是HDMI接口没有引出来
the latest information about hdmi:
The HDMI connector is on-board, but the HDMI transmitter is not due to sharing the same interface as the LCD. HDMI has not been validated / tested with the BSP. Internal discussions are ongoing.
