HI every one,
in imx6qdl-sabresd.dtsi file i need to change some code in place of volume up and volume down.I gave pir sensor and ntc sensor .But its giving synatx error .
pir {
label = "pir sensor";
gpios = <&gpio1 4 1>;
gpio-key,wakeup;
linux,code = <KEY_PIRSENSOR >; //synatx error showing
ntc {
label = "Ntc sensor";
gpios = <&gpio1 5 1>;
gpio-key,wakeup;
linux,code = <KEY_NTCSENSOR>; //synatx error showing
pir {
gpio-key,wakeup;
linux,code = <KEY_VOLUMEUP >; //pir sensor for customboard
ntc {
gpio-key,wakeup;
linux,code = <KEY_VOLUMEDOWN>; //ntc sensor for customboard
If i gave pir and ntc inplace of volumeup and volumedown keys .Its building .But i gave reverse its not building showing syntax error .
Have you checked that the KEY_PIRSENSOR and KEY_NTCSENSOR symbols are defined in a header file?
If not, it is expected to get a sintax error.
KEY_VOLUMEDOWN for example is defined in arch/arm/boot/dts/include/dt-bindings/input/input.h
Alejandro
